Re: Page being rendered as XML [message #489170 is a reply to message #489151] |
Thu, 01 October 2009 16:42 |
Steve Whatmore Messages: 95 Registered: July 2009 |
Member |
Well I believe so here is my web.xml
<web-app version="2.5" xmlns="http://java.sun.com/xml/ns/javaee"
xsi:schemaLocation="http://java.sun.com/xml/ns/javaee
http://java.sun.com/xml/ns/javaee/web-app_2_5.xsd">
<context-param>
<param-name>javax.faces.PROJECT_STAGE</param-name>
<param-value>Development</param-value>
</context-param>
<context-param>
<description>
Set this flag to true if you want the JavaServer Faces Reference
Implementation to validate the XML in your faces-config.xml
resources
against the DTD. Default value is false.
</description>
<param-name>com.sun.faces.validateXml</param-name>
<param-value>false</param-value>
</context-param>
<context-param>
<param-name>log4jConfigLocation</param-name>
<param-value>/WEB-INF/properties/log4j.properties</param-value >
</context-param>
<context-param>
<param-name>javax.faces.STATE_SAVING_METHOD</param-name>
<param-value>server</param-value>
</context-param>
<context-param>
<description>Special Debug Output for Development</description>
<param-name>facelets.DEVELOPMENT</param-name>
<param-value>true</param-value>
</context-param>
<context-param>
<param-name>javax.faces.DEFAULT_SUFFIX</param-name>
<param-value>.faces</param-value>
</context-param>
<listener>
<listener-class>com.sun.faces.config.ConfigureListener</listener-class >
</listener>
<servlet>
<servlet-name>ConfigurationServlet</servlet-name>
<servlet-class>com.purefacts.web.util.ConfigurationServlet</servlet-class >
<init-param>
<param-name>configuration</param-name>
<param-value>/WEB-INF/properties/configuration.xml</param-value >
</init-param>
<load-on-startup>1</load-on-startup>
</servlet>
<servlet>
<servlet-name>StartupServlet</servlet-name>
<servlet-class>com.purefacts.web.util.StartupServlet</servlet-class >
<init-param>
<param-name>ApplicationName</param-name>
<param-value></param-value>
</init-param>
<load-on-startup>2</load-on-startup>
</servlet>
<servlet>
<servlet-name>FacesServlet</servlet-name>
<servlet-class>javax.faces.webapp.FacesServlet</servlet-class >
</servlet>
<servlet-mapping>
<url-pattern>*.faces</url-pattern>
</servlet-mapping>
<session-config>
<session-timeout>720</session-timeout>
</session-config>
<error-page>
<error-code>500</error-code>
<location>/jsf/errorPage.faces</location>
</error-page>
<error-page>
<error-code>404</error-code>
</error-page>
<error-page>
<exception-type>java.lang.Exception</exception-type>
</error-page>
<welcome-file-list>
<welcome-file>index.jsp</welcome-file>
</welcome-file-list>
</web-app>
I am receiving no errors on startup (see log below)
Oct 1, 2009 12:17:06 PM org.apache.catalina.core.AprLifecycleListener init
INFO: The Apache Tomcat Native library which allows optimal performance in
production environments was not found on the java.library.path:
C:\DEV\Java\JDK\jdk1.6.0_10\bin;.;C:\Windows\Sun\Java\bin;C: \Windows\system32;C:\Windows;C:/DEV/Java/JDK/jre6/bin/client ;C:/DEV/Java/JDK/jre6/bin;C:\DEV\DB\Sybase\Client\DataAccess \ADONET\dll;C:\DEV\DB\Sybase\Client\DataAccess\OLEDB\dll;C:\ DEV\DB\Sybase\Client\DataAccess\ODBC\dll;C:\DEV\DB\Sybase\Cl ient\OCS-15_0\lib3p;C:\DEV\DB\Sybase\Client\OCS-15_0\dll;C:\ DEV\DB\Sybase\Client\OCS-15_0\bin;C:\Program
Files (x86)\Windows Resource Kits\Tools\;C:\Program Files (x86)\Common
Files\Microsoft Shared\Windows
Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem ;C:\Program
Files (x86)\NTRU Cryptosystems\NTRU TCG Software Stack\bin\;C:\Program
Files\NTRU Cryptosystems\NTRU TCG Software Stack\bin\;C:\Program Files\Wave
Systems Corp\Gemalto\Access
Client\v5\;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Pr ogram Files
(x86)\Microsoft SQL Server\90\Tools\binn\;C:\Program Files
(x86)\TortoiseSVN\bin;C:\Program Files (x86)\Common Files\Roxio
Shared\9.0\DLLShared\;C:\Program Files\TortoiseSVN\bin;C:\Program
Files\Common Files\Microsoft Shared\Windows
Live;C:\DEV\DB\DB2\IBM\SQLLIB\BIN;C:\DEV\DB\DB2\IBM\SQLLIB\F UNCTION;C:\DEV\DB\DB2\IBM\SQLLIB\SAMPLES\REPL;C:\Program
Files (x86)\Microsoft SQL Server\100\Tools\Binn\;C:\Program Files\Microsoft
SQL Server\100\Tools\Binn\;C:\Program Files\Microsoft SQL
Server\100\DTS\Binn\;C:\Program Files (x86)\Microsoft SQL
Server\100\Tools\Binn\VSShell\Common7\IDE\;C:\Program Files (x86)\Microsoft
SQL Server\100\DTS\Binn\;C:\Program Files (x86)\Microsoft Visual Studio
9.0\Common7\IDE\PrivateAssemblies\;C:\Program Files (x86)\Common Files\Roxio
Shared\DLLShared\;C:\Program Files (x86)\Common Files\Roxio
(x86)\QuickTime\QTSystem\;C:\DEV\DB\Sybase\Client\DBISQL\bin ;C:\Program
Files\Common Files\Microsoft Shared\Windows Live
Oct 1, 2009 12:17:06 PM org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8080
Oct 1, 2009 12:17:06 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 407 ms
Oct 1, 2009 12:17:06 PM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
Oct 1, 2009 12:17:06 PM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.13
Oct 1, 2009 12:17:07 PM com.sun.faces.config.ConfigureListener
contextInitialized
INFO: Initializing Mojarra 2.0.0 (RC b16) for context '/PF'
Oct 1, 2009 12:17:08 PM
com.sun.faces.config.ConfigureListener$WebConfigResourceMoni tor$Monitor
<init>
INFO: Monitoring jndi:/localhost/PF/WEB-INF/faces-config.xml for
modifications
Oct 1, 2009 12:17:08 PM org.apache.catalina.core.ApplicationContext log
INFO: Set web app root system property: 'webapp.root' =
[C:\Projects-3.5\.metadata\.plugins\org.eclipse.wst.server.c ore\tmp0\wtpwebapps\PF\]
INFO: Initializing log4j from
[C:\Projects-3.5\.metadata\.plugins\org.eclipse.wst.server.c ore\tmp0\wtpwebapps\PF\WEB-INF\properties\log4j.properties]
2009-10-01 12:17:08,638 DEBUG com.purefacts.web.util.ConfigurationServlet
init - Loading configuration file: /WEB-INF/properties/configuration.xml
2009-10-01 12:17:08,677 DEBUG
org.apache.commons.configuration.ConfigurationUtils locate -
ConfigurationUtils.locate(): base is null, name is null
2009-10-01 12:17:08,680 DEBUG com.purefacts.util.AbstractConfiguration
debug - loadApplicationConfiguration
2009-10-01 12:17:08,691 DEBUG
Oct 1, 2009 12:17:08 PM org.apache.coyote.http11.Http11Protocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
Oct 1, 2009 12:17:08 PM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
Oct 1, 2009 12:17:08 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/20 config=null
Oct 1, 2009 12:17:08 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 2662 ms
However, now I am running into the problem of how to setup JSF 2.0 in
"Yury Kats" <ykats@us.ibm.com> wrote in message
news:ha2j61$2f5$1@build.eclipse.org...
> What's your file's extension and is your jsf runtime configured to handle
> that extension?
> On 10/1/2009 9:58 AM, Whatty wrote:
>> Good morning,
>> I am in the middle of upgrading to JSF 2.0 and am having problems getting
>> my
>> very basic page to render as HTML in the embedded browser.
>> Here is the source of the page.
>> <html xmlns="http://www.w3.org/1999/xhtml"
>> xmlns:ui="http://java.sun.com/jsf/facelets"
>> xmlns:h="http://java.sun.com/jsf/html"
>> xmlns:f="http://java.sun.com/jsf/core">
>> <body bgcolor="white">
>> HELLO WORLD!
>> </body>
>> </html>
>> and this source is actually be displayed in the browser.
>> This seems to indicate to me that the page is not actually being executed
>> by
>> the JSF engine.
>> Anyone seen this and can assist?
>> Whatty
Re: Page being rendered as XML [message #620438 is a reply to message #489151] |
Member |
<context-param>
</context-param>
<context-param>
<description>
resources
</description>
</context-param>
<context-param>
</context-param>
<context-param>
</context-param>
<context-param>
</context-param>
<context-param>
</context-param>
<listener>
</listener>
<servlet>
<init-param>
</init-param>
</servlet>
<servlet>
<init-param>
</init-param>
</servlet>
<servlet>
</servlet>
<servlet-mapping>
</servlet-mapping>
<session-config>
</session-config>
<error-page>
</error-page>
<error-page>
</error-page>
<error-page>
</error-page>
<welcome-file-list>
</web-app>
contextInitialized
<init>
modifications
> that extension?
>> Good morning,
>> my
>> HELLO WORLD!
>> </body>
>> </html>
>> by
>> the JSF engine.
>> Whatty
FUDForum. Page generated in 0.02508 seconds
