Home » Eclipse Projects » Standard Widget Toolkit (SWT) » restrict Composite size
restrict Composite size [message #485073] Thu, 10 September 2009 09:29 Go to next message
HI All,
Is there any way to limit the Composite size?? I have a Parent composite
say "A", adding one more composite "B" to it....i add CheckBoxTableViewer
"ctv" to it,elements in ctv are added at run time from a property file it
has some 100 elements.The Problem is size of UI, due to large number of
elemnts in ctv it is expanding to full length making Dialog to expand from
top to bottom of screen and then adding scrollbar to it which is ok.
Due to some limitations i can't use shell.setSize(), only way for me is to
limit the size of composite "B" so that ctv does't expand beyond B's
height.
Re: restrict Composite size [message #485396 is a reply to message #485073] Fri, 11 September 2009 11:29 Go to previous message
A Table's preferred size (which is what pack() gives you) is to show all of
its items, so to keep it from doing this you have to set a size or size hint
on the Table or its parent. For example, if your Composite B uses a
GridLayout then you can give it width and height hints in its GridData, and
the Table will be sized to fit within it (and will show scrollbars if
needed).
Grant
"Rahul Yadav" <rahulyadav20@gmail.com> wrote in message
news:98d500bc346c39ef49c7200b185c8f08$1@www.eclipse.org...
> HI All,
> height.
Previous Topic:Is it possible to have a tree with only some items with checkboxes
Next Topic:Frequent update of image
Current Time: Thu Nov 06 19:49:27 EST 2025
Powered by FUDForum. Page generated in 0.03362 seconds
