Re: Unable to load mixed content when loading an ecore model derived from an xml schema [message #487327 is a reply to message #487305] |
Tue, 22 September 2009 18:30 |
Ed Merks Messages: 33142 Registered: July 2009 |
Dhiraj,
I answered on the EMF newsgroup.
Dhiraj wrote:
> I have the following sample xsd:-
> <?xml version="1.0" encoding="UTF-8" standalone="no"?>
> <schema xmlns="http://www.w3.org/2001/XMLSchema"
> xmlns:tns="http://www.example.org/NewXMLSchema"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> elementFormDefault="qualified"
> targetNamespace="http://www.example.org/NewXMLSchema">
> <complexType mixed="true" name="PersonType">
> <sequence>
> <any processContents="lax" namespace="##any" minOccurs="0"
> maxOccurs="unbounded"/>
> </sequence>
> <attribute name="name" type="string" />
> </complexType>
> <element name="Person" type="tns:PersonType"></element>
> </schema>
> And using the EMF Project I created an ecore out of this xsd and
> added a derived feature 'classification' which would be assigned
> the value from the text node of the Person element. The ecore for
> this derived attribute is like this:-
> <eStructuralFeatures xsi:type="ecore:EAttribute"
> name="classification" eType="ecore:EDataType
> http://www.eclipse.org/emf/2003/XMLType#//String"
> volatile="true" transient="true" defaultValueLiteral=""
> derived="true">
> <eAnnotations
> source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
> <details key="name" value=":3"/>
> <details key="kind" value="simple"/>
> </eAnnotations>
> </eStructuralFeatures>
> I have attached the complete ecore file with this post (filename:
> schema.ecore)
> Then I was trying to load the following model file (xml file):-
> <schema:Person xmlns:schema="http://www.example.org/NewXMLSchema"
> name="Dhiraj">Dhiraj KUmar<schema:Person name="Manoj"/></schema:Person>
> using the following Junit test, but for some reason the 'mixed'
> attribute of
> the PersonType EObject was not being loaded with the correct values
> and as
> a result the 'classification' feature was having an empty value.
> Following is
> the code to load the model file:-
> public class ModelLoadingTest extends TestCase {
> public void testLoading() {
> URI composite2xURI = URI.createPlatformPluginURI(
> "/PersonEcore/test/Person.schema", true);
> ResourceSet rset = new ResourceSetImpl();
> rset.getPackageRegistry().put("http://www.example.org/NewXMLSchema",
> getPersonEPackage());
> rset.getPackageRegistry().put("http://www.eclipse.org/xsd/2002/XSD",
> XSDPackage.eINSTANCE);
> XMLResourceImpl c2xRes = new XMLResourceImpl(composite2xURI);
> Map<Object, Object> defaultLoadOptions =
> c2xRes.getDefaultLoadOptions();
> defaultLoadOptions.put(XMLResource.OPTION_RECORD_UNKNOWN_FEA TURE,
> Boolean.TRUE);
> defaultLoadOptions.put(XMLResource.OPTION_EXTENDED_META_DATA ,
> Boolean.TRUE);
> rset.getResources().add(c2xRes);
> try {
> c2xRes.load(null);
> System.out.println("loaded the resource correctly...");
> EObject person = c2xRes.getContents().get(0);
> person.getClass();
> } catch (IOException e) {
> e.printStackTrace();
> public EPackage getPersonEPackage() {
> EPackage composite2xPkg = null;
> Resource res = rset
> .createResource(URI.createPlatformPluginURI(
> "/PersonEcore/model/schema.ecore", true));
> //$NON-NLS-1$ //$NON-NLS-2$
> try {
> res.load(null);
> composite2xPkg = (EPackage) res.getContents().get(0);
> return composite2xPkg;
> Do I need to pass some other options while loading such resources?
Ed Merks
Re: Unable to load mixed content when loading an ecore model derived from an xml schema [message #604373 is a reply to message #487305] |
Dhiraj,
> <sequence>
> </sequence>
> </complexType>
> </schema>
> derived="true">
> <eAnnotations
> </eAnnotations>
> schema.ecore)
> attribute of
> and as
> Following is
> Boolean.TRUE);
> Boolean.TRUE);
> try {
> c2xRes.load(null);
> person.getClass();
> Resource res = rset
> try {
> res.load(null);
Ed Merks
FUDForum. Page generated in 0.04057 seconds
