Re: isBlockSelectionModeEnabled error on code from jface [message #488320 is a reply to message #487718] |
Mon, 28 September 2009 05:42 |
Matthew Lowry Messages: 1 Registered: July 2009 |
For what it's worth, I've just noticed I'm getting the exact same error. I'm working on a Java project that has an XML file in it, and I just noticed that when I opened the XML file it came up in the plain text editor and not the XML editor. The file is very simple and rarely editted, so I hadn't actually noticed I wasn't getting the syntax highlighting and other goodies of the XML editor; hence I have no idea how long this has been happening.
Anyway, I'm getting the same symptoms as the OP. My log file shows the same stack trace, and the other editors (Java and plain text) that I use are working fine. I running on the same type of system (Win32 / x86) as the OP.
One factor that could be important in this: my installed version of the XML editor and WST core / UI / XML core packages is the latest from the WTP update site (version 3.1.0), rather than the version offered by the Ganymede update site (version 3.0.4).
No idea what the problem is, and since I don't really care (I can survive without the XML editor for now) I'm not going to spend the time looking for a workaround. Just putting this out there for the record.
Matt.
[Updated on: Mon, 28 September 2009 05:44] Report message to a moderator
FUDForum. Page generated in 0.02942 seconds
