Re: Extending the BPMN Modeler [message #503334 is a reply to message #502247] |
Fri, 11 December 2009 23:03 |
Originally posted by: atoulme.intalio.com
On 12/7/09 4:59 AM, Christian Kuhl wrote:
> Hey it's me again.
> Antoine, thanks for the links!
> I decided to use extension points to add the new entry for a Subclass of
> "SubProcess" to my palette. So far so good, I also managed to assign it
> to a CreationTool but thats where my problems come in:
> I don't seem to be able to create anything when Im using my own
> elementType. Maybe I missed to specify something?
> My own PaletteFactory contains this:
> return new CreationTool(BpmnElementTypes.MyOwnSubprocess);
> So what I did was basically: I tried to define an "IElementType" in
> BpmnElementTypes and add the elementType to plugin.xml
> <metamodel nsURI="http://stp.eclipse.org/bpmn">
> <metamodelType
> id="org.eclipse.stp.bpmn.diagram.MyOwnSubProcess"
> name="%sub_process_label"
> kind="org.eclipse.gmf.runtime.emf.type.core.IHintedType"
> eclass="MyOwnSubprocess"
> edithelper=" org.eclipse.stp.bpmn.diagram.edit.helpers.SubProcessEditHelp er ">
> <param name="semanticHint" value="2002"/>
> </metamodelType>
> </metamodel>
> However, there are a few things Im not sure about: The semantic Hint for
> example. Also is it necessary to create new viewProvider and
> EditPartProvider classes ?(I saw that in some other tutorial) I was
> hoping I could simply use the existing Helper class since it doesnt
> explicitly mention the type "Subprocess" anywhere.
> As some of you might suspect I am by no means an expert in GMF :blush:
> Anyways: when I want to draw my own Object it just doesnt let me (there
> is this little "not allowed" sign on my pointer)
> Has anyone ever done something similar?
> ANY help is greatly appreciated! :)
As a rule of thumb, don't touch element types as they are defined in the
model of the diagram. You can use annotations to customize your items.
Antoine
FUDForum. Page generated in 0.03651 seconds
