Home » Eclipse Projects » DSDP - Target Management » TCF Visual Studio build problems, cause: DIA SDK
TCF Visual Studio build problems, cause: DIA SDK [message #486549] |
Fri, 18 September 2009 07:33 |
Originally posted by: peter.nospam.tragardh.gmail.com
Hi!
I have a problem with DIA SDK when building TCF using Visual Studio. I
get the following error:
....\org.eclipse.tm.tcf.agent\symbols_win32.c(95) : error C2065:
'SymTagFunction' : undeclared identifier
I use 2005 standard edition, and have downgraded the solution and
project files from the distributed 2008, using the Source Forge project
VSPC (http://sourceforge.net/projects/vspc).
Looking at the documentation on MSDN for SymTagFunction, it should be
declared in cvconst.h, but that file doesn't exist on my machine. I have
vacuumed the net to find out how to get the SDK, but no luck. I read
somewhere that it’s supposed to get installed doing a full installation
of Visual Studio but didn’t work here.
So if anybody has any ideas on how to solve this, I would be so
grateful. I’m getting desperate. So… HELP! PLEASE! ;-)
/Peter
FW: TCF Visual Studio build problems, cause: DIA SDK [message #488348 is a reply to message #486549] |
Mon, 28 September 2009 11:09 |
Martin Oberhuber Messages: 1007 Registered: July 2009 |
Forwarding to the dsdp-tcf-dev@eclipse.org mailing list for
comments.
http://dev.eclipse.org/mhonarc/lists/dsdp-tcf-dev
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Peter Tragardh wrote:
> Hi!
> /Peter
FW: TCF Visual Studio build problems, cause: DIA SDK [message #488349 is a reply to message #486549] |
Mon, 28 September 2009 11:11 |
comments.
> Hi!
> /Peter
Re: FW: TCF Visual Studio build problems, cause: DIA SDK [message #490876 is a reply to message #488349] |
Mon, 12 October 2009 07:12 |
> comments.
> Cheers,
>> Hi!
>> project VSPC (http://sourceforge.net/projects/vspc).
>> have vacuumed the net to find out how to get the SDK, but no luck. I
>> read somewhere that it’s supposed to get installed doing a full
>> installation of Visual Studio but didn’t work here.
>> /Peter
I finally managed to convince my company to upgrade to Visual Studio
2008 and then the problem was gone. Never got it to work in 2005.
FW: TCF Visual Studio build problems, cause: DIA SDK [message #582639 is a reply to message #486549] |
comments.
> Hi!
> /Peter
FW: TCF Visual Studio build problems, cause: DIA SDK [message #582652 is a reply to message #486549] |
comments.
> Hi!
> /Peter
Re: FW: TCF Visual Studio build problems, cause: DIA SDK [message #582753 is a reply to message #488349] |
> comments.
> Cheers,
>> Hi!
>> /Peter
Current Time: Sat Apr 27 00:21:09 GMT 2024
Powered by FUDForum. Page generated in 0.02877 seconds
