Re: m2t projects [message #489853 is a reply to message #489549] |
Tue, 06 October 2009 09:17 |
Siegfried Nolte Messages: 48 Registered: August 2009 |
Member |
Hi Mariam,
I'm not that expert, too. But I worked on that question as well and got some impression.
* JET - It's something like the Eclipse EMF defacto standard for generating code from models. You need a metamodel somehow XML based; UML will do very well. So you can generate Code from UML models, though UML-profiles are not, or not easily, supported, as far as I know.
* Acceleo implements the OMG's M2T standard. You will get code from any metamodel based model, UML and others.
* XPand is just like the above a metamodel based generation language, that uses a special template language.
They are alike, all of them work fine, so you have to like the one or another template notation. I'm working on a simple sample project showing those different notations and usage, but it's not ready yet.
Siegfried
FUDForum. Page generated in 0.02629 seconds
