Home » Eclipse Projects » Rich Client Platform (RCP) » Commandframework
Commandframework [message #488332] Mon, 28 September 2009 04:26 Go to next message
I have a own command and a handler. This handler is enable when the activeEditor implement my own interface IClearable.
This works:
   <handler
            class="ui.command.MaskDeleteHandler"
            commandId="MaskDelete">
         <enabledWhen>
            <with
                  variable="activeEditor">
               <instanceof
                     value=IClerable>
               </instanceof>
            </with>
         </enabledWhen>
      </handler>
public interface IClearable
public boolean isClear();
But now I want a 2nd condition. The command should only be enabled, if the activeEditor implements IClearable and the isClear methode returns true.
How could I do this?
Thx a lot Smile
Re: Commandframework [message #488345 is a reply to message #488332] Mon, 28 September 2009 06:47 Go to previous messageGo to next message
SirWayne schrieb:
> Hello,
> This works:
> <handler
> <enabledWhen>
> <with
> <instanceof
> value=IClerable>
> </instanceof>
> </with>
> </enabledWhen>
> </handler>
> true.
> Thx a lot :)
use a PropertyTester for this:
http://wiki.eclipse.org/Command_Core_Expressions#Property_Te sters
Re: Commandframework [message #488380 is a reply to message #488345] Mon, 28 September 2009 09:43 Go to previous messageGo to next message
Do you have an example?
Do I need a own ProprtyTester
import org.eclipse.core.expressions.PropertyTester;
import org.eclipse.ui.IPerspectiveDescriptor;
import org.eclipse.ui.IWorkbench;
import org.eclipse.ui.IWorkbenchPage;
import org.eclipse.ui.IWorkbenchPart;
public class ClearPropertyTester extends PropertyTester {
	public boolean test(Object receiver, String property, Object[] args,
			Object expectedValue) {
		if (receiver instanceof IWorkbench ) {
			final IWorkbench window = (IWorkbench) receiver;
				IWorkbenchPart part = window.getActiveWorkbenchWindow().getActivePage().getActivePart();
				if (part != null && part instanceof IClearable) {
					return ((IClearable)part).isClear();
		return false;
or how i have to use?
Re: Commandframework [message #488466 is a reply to message #488380] Mon, 28 September 2009 15:35 Go to previous messageGo to next message
Ok got it thx =)
Solution:
      <handler
            <enabledWhen>
               <with
                     variable="activePart">
                  <test
                        forcePluginActivation="true"
                        property="ui.command.interfaces.isClearable">
                  </test>
               </with>
            </enabledWhen>
      </handler>
<propertyTester
            class="ui.command.propertytester.ClearProperyTester"
            id="ClearProperyTester"
            namespace="ui.command.interfaces"
            properties="isClearable"
            type="ui.command.interfaces.IClearable">
      </propertyTester>
import ui.command.interfaces.IClearable;
public class ClearProperyTester extends PropertyTester {
    public boolean test(Object receiver, String property, Object[] args, Object expectedValue) {
        return ((IClearable) receiver).isClearable();
Re: Commandframework [message #488470 is a reply to message #488380] Mon, 28 September 2009 15:43 Go to previous message
*doppel post*
[Updated on: Tue, 29 September 2009 01:53] by Moderator
Previous Topic:New Wizards
Next Topic:[DataBinding] Does there exist a BufferedObservable?
Current Time: Thu Sep 25 22:36:34 EDT 2025
Powered by FUDForum. Page generated in 0.08444 seconds
