Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » could anybody tell me what is 'interface' class?
could anybody tell me what is 'interface' class? [message #489451] Sat, 03 October 2009 02:49 Go to next message
I'm using the ECORE to build my metamodel, but | see there's two options for the normal Class, that is 'is interface' and 'is abstract', I know the later, but don't understand the former, could anybody tell me what is that? and how can I use it? thanks a lot.
Re: could anybody tell me what is 'interface' class? [message #489453 is a reply to message #489451] Sat, 03 October 2009 04:36 Go to previous messageGo to next message
If you specify isInterface to be true, an AbcImpl class won't be
generated for it; so it has to be isAbstract true as well.
Re: could anybody tell me what is 'interface' class? [message #489463 is a reply to message #489453] Sat, 03 October 2009 09:07 Go to previous messageGo to next message
Thanks a lot, then what is the difference between the Class (call A) only with 'isAbstract' and this Class (call B) with both 'isInterface' and 'isAbstract'?
As I know, A also will not be generated (I mean, when I build a model, it's not possible to create an instance for this abstract class), right? correct me if any mistake, I'm a beginner with EMF
Ed Merks wrote on Sat, 03 October 2009 04:36
Re: could anybody tell me what is 'interface' class? [message #489483 is a reply to message #489463] Sat, 03 October 2009 15:29 Go to previous messageGo to next message
The difference is, that you won't find any implementation class
(commonly in *.impl package) for the interface. The generator will
produce code for both abstract and concrete classes only.
Since now, i used 'isInterface' rather few, but i think there are some
scenarios, where this is helpful - otherwise, it would have been
cancelled from the framework!
I guess, that it has something to do with the multiple inheritance
solution of EMF. There might a situation, where the usage of interfaces
for the construction of an inheritance hierarchy is preferred, but
actually i'm not quite sure... a hint from the EMF guys would help at
this point, i think ...
> and 'isAbstract'?
>> flyduckegg wrote:
>> > I'm using the ECORE to build my metamodel, but | see there's two >
>> options for the normal Class, that is 'is interface' and 'is >
>> abstract', I know the later, but don't understand the former, could >
Re: could anybody tell me what is 'interface' class? [message #489503 is a reply to message #489483] Sun, 04 October 2009 03:44 Go to previous messageGo to next message
Timothy,
Technically EClass.isInterface and EStructuralFeature.isVolatile
probably should have been GenClass/GenFeature properties because they
don't affect dynamic models, only generated ones. One could imagine a
case where multiple inheritance is used, but a given interface is never
the primary inheritance (first eSuperType) used by any other class and
hence there'd be no direct use nor reuse of the generated Impl for it...
> interfaces for the construction of an inheritance hierarchy is
> preferred, but actually i'm not quite sure... a hint from the EMF guys
> would help at this point, i think ...
Re: could anybody tell me what is 'interface' class? [message #489585 is a reply to message #489503] Mon, 05 October 2009 03:07 Go to previous messageGo to next message
thanks, Timothy and Ed.
what is the implementation class used for? is that important? I usually creat dynamic instance from the ecore model, what's the difference between this one and the generated one?
also, I don't understand
'---but a given interface is never the primary inheritance (first eSuperType)--- '
here I attached a ecore model, the 'EClass3' is not the first eSupertype? it doesn't interit from anyone else.
Victor
I can't see the pic that I've attached, don't know why
Ed Merks wrote on Sun, 04 October 2009 03:44
Timothy,
[Updated on: Mon, 05 October 2009 03:10] by Moderator
Re: could anybody tell me what is 'interface' class? [message #489594 is a reply to message #489585] Mon, 05 October 2009 03:35 Go to previous message
Comments below.
For implementing the interface. :-P
> is that important?
Yes, kind of.
A generated one performs better and takes less space.
> also, I don't understand '---but a given interface is never the
Java interfaces support multiple interface inheritance but Java classes
only support single class inheritance, right? So you can at most extend
one class and generally EMF will use the implementation class of the
first eSuperType.
Try generating code and looking at that to help explore your questions...
>> Timothy,
>> a case where multiple inheritance is used, but a given interface is
>> never the primary inheritance (first eSuperType) used by any other
>> class and hence there'd be no direct use nor reuse of the generated
>> Impl for it...
>> Timothy Marc wrote:
>> > The difference is, that you won't find any implementation class >
>> (commonly in *.impl package) for the interface. The generator will >
>> some > scenarios, where this is helpful - otherwise, it would have
>> been > cancelled from the framework!
>> > solution of EMF. There might a situation, where the usage of >
>> interfaces for the construction of an inheritance hierarchy is >
>> guys > would help at this point, i think ...
>> A) >> only with 'isAbstract' and this Class (call B) with both >>
>> >> As I know, A also will not be generated (I mean, when I build a >>
>> model, it's not possible to create an instance for this abstract >>
>> two > >>> options for the normal Class, that is 'is interface' and
>> 'is > >>> abstract', I know the later, but don't understand the
>> former, could >>> > anybody tell me what is that? and how can I use
>> it? thanks a lot.
Re: could anybody tell me what is 'interface' class? [message #621415 is a reply to message #489453] Sat, 03 October 2009 09:07 Go to previous message
Re: could anybody tell me what is 'interface' class? [message #621418 is a reply to message #621415] Sat, 03 October 2009 15:29 Go to previous message
> and 'isAbstract'?
Re: could anybody tell me what is 'interface' class? [message #621420 is a reply to message #489483] Sun, 04 October 2009 03:44 Go to previous message
Timothy,
Re: could anybody tell me what is 'interface' class? [message #621427 is a reply to message #489503] Mon, 05 October 2009 03:07 Go to previous message
> Timothy,
Re: could anybody tell me what is 'interface' class? [message #621428 is a reply to message #621427] Mon, 05 October 2009 03:35 Go to previous message
Comments below.
> is that important?
Yes, kind of.
first eSuperType.
>> Timothy,
>> Impl for it...
>> it? thanks a lot.
Previous Topic:Graphical Ecore Editor and support for plugin URIs
Next Topic:Problem using jet.compile ANT task
Current Time: Thu Oct 30 16:02:29 EDT 2025
Powered by FUDForum. Page generated in 0.11754 seconds
