Re: key/keyref does not validate with recursion? [message #485376 is a reply to message #485361] |
Fri, 11 September 2009 14:15 |
Toan Messages: 36 Registered: July 2009 |
Member |
Hi Ed,
Ok, I'll search, thanks anyway.
Toan.
Ed Merks wrote:
> Toan,
> I don't know either, but I find Google searches quite effective. No
> doubt it's at Apache somewhere...
> Toan wrote:
>> Ed,
>> I'm sorry because I don't know the link of Xerces forum in order to
>> post this question. Can you please inform it to me? Thanks.
>> Toan.
>> Ed Merks wrote:
>>> Toan,
>>> It's probably better to ask this question on a Xerces forum because
>>> the XSD model doesn't provide support validation of XML instances
>>> only support for validating XSD instances themselves.
>>> Toan wrote:
>>>> Hi everyone,
>>>> Is it true that key/keyref does not validate with recursion? I have
>>>> this question because that when I validate the following xml file,
>>>> the validation of an element defined with recursion doesn't work.
>>>> Following is xml and the corresponding xsd file. Thanks in advance!
>>>> Toan.
>>>> xsd file :
>>>> <?xml version="1.0" encoding="ISO-8859-1"?>
>>>> <xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema">
>>>> <xsd:element name="CompositeType" type="CompositeType" />
>>>> <xsd:element name="Model" type="Model">
>>>> <!-- CompositeTypeKey/KeyRef -->
>>>> <xsd:key name="CompositeTypeKey">
>>>> <xsd:selector
>>>> xpath=".//CompositeType" />
>>>> <xsd:field xpath="./typeName" />
>>>> </xsd:key>
>>>> <xsd:keyref name="CompositeTypeRef" refer="CompositeTypeKey">
>>>> <xsd:selector
>>>> xpath=".//Attribute/CompositeTypeReference" />
>>>> <xsd:field xpath="." />
>>>> </xsd:keyref>
>>>> </xsd:element>
>>>> <xsd:complexType name="CompositeType">
>>>> <xsd:sequence>
>>>> <xsd:element minOccurs="0" name="typeName"
>>>> type="xsd:string" />
>>>> <xsd:element maxOccurs="unbounded" minOccurs="0"
>>>> name="Attribute" type="Attribute" />
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> <xsd:complexType name="Attribute">
>>>> <xsd:sequence>
>>>> <xsd:element minOccurs="0" name="name" type="xsd:string" />
>>>> <xsd:choice minOccurs="1">
>>>> <xsd:element minOccurs="1" maxOccurs="1"
>>>> name="CompositeTypeReference" type="xsd:string" />
>>>> </xsd:choice>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> <xsd:complexType name="Model">
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> </xsd:schema>
>>>> xml file :
>>>> <?xml version="1.0" encoding="ISO-8859-1" standalone="no"?>
>>>> <Model xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>>> xsi:noNamespaceSchemaLocation="test.xsd" >
>>>> <CompositeType>
>>>> <typeName>Bozo</typeName>
>>>> </CompositeType>
>>>> <CompositeType>
>>>> <typeName>MyData</typeName>
>>>> <Attribute>
>>>> <name>b</name>
>>>> <CompositeTypeReference>Bozo</CompositeTypeReference>
>>>> </Attribute>
>>>> <Attribute>
>>>> <name>d</name>
>>>> <CompositeType>
>>>> <typeName>CustomData</typeName>
>>>> </CompositeType>
>>>> </Attribute>
>>>> <Attribute>
>>>> <name>n</name>
>>>> <CompositeType>
>>>> <typeName>NewData</typeName>
>>>> <Attribute>
>>>> <name>m</name>
>>>> <CompositeTypeReference>My</CompositeTypeReference>
>>>> </Attribute>
>>>> <Attribute>
>>>> <name>c</name>
>>>> <CompositeTypeReference>Custom</CompositeTypeReference>
>>>> </Attribute>
>>>> </CompositeType>
>>>> </Attribute>
>>>> </CompositeType>
>>>> </Model>
>>>> Notice that when validate if the validation of recursion works,
>>>> there will be two errors at :
>>>> because the right references are :
>>>> <CompositeTypeReference>MyData</CompositeTypeReference>
>>>> <CompositeTypeReference>CustomData</CompositeTypeReference >
Re: key/keyref does not validate with recursion? [message #604359 is a reply to message #485136] |
Thu, 10 September 2009 15:37 |
Ed Merks Messages: 33142 Registered: July 2009 |
Toan,
It's probably better to ask this question on a Xerces forum because the
XSD model doesn't provide support validation of XML instances only
Toan wrote:
> Hi everyone,
> this question because that when I validate the following xml file, the
> Toan.
> xsd file :
> <xsd:selector
> </xsd:key>
> <xsd:selector
> </xsd:keyref>
> </xsd:element>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:choice>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> xml file :
> <CompositeType>
> </CompositeType>
> <CompositeType>
> <Attribute>
> <name>b</name>
> </Attribute>
> <Attribute>
> <name>d</name>
> <CompositeType>
> </CompositeType>
> </Attribute>
> <Attribute>
> <name>n</name>
> <CompositeType>
> <Attribute>
> <name>m</name>
> </Attribute>
> <Attribute>
> <name>c</name>
> </Attribute>
> </CompositeType>
> </Attribute>
> </CompositeType>
> </Model>
> Notice that when validate if the validation of recursion works, there
Ed Merks
Re: key/keyref does not validate with recursion? [message #604364 is a reply to message #485282] |
Fri, 11 September 2009 13:45 |
Toan,
Toan wrote:
> Ed,
> Toan.
> Ed Merks wrote:
>> Toan,
>> Toan wrote:
>>> Hi everyone,
>>> Toan.
>>> xsd file :
>>> <xsd:selector
>>> </xsd:key>
>>> <xsd:selector
>>> </xsd:keyref>
>>> </xsd:element>
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> <xsd:sequence>
>>> </xsd:choice>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> </xsd:schema>
>>> xml file :
>>> <CompositeType>
>>> </CompositeType>
>>> <CompositeType>
>>> <Attribute>
>>> <name>b</name>
>>> </Attribute>
>>> <Attribute>
>>> <name>d</name>
>>> <CompositeType>
>>> </CompositeType>
>>> </Attribute>
>>> <Attribute>
>>> <name>n</name>
>>> <CompositeType>
>>> <Attribute>
>>> <name>m</name>
>>> </Attribute>
>>> <Attribute>
>>> <name>c</name>
>>> </Attribute>
>>> </CompositeType>
>>> </Attribute>
>>> </CompositeType>
>>> </Model>
Ed Merks
Re: key/keyref does not validate with recursion? [message #604366 is a reply to message #485361] |
Member |
Hi Ed,
Toan.
Ed Merks wrote:
> Toan,
> Toan wrote:
>> Ed,
>> Toan.
>> Ed Merks wrote:
>>> Toan,
>>> Toan wrote:
>>>> Hi everyone,
>>>> Toan.
>>>> xsd file :
>>>> <xsd:selector
>>>> </xsd:key>
>>>> <xsd:selector
>>>> </xsd:keyref>
>>>> </xsd:element>
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> <xsd:sequence>
>>>> </xsd:choice>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> </xsd:schema>
>>>> xml file :
>>>> <CompositeType>
>>>> </CompositeType>
>>>> <CompositeType>
>>>> <Attribute>
>>>> <name>b</name>
>>>> </Attribute>
>>>> <Attribute>
>>>> <name>d</name>
>>>> <CompositeType>
>>>> </CompositeType>
>>>> </Attribute>
>>>> <Attribute>
>>>> <name>n</name>
>>>> <CompositeType>
>>>> <Attribute>
>>>> <name>m</name>
>>>> </Attribute>
>>>> <Attribute>
>>>> <name>c</name>
>>>> </Attribute>
>>>> </CompositeType>
>>>> </Attribute>
>>>> </CompositeType>
>>>> </Model>
FUDForum. Page generated in 0.04173 seconds
