Re: CNF view activatation [message #489046 is a reply to message #488506] |
Thu, 01 October 2009 11:10 |
Mark Miller Messages: 5 Registered: July 2009 |
I have exactly the same problem. I am also on 3.5 but i also had this under ganymede.
This appears to happen under windows and linux.
The strange thing is that this only happens in an RCP and not in the eclipse application itself.
Any help would be greatly appreciated as this leads to a problem of the selection not becoming active and so a double click (which opens the editor using a command) fails saying that the command was not found (as i have an activeWhen defined which requires a selection).
All the best,
Mark
[Updated on: Thu, 01 October 2009 11:11] Report message to a moderator
Re: CNF view activatation [message #489074 is a reply to message #489048] |
Thu, 01 October 2009 12:53 |
I have finally figured this out.
If anyone else is interested the issue is with setFocus in editors. Editors inheriting from FormEditor with pages added extending from FormPage, set the focus to the pages scrolled form. This seems to cause problems.
Overriding the setFocus method in the subclassed FormEditor and explicitly delegating setFocus to the subclassed FormPage (which then sets the focus to an internal control) seems to get rid of the problem.
[Updated on: Thu, 01 October 2009 12:54] Report message to a moderator
FUDForum. Page generated in 0.03427 seconds
