Wiki management [message #486188] |
Wed, 16 September 2009 16:18 |
Originally posted by: mariaenrica.free.fr
I have installed an EPF WIKI and created new wikis and run some trials.
I have 2 questions:
1)Being the main administrator I should be in the right position to delete
Wikis (as explained in EPF Wiki User Guide pag.11), but I cannot find this
funtionality, is only possible to tag a wiki as "obsolete" but it is not
what I wouls like to do. Any suggestion ?
2) Is it possible to modify my password ? in the chapter User Management
pag 10 , this is not mentioned and this funtionality does not appear in
the Authentication window. Does anybody face the same issue ?
Thanks Enrica
Re: Wiki management [message #487215 is a reply to message #486188] |
Tue, 22 September 2009 13:28 |
Angelo Messages: 22 Registered: July 2009 |
to modify your password, you should have a link "I forgot my password)" in the Authentication window
It will send you an email to confirm the modification. yo(u have correctly configured your SMTP infos)
If you work on a test server, you have to update manually the users table
If you need, I can give you an example of update
[Updated on: Tue, 22 September 2009 13:36] Report message to a moderator
FUDForum. Page generated in 0.03955 seconds
