Home » Archived » B3 » Ideas from Grails dependency resolution
Ideas from Grails dependency resolution [message #486586] Fri, 18 September 2009 10:37 Go to next message
Henrik Lindberg is currently offline Henrik LindbergFriend
In a tweat, Oisin mentioned that something like the grails dependency
management http://tr.im/z1Y9 should be considered for b3.
Not knowing what Oisin liked in particular, I think these two features
are important, and should be handled by b3:
- injection of dependencies
- ability to have different dependencies injected (or removed) for
different actions
Maybe there were some more features...
- henrik
Re: Ideas from Grails dependency resolution [message #486649 is a reply to message #486586] Fri, 18 September 2009 14:08 Go to previous messageGo to next message
Oisin Hurley is currently offline Oisin HurleyFriend
Henrik Lindberg wrote on Fri, 18 September 2009 06:37
different actions
The first thing that struck me was the syntax - editable without
any XML and without any need for the simplifying influence of
an IDE. It's very important to me that I can describe all of the
metadata I need to describe in a way that is compact and can
be simply edited as necessary from a ssh connection.
So that's more of a 'user' requirement than a core function
requirement, i.e. that there must be a way to conveniently
update build files through a remote terminal access provided
as part of the basic b3 package - not as an extension.
Does that make sense?
cheers
--oh
Re: Ideas from Grails dependency resolution [message #486673 is a reply to message #486649] Fri, 18 September 2009 14:57 Go to previous messageGo to next message
>> different actions
> The first thing that struck me was the syntax - editable without any XML
Yes, I thought that looked nice too. In b3, the idea is to separate the
resulting model from the artifacts - although it would certainly be
possible to save Ecore instances of the b3 models, these are not
suitable for human editing :)
The idea is to invent compact and easy to use syntax with XText as an
alternative to some GUI based editor. The nice thing being that there
can be different formats/editors etc. suitable for different situations,
and that specifications may "add up" - i.e. that a full gui based editor
could be used to create some overall model, and that additional
"stuff/advice" can be provided in a compact format.
> So that's more of a 'user' requirement than a core function requirement,
Yes, that makes a lot of sense.
> cheers
> --oh
Re: Ideas from Grails dependency resolution [message #486679 is a reply to message #486673] Fri, 18 September 2009 15:12 Go to previous messageGo to next message
Henrik Lindberg wrote on Fri, 18 September 2009 10:57
Sounds cool - this is something that I would like to
contribute to.
--oh
Re: Ideas from Grails dependency resolution [message #527252 is a reply to message #486679] Wed, 14 April 2010 15:05 Go to previous messageGo to next message
Werner Keil is currently offline Werner KeilFriend
Has there been any result from this discussion?`
I'm working heavily with Grails right now, so in this area I'd also be happy
to contribute to.
Werner
Re: Ideas from Grails dependency resolution [message #527343 is a reply to message #527252] Wed, 14 April 2010 20:59 Go to previous message
I guess the result is the implementation of the b3 model and concrete
text representation (language) as described in the first draft of the b3
book.
I am very interested in feedback on b3, comparision to grails, etc.
- henrik
> happy to contribute to.
> Werner
Re: Ideas from Grails dependency resolution [message #571382 is a reply to message #486586] Fri, 18 September 2009 14:08 Go to previous message
> different actions
cheers
--oh
Re: Ideas from Grails dependency resolution [message #571489 is a reply to message #486649] Fri, 18 September 2009 14:57 Go to previous message
>> different actions
> cheers
> --oh
Re: Ideas from Grails dependency resolution [message #571580 is a reply to message #486673] Fri, 18 September 2009 15:12 Go to previous message
contribute to.
--oh
Re: Ideas from Grails dependency resolution [message #603720 is a reply to message #486679] Wed, 14 April 2010 15:05 Go to previous message
to contribute to.
Werner
Re: Ideas from Grails dependency resolution [message #603729 is a reply to message #527252] Wed, 14 April 2010 20:59 Go to previous message
book.
- henrik
> Werner
Previous Topic:newversion of b3 book uploaded
Next Topic:b3 coding rules updated
Current Time: Sat Sep 23 09:18:48 GMT 2023
Powered by FUDForum. Page generated in 0.01937 seconds
