Home » Modeling » EMF » EMF newbie question
EMF newbie question [message #486485] |
Thu, 17 September 2009 15:52  |
Originally posted by: mc5686.mclink.it
Hi Everybody,
I am a complete newbie to EMF and thus, please, bear with me :)
I am trying to setup my first (after tutorials) real EMF project.
I am using annotated java to define my model (as per tutorials, again).
My current problem is: how to fill-up references (contained="false") as
references to a "real" container (something similar to enums, but with a
List of real classes).
I have a series of Interfaces:
IProduct: name, description, price, ...
IOrder: reference to IProduct, quantity, deliveryDate, ...
ICustomer: name, address, ..., List<IOrder>
IFirm: name, address, ..., List<IProduct>, List<ICustomer>
I am simplifying, of course.
My problem is the "reference to IProduct" should not be owned by IOrder,
but a reference to some IProduct already defined and owned by IFirm.
This would be a FOREIGN KEY in SQL.
I would expect an editor showing a (dynamically filled) list (or combo)
but I have been unable to achieve this.
Can someone point me in the right direction?
Thanks in advance.
Re: EMF newbie question [message #486503 is a reply to message #486485] |
Thu, 17 September 2009 17:23   |
Mauro,
Comments below.
Mauro Condarelli wrote:
> Hi Everybody,
> as references to a "real" container (something similar to enums, but
> with a List of real classes).
> IOrder, but a reference to some IProduct already defined and owned by
> IFirm.
> combo) but I have been unable to achieve this.
Unless you add containment="true" you should end up with a
non-containment reference. Note that you can always create an Ecore
model and generate the code to see what @model annotations come out for
that. I'd also suggest you look at the nice EMF refcard.
http://refcardz.dzone.com/refcardz/essential-emf
> Thanks in advance.
Re: EMF newbie question [message #486553 is a reply to message #486503] |
Fri, 18 September 2009 04:10   |
Thanks.
I have evidently been unclear.
I already discovered the trick of leaving out the containment="true"
attribute.
Problem is:
If I do that the generated editor will create a temporary IProduct
instance and will refuse to save it (because it has to be contained
somewhere).
How do I convince EMF to generate an editor that will not generate a new
instance, but will allow me to select an existing IProduct contained in
another class (instance of IFirm)?
Can this be done?
I suppose the answer is "yes", because it looks like a very common
operation, but I found no references to it.
Thanks for the pointer. I'm printing it now :)
Mauro
Ed Merks wrote:
> Mauro,
> Comments below.
>> Hi Everybody,
>> IFirm.
>> Thanks in advance.
Re: EMF newbie question [message #486675 is a reply to message #486553] |
Fri, 18 September 2009 10:34   |
Mauro,
Comments below.
> Thanks.
> attribute.
> Problem is:
> somewhere).
That sounds like what would happen if you don't use containment="true"
> new instance, but will allow me to select an existing IProduct
> contained in another class (instance of IFirm)?
You have to make containment false and then you can choose from
instances contained already elsewhere in the model (or in another
resource you load into the editor).
> Can this be done?
The library example illustrates this where the books and writers are
contained by the library but can refer to each other.
> Regards
> Mauro
> Ed Merks wrote:
>> Mauro,
>> Comments below.
>>> Hi Everybody,
>>> by IFirm.
>> for that. I'd also suggest you look at the nice EMF refcard.
>>> Thanks in advance.
Re: EMF newbie question [message #486837 is a reply to message #486746] |
Sat, 19 September 2009 14:07   |
Mauro,
Comments below.
> I'm here again :blush:
> I managed to make this work.
> Next problem:
> I have a tree structure and each node has an EList holding some of
> the same kind of information (users, in this case). Here I have
> 'containment="true"'.
> The leafs do have an EList of references to users (containment="false").
> The generated editor shows, for the leafs, all users defined
> (contained) everywhere in the tree.
> I would like to restrict the possible choices to just the users
> contained in the nodes in the path that leads from the root to the
> leaf. I.E.: the leaf should have (an EList of references to) a subset
> of the users defined in the branch.
> How can I do this?
Specialize getChoiceOfValues for the property, e.g,
* This adds a property descriptor for the EType feature.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated NOT
protected void addETypePropertyDescriptor(Object object)
itemPropertyDescriptors.add
(new ItemPropertyDescriptorWithUniqueChoiceOfValueLabels
(((ComposeableAdapterFactory)adapterFactory).getRootAdapterF actory(),
getResourceLocator(),
getString("_UI_ETypedElement_eType_feature"),
getString("_UI_ETypedElement_eType_description"),
EcorePackage.Literals.ETYPED_ELEMENT__ETYPE,
true,
false,
true,
null,
null,
null)
public Collection<?> getChoiceOfValues(Object object)
> Other thing: how can I specify custom icons for the various node
> elements?
Replace the generated icons in the *.edit project with your own.
> Thanks a lot for Your patience
> Mauro
Re: EMF newbie question [message #487083 is a reply to message #486837] |
Mon, 21 September 2009 15:11   |
Sorry,
I feel very stupid.
This is one of my generated methods:
* This adds a property descriptor for the Name feature.
* @generated
protected void addNamePropertyDescriptor(Object object) {
(createItemPropertyDescriptor
getString("_UI_Character_name_feature"),
getString("_UI_PropertyDescriptor_description", "_UI_Character_name_feature", "_UI_Character_type"),
MCWritePackage.Literals.CHARACTER__NAME,
true,
false,
false,
ItemPropertyDescriptor.GENERIC_VALUE_IMAGE,
null,
null));
This resembles what You posted earlier, but not quite.
I tried changing this to:
itemPropertyDescriptors.add( new new ItemPropertyDescriptorWithUniqueChoiceOfValueLabels(
but it says new ItemPropertyDescriptorWithUniqueChoiceOfValueLabels is unresolved (also after Ctrl-O).
Where can I find documentation about this?
I searched the Help to no avail.
I will also check the hits I had on the the web, but some pointer from a knowledgeable person would be very welcome
TiA
Mauro
Re: EMF newbie question [message #487103 is a reply to message #487091] |
Mon, 21 September 2009 17:59   |
I'm getting mad
I managed to have the selection working, at least it displays in the selector the items I think it should.
So far, so good.
Problem is that the properties of my "leafs" do not refresh correctly
When I switch from one leaf to the other the lists remain the same, even if they are actually different (I checked the saved XML).
This is my tentative mcwrite.genmodel:<?xml version="1.0" encoding="UTF-8"?>
<genmodel:GenModel xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:genmodel="http://www.eclipse.org/emf/2002/GenModel" modelDirectory="/it.condarelli.emf.mcwrite/src"
modelPluginID="it.condarelli.emf.mcwrite" modelName="MCWrite" importerID="org.eclipse.emf.importer.ecore"
complianceLevel="6.0" copyrightFields="false">
<foreignModel>mcwrite.ecore</foreignModel>
<genPackages prefix="MCWrite" basePackage="it.condarelli.emf" disposableProviderFactory="true"
ecorePackage="mcwrite.ecore#/">
<genEnums typeSafeEnumCompatible="false" ecoreEnum="mcwrite.ecore#//CharacterType">
<genEnumLiterals ecoreEnumLiteral="mcwrite.ecore#//CharacterType/Unknown"/>
<genEnumLiterals ecoreEnumLiteral="mcwrite.ecore#//CharacterType/World"/>
<genEnumLiterals ecoreEnumLiteral="mcwrite.ecore#//CharacterType/Book"/>
<genEnumLiterals ecoreEnumLiteral="mcwrite.ecore#//CharacterType/Local"/>
</genEnums>
<genClasses ecoreClass="mcwrite.ecore#//World">
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute mcwrite.ecore#//World/name"/>
<genFeatures property="None" children="true" createChild="true" ecoreFeature="ecore:EReference mcwrite.ecore#//World/books"/>
<genFeatures property="None" children="true" createChild="true" ecoreFeature="ecore:EReference mcwrite.ecore#//World/characters"/>
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute mcwrite.ecore#//World/desc"/>
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute mcwrite.ecore#//World/content"/>
</genClasses>
<genClasses ecoreClass="mcwrite.ecore#//Book">
<genFeatures property="None" notify="false" createChild="false" ecoreFeature="ecore:EReference mcwrite.ecore#//Book/world"/>
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute mcwrite.ecore#//Book/title"/>
<genFeatures property="None" children="true" createChild="true" ecoreFeature="ecore:EReference mcwrite.ecore#//Book/characters"/>
<genFeatures property="None" children="true" createChild="true" ecoreFeature="ecore:EReference mcwrite.ecore#//Book/chapters"/>
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute mcwrite.ecore#//Book/desc"/>
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute mcwrite.ecore#//Book/content"/>
</genClasses>
<genClasses ecoreClass="mcwrite.ecore#//Chapter">
<genFeatures property="None" notify="false" createChild="false" ecoreFeature="ecore:EReference mcwrite.ecore#//Chapter/book"/>
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute mcwrite.ecore#//Chapter/title"/>
<genFeatures property="None" children="true" createChild="true" ecoreFeature="ecore:EReference mcwrite.ecore#//Chapter/characters"/>
<genFeatures property="None" children="true" createChild="true" ecoreFeature="ecore:EReference mcwrite.ecore#//Chapter/scenes"/>
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute mcwrite.ecore#//Chapter/desc"/>
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute mcwrite.ecore#//Chapter/content"/>
</genClasses>
<genClasses ecoreClass="mcwrite.ecore#//Scene">
<genFeatures property="None" notify="false" createChild="false" ecoreFeature="ecore:EReference mcwrite.ecore#//Scene/chapter"/>
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute mcwrite.ecore#//Scene/title"/>
<genFeatures notify="false" createChild="false" propertySortChoices="true" ecoreFeature="ecore:EReference mcwrite.ecore#//Scene/viewPoint"/>
<genFeatures notify="false" createChild="false" propertySortChoices="true" ecoreFeature="ecore:EReference mcwrite.ecore#//Scene/actors"/>
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute mcwrite.ecore#//Scene/desc"/>
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute mcwrite.ecore#//Scene/content"/>
</genClasses>
<genClasses ecoreClass="mcwrite.ecore#//Character">
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute mcwrite.ecore#//Character/name"/>
<genFeatures property="Readonly" createChild="false" ecoreFeature="ecore:EAttribute mcwrite.ecore#//Character/type"/>
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute mcwrite.ecore#//Character/alias"/>
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute mcwrite.ecore#//Character/desc"/>
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute mcwrite.ecore#//Character/bio"/>
</genClasses>
</genPackages>
</genmodel:GenModel>
Here is the code I modified in SceneItemProvider.java: private List<Character> getCharacters(Object o) {
List<Character> ret = new ArrayList<Character>();
if (o instanceof Scene) {
Scene s = (Scene) o;
o = s.getChapter();
if (o instanceof Chapter) {
Chapter c = (Chapter) o;
ret.addAll(c.getCharacters());
o = c.getBook();
if (o instanceof Book) {
Book b = (Book) o;
ret.addAll(b.getCharacters());
o = b.getWorld();
if (o instanceof World) {
World w = (World) o;
ret.addAll(w.getCharacters());
return ret;
* This adds a property descriptor for the View Point feature.
* @generated NOT
protected void addViewPointPropertyDescriptor(Object object) {
new ItemPropertyDescriptorDecorator(object,
createItemPropertyDescriptor(
((ComposeableAdapterFactory)adapterFactory).getRootAdapterFactory(),
getString("_UI_Scene_viewPoint_feature"),
getString("_UI_PropertyDescriptor_description", "_UI_Scene_viewPoint_feature", "_UI_Scene_type"),
MCWritePackage.Literals.SCENE__VIEW_POINT,
true,
false,
true,
null,
null,
null)) {
public Collection<?> getChoiceOfValues(Object thisObject) {
return getCharacters(thisObject);
/* generated (original)
(((ComposeableAdapterFactory)adapterFactory).getRootAdapterFactory(),
true,
false,
true,
null,
null,
null));
* This adds a property descriptor for the Actors feature.
* @generated NOT
protected void addActorsPropertyDescriptor(Object object) {
getString("_UI_Scene_actors_feature"),
getString("_UI_PropertyDescriptor_description", "_UI_Scene_actors_feature", "_UI_Scene_type"),
MCWritePackage.Literals.SCENE__ACTORS,
true,
false,
true,
null,
null,
null))
true,
false,
true,
null,
null,
null));
Please-please help me!
I am willing to send any piece of my code that could be useful to pinpoint the problem, of course!
TiA
Mauro
Re: EMF newbie question [message #487275 is a reply to message #487103] |
Tue, 22 September 2009 12:07   |
Mauro,
Comments below.
> I'm getting mad :?
Angry or crazy? :-P
> So far, so good.
> Problem is that the properties of my "leafs" do not refresh correctly :(
I'm not sure I follow. Is the property descriptor's getChoiceOfValues
being called each time?
> encoding="UTF-8"?>
> <genEnumLiterals
> <genEnumLiterals
> <genEnumLiterals
> <genEnumLiterals
> </genEnums>
> </genClasses>
> </genClasses>
> </genClasses>
> </genClasses>
> </genClasses>
> </genPackages>
> o = s.getChapter();
> o = c.getBook();
> Book b = (Book) o;
> o = b.getWorld();
> return ret;
> * @generated NOT
> ((ComposeableAdapterFactory)adapterFactory).getRootAdapterFa ctory(),
> true,
> false,
> true,
> null,
> null,
> null)) {
> @Override
> thisObject) {
> true,
> false,
> true,
> null,
> null,
> null));
> * @generated NOT
> true,
> false,
> true,
> null,
> null,
> null))
> @Override
> thisObject) {
> true,
> false,
> true,
> null,
> null,
> null));
I assume you've set a breakpoint in the getChoiceOfValues method to
track when it's being called?
It looks okay. The debugger will probably help better than me.
> TiA
> Mauro
Re: EMF newbie question [message #487475 is a reply to message #487275] |
Wed, 23 September 2009 07:44   |
Quote: | Mauro Condarelli wrote:
> I'm getting mad
Angry or crazy?
| I'm just at Witt's end
Quote: | > Problem is that the properties of my "leafs" do not refresh correctly
| My command of English language is evidently lacking... which is not unlikely, since I'm Italian
What I tried to say is:
- I am using (for testing) the generated editor, no modifications.
- I have a small test tree I can upload, if useful.
- The "leafs" (Scene) have references (List<Character> Actors; Character Viewpoint;) declared with contained="false".
- The "nodes" (World, Book, Chapter) have a list of Characters (List<Character> Characters;) declared with contained="true".
- In the "leaf" I can open the generated dialog to chose the character for the references.
- In this case the getChoiceOfValues() *is* called and I can chose only the characters in teh currently active branch (this is correct).
- The saved .XML reflects the various choices (this is correct).
- If I switch from one leaf to another I see in the editor the same values that are present in the previous chosen leaf; this is *not* a simple screen-refresh problem because it happens even if i do not go directly from one leaf to the other.
- If I open the editor dialog-box I see in the left pane the right choices (as computed using my custom getChoiceOfValues()), but in the right I find the (possibly incompatible) entries from the previous edit.
- It seems the data structures of the editor for the non-owned references are not reloaded from the model when I switch from one leaf to the other; is it possible?
I am unable to understand what's going on and, obviously, the debugger can't help me if I don't know where I should breakpoint. The "malfunctioning" software isn't something I wrote; It is either library or generated.
What could I have done to trigger this behavior?
TiA
Mauro
Re: EMF newbie question [message #487501 is a reply to message #487475] |
Wed, 23 September 2009 08:58   |
Mauro,
Comments below.
> Quote:
>> > I'm getting mad :?
>> Angry or crazy? :p
> I'm just at Witt's end :(
> Quote:
>> correctly :(
> unlikely, since I'm Italian :)
> Viewpoint;) declared with contained="false". The "nodes" (World, Book,
> for the references.
It doesn't sound possible no. Use the debugger to see how the
"currentValues" is passed to the constructor of FeatureEditorDialog.
The basic generated editors don't generally have the problem you describe...
> TiA
> Mauro
Re: EMF newbie question [solved] [message #488157 is a reply to message #487684] |
Fri, 25 September 2009 13:44   |
Thanks for the hints.
I managed to make the default editor work.
Problem was some misunderstanding about what to do.
I am still puzzled though:
This is the working code:
new ItemPropertyDescriptor(
McwritePackage.Literals.SCENE__ACTORS,
true,
false,
true,
null,
null,
null
return getActors(thisObject);
while this is the not working code:
object,
true,
false,
true,
null,
null,
null)
To my understanding (and perusal of code) they should be equivalent, but obviously aren't.
Can someone explain me what I'm not seeing?
Anyways, as said, it now works.
Many thanks for the (undeserved) help.
Best Regards
Mauro
Re: EMF newbie question [solved] [message #488162 is a reply to message #488157] |
Fri, 25 September 2009 13:51   |
Mauro,
The logic to add the property descriptors isn't called repeatedly, at
least by default, it's done once and cached for all objects of that
type. The second approach locks the descriptor onto the first object
for which descriptors are needed...
> true,
> false,
> true,
> null,
> null,
> null
> @Override
> thisObject) {
> object,
> true,
> false,
> true,
> null,
> null,
> null) ) {
> @Override
> thisObject) {
> Best Regards
> Mauro
Re: EMF newbie question [message #545648 is a reply to message #486746] |
Thu, 08 July 2010 09:53  |
See inline below. Can you be specific about which UI part you refer to ?
> Next problem:
> I have a tree structure and each node has an EList holding some of the
> The generated editor shows, for the leafs, all users defined (contained)
What do you mean by shows? Only the contained users would appear as a
branch on this tree. A non contained user will not be shown in the
outline, but would appear in the properties view and editable with a
feature selector dialog. Is this what you mean?
Which choices are you referring to?
> contained in the nodes in the path that leads from the root to the leaf.
> I.E.: the leaf should have (an EList of references to) a subset of the
> How can I do this?
> Other thing: how can I specify custom icons for the various node elements?
EMF by default produces icons for your model objects in you
..edit/icons/full/obj16 folder. Simply replace them and you will see a
different icon.
> Mauro
Current Time: Mon Sep 15 02:30:12 EDT 2025
Powered by FUDForum. Page generated in 0.11337 seconds
