Home » Eclipse Projects » EclipseLink » criteria API: select count(*) from ..
criteria API: select count(*) from .. [message #487130] Tue, 22 September 2009 01:27 Go to next message
Is it correct usage?
EntityManager em = getEntityManager();
try {
QueryBuilder qb = em.getQueryBuilder();
CriteriaQuery cq = qb.createQuery();
Root<DiscountCode> dc = cq.from(DiscountCode.class);
cq.select(qb.count(dc));
Query q = em.createQuery(cq);
return ((Long) q.getSingleResult()).intValue();
} finally {
em.close();
if yes, then I got two issues here in eclipselink 2.0 M7, return value
is double (may be known issue
https://bugs.eclipse.org/bugs/show_bug.cgi?id=289830)
and value is powered in two, i.e. if I have 6 rows result will be 36.0,
after addition of one more row I have result 49.0, it may be somehow
related to issue https://bugs.eclipse.org/bugs/show_bug.cgi?id=245653
but may be another one.
Re: criteria API: select count(*) from .. [message #487815 is a reply to message #487130] Thu, 24 September 2009 09:47 Go to previous messageGo to next message
The first issue seems to be the same as the logged bug. Please try again on the next good 2.0 build.
The second issue does not seem related. It seems that it is joining the DiscountCode twice for some reason. Please include the SQL generated. If you use the dc variable in the where clause, does the extra join still occur? Either way it seems like a bug, maybe retry in the latest build, and if it still occurs log the bug.
Re: criteria API: select count(*) from .. [message #487885 is a reply to message #487815] Thu, 24 September 2009 13:01 Go to previous messageGo to next message
James пишет:
ok, I can try, where I can find dayly builds of el 2.0?
second one issue generate multiplied by itself results if count if used,
and generate expected result(except type) if countDistinct is used.
Re: criteria API: select count(*) from .. [message #487887 is a reply to message #487815] Thu, 24 September 2009 13:06 Go to previous messageGo to next message
James пишет:
> still occur?
one more, how I can find what sql is generated?
will try a bit later
Re: criteria API: select count(*) from .. [message #487888 is a reply to message #487885] Thu, 24 September 2009 13:09 Go to previous messageGo to next message
Serge пишет:
found nightly myself, will try
Re: criteria API: select count(*) from .. [message #487894 is a reply to message #487888] Thu, 24 September 2009 13:55 Go to previous messageGo to next message
Serge пишет:
> Serge пишет:
looks fixed in 090921, will reverify tomorrow
Re: criteria API: select count(*) from .. [message #488000 is a reply to message #487894] Fri, 25 September 2009 05:18 Go to previous message
Serge пишет:
> Serge пишет:
>> Serge пишет:
and 090925 have both issues fixed, thanks
Previous Topic:Inheritance problem with Id in subclass
Next Topic:Unknown entity type
Current Time: Sat Sep 27 00:47:03 EDT 2025
Powered by FUDForum. Page generated in 0.03575 seconds
