| RCP hangs [message #487138] |
Tue, 22 September 2009 02:51 |
Originally posted by: yoduderoo.netscape.net
I have a RCP app, which after a certain operation, hangs. When I run the
app from the java command line (java -jar plugins/*launcher*jar) instead
of the launcher, the problem does not occur. Also, the problem does not
occur when launching from the workspace.
There is reason to suspect a heap problem, but nothing is written to the
log and a heapdump is not not generated.
I play with the maximum heap value in eclipse.ini, but it has no effect.
The memory size always stays the same, surprisingly.
Is there a fundamental difference in how the app runs when it is
launched from the launcher.exe ?
Thanks,y
FUDForum. Page generated in 0.24324 seconds
