Home » Modeling » EMF » Side effects of setIntrinsicIDToEObjectMap
Side effects of setIntrinsicIDToEObjectMap [message #489128] Thu, 01 October 2009 11:09 Go to next message
So now after I got that HashMap speed up the loading it seem there are
some unwanted side effects.
After removing an element with an ID I could still see that element when
attempting to create a reference to it.
After restarting the workbench and opening the file that reference was
marked invalid as expected. In the same session I removed that file and
created a new one with the same name which now was known to contain the
object again. When opening that file the problems page again opened
claiming the references were invalid although they are not.
I guess these effects result from setIntrinsicIDToEObjectMap. Could I
avoid these effects by deleting or clearing the HashMap after the
resource is loaded or is there something else to tweak.
Thanks and Regards,
Dirk
Re: Side effects of setIntrinsicIDToEObjectMap [message #489140 is a reply to message #489128] Thu, 01 October 2009 11:25 Go to previous messageGo to next message
Dirk,
> when attempting to create a reference to it.
Isn't detachedHelper kicking in during the removal?
> and created a new one with the same name which now was known to
> contain the object again. When opening that file the problems page
> again opened claiming the references were invalid although they are not.
Doesn't it kick in during unload too?
Yes, but I'm not sure why you're seeing these problems...
> Thanks and Regards,
> Dirk
Re: Side effects of setIntrinsicIDToEObjectMap [message #489252 is a reply to message #489140] Fri, 02 October 2009 02:24 Go to previous message
Ed Merks schrieb:
> Dirk,
What's that supposed to be? I did a full text search for
"detachedHelper" but didn't get anything. Is that something that came in
after version 2.2.3?
>> Thanks and Regards,
>> Dirk
Previous Topic:[TENEO] Associate a GMF/EMF model with an Eclipse project
Next Topic:EcoreUtil.delete()...
Current Time: Thu Nov 06 09:40:59 EST 2025
Powered by FUDForum. Page generated in 0.03060 seconds
