Home » Eclipse Projects » Eclipse Platform » Cannot launch application on some Linux machine after upgrade to eclipse 3.5
Cannot launch application on some Linux machine after upgrade to eclipse 3.5 [message #487042] |
Mon, 21 September 2009 11:59  |
After upgrade our product to eclipse 3.5, we run into problem
on some Linux machines (We do have different Linux set ups due to
customers have various Linux machine setup).
The Linux machine we run into problem has following setting:
SUSE 10 SP2
nVidia Quadro graphic card and matching graphic driver
Here is the problem we have:
If use jre 1.5.0_11, we cannot launch our product at all.
If use jre 1.6.0_10, we were able to start application, how ever, when
we try to launch a dialog, we will get following error:
Xlib: sequence lost …….
Xlib: unexpected async reply ( sequence 0x3c695)!
And after the error, the product freezes. Look at log file, I am seeing
following output:
org.eclipse.swt.internal.gtk.OS._gdk_window_clear_area(OS.ja va:-2)
org.eclipse.swt.internal.gtk.OS.gdk_window_clear_area(OS.jav a:4606)
org.eclipse.swt.widgets.Tree.rendererRenderProc(Tree.java:25 80)
org.eclipse.swt.widgets.Display.rendererRenderProc(Display.j ava:1305)
org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(OS.java:- 2)
org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:75 86)
org.eclipse.swt.widgets.Display.eventProc(Display.java:1185)
org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(OS .java:-2)
org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS. java:1858)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3110)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
myApplication.runApplication(null:-1)
myApplication.start(null:-1)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
sun.reflect.NativeMethodAccessorImpl.invoke0(NativeMethodAcc essorImpl.java:-2)
java.lang.reflect.Method.invoke(Method.java:597)
org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
org.eclipse.equinox.launcher.Main.run(Main.java:1311)
org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Thread[AWT-EventQueue-0,6,main]/java.awt.EventDispatchThread [Alive]
com.sun.java.swing.plaf.gtk.GTKNativeEngine.nativeFinishPain ting(GTKNativeEngine.java:-2)
com.sun.java.swing.plaf.gtk.GTKNativeEngine.finishPainting(G TKNativeEngine.java:494)
com.sun.java.swing.plaf.gtk.GTKPainter.paintButtonBackground Impl(GTKPainter.java:348)
com.sun.java.swing.plaf.gtk.GTKPainter.paintButtonBackground (GTKPainter.java:253)
javax.swing.plaf.synth.SynthButtonUI.paintBackground(SynthBu ttonUI.java:233)
javax.swing.plaf.synth.SynthButtonUI.update(SynthButtonUI.ja va:205)
javax.swing.JComponent.paintComponent(JComponent.java:763)
javax.swing.JComponent.paint(JComponent.java:1027)
javax.swing.JComponent.paintChildren(JComponent.java:864)
javax.swing.JComponent.paint(JComponent.java:1036)
javax.swing.JLayeredPane.paint(JLayeredPane.java:564)
javax.swing.JComponent.paintToOffscreen(JComponent.java:5129 )
javax.swing.BufferStrategyPaintManager.paint(BufferStrategyP aintManager.java:277)
javax.swing.RepaintManager.paint(RepaintManager.java:1217)
javax.swing.JComponent.paint(JComponent.java:1013)
java.awt.GraphicsCallback$PaintCallback.run(GraphicsCallback .java:21)
sun.awt.SunGraphicsCallback.runOneComponent(SunGraphicsCallb ack.java:60)
sun.awt.SunGraphicsCallback.runComponents(SunGraphicsCallbac k.java:97)
java.awt.Container.paint(Container.java:1762)
javax.swing.RepaintManager.paintDirtyRegions(RepaintManager. java:814)
javax.swing.RepaintManager.paintDirtyRegions(RepaintManager. java:714)
javax.swing.RepaintManager.seqPaintDirtyRegions(RepaintManag er.java:694)
javax.swing.SystemEventQueueUtilities$ComponentWorkRequest.r un(SystemEventQueueUtilities.java:128)
java.awt.event.InvocationEvent.dispatch(InvocationEvent.java :209)
java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
java.awt.EventDispatchThread.pumpOneEventForFilters(EventDis patchThread.java:269)
java.awt.EventDispatchThread.pumpEventsForFilter(EventDispat chThread.java:184)
java.awt.EventDispatchThread.pumpEventsForFilter(EventDispat chThread.java:178)
java.awt.Dialog$1.run(Dialog.java:1047)
java.awt.Dialog$3.run(Dialog.java:1099)
java.security.AccessController.doPrivileged(AccessController .java:-2)
java.awt.Dialog.show(Dialog.java:1097)
java.awt.Component.show(Component.java:1447)
java.awt.Component.setVisible(Component.java:1400)
java.awt.Window.setVisible(Window.java:824)
java.awt.Dialog.setVisible(Dialog.java:987)
myDialog.setVisible(null:-1)
myDialog.run(null:-1)
java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDis patchThread.java:174)
java.awt.EventDispatchThread.pumpEvents(EventDispatchThread. java:169)
java.awt.EventDispatchThread.pumpEvents(EventDispatchThread. java:161)
java.awt.EventDispatchThread.run(EventDispatchThread.java:12 2)
Thread[Worker-3,5,main]/org.eclipse.core.internal.jobs.Worke r [Alive]
java.awt.Component.enable(Component.java:1274)
javax.swing.JComponent.enable(JComponent.java:3563)
java.awt.Component.enable(Component.java:1298)
java.awt.Component.setEnabled(Component.java:1263)
javax.swing.JComponent.setEnabled(JComponent.java:2647)
myAppJob.run(null:-1)
org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Please help me. I am stuck here, tried all the work around I can find,
but no luck. I appreciate any help or hint.
Hongying
Re: Cannot launch application on some Linux machine after upgrade to eclipse 3.5 [message #487219 is a reply to message #487042] |
Tue, 22 September 2009 09:45   |
I see awt and swing in your output log, so I assume you're running an RCP
app. I haven't heard of problems at gdk_window_clear_area() before. Are
there other Linux machines that your app does work on? Can you provide a
code snippet that shows the problem, based on the dialog that hangs for you?
Grant
"Hongying Zhang" <hongying.zhang@ugs.com> wrote in message
news:h987su$j59$1@build.eclipse.org...
> Hello,
> SUSE 10 SP2
> Xlib: sequence lost
Re: Cannot launch application on some Linux machine after upgrade to eclipse 3.5 [message #487282 is a reply to message #487219] |
Tue, 22 September 2009 12:27   |
Grant,
Yep, We are running an RCP application. We do have some Linux machines
that our RCP application runs good. We compared the Linux machines, the
differences are:
The Linux machine RCP app runs good has following setup: KDE GUI, nVidia
Quadro graphic card (FX 1400) and matching graphic driver
The Linux machine RCP app doesn't run has following setup: GNOME GUI,
nVidia Quadro graphic card (FX 550) and matching graphic driver
Our application runs good on both machine (eclipse 3.3) before upgrade
to eclipse 3.5
I will try to provide a snippet that can reproduce the issue.
Hongying
Grant Gayed wrote:
> Grant
>> Hello,
>> SUSE 10 SP2
>> following output:
> 194)
> pLauncher.java:79)
> 2)
> .java:25)
> gine.java:-2)
> ava:494)
> java:348)
> :253)
> :277)
> :269)
> 4)
> 8)
> :269)
> 4)
> :174)
>> Thanks,
>> Hongying
Re: Cannot launch application on some Linux machine after upgrade to eclipse 3.5 [message #487349 is a reply to message #487219] |
Tue, 22 September 2009 16:00   |
Grant,
Thanks for reply. Yep, We are running an RCP application, and we do have
some Linux machines that our RCP application runs good. We compared the
Linux machines, the differences are:
to eclipse 3.5
Hongying
Grant Gayed wrote:
> Grant
>> Hello,
>> SUSE 10 SP2
>> following output:
> 194)
> pLauncher.java:79)
> 2)
> .java:25)
> gine.java:-2)
> ava:494)
> java:348)
> :253)
> :277)
> :269)
> 4)
> 8)
> :269)
> 4)
> :174)
>> Thanks,
>> Hongying
Re: Cannot launch application on some Linux machine after upgrade to eclipse 3.5 [message #487507 is a reply to message #487349] |
Wed, 23 September 2009 09:21  |
Also possibly relevant, which GTK+ versions and/or linux distros are on the
working and non-working linux machines?
Grant
news:h9bacj$ef5$1@build.eclipse.org...
> Grant,
> to eclipse 3.5
> Hongying
> Grant Gayed wrote:
> > Hi,
RCP
Are
a
you?
> > Grant
> >> Hello,
> >> SUSE 10 SP2
> >> Xlib: sequence lost
Current Time: Sat Jul 26 20:15:03 EDT 2025
Powered by FUDForum. Page generated in 0.08122 seconds
