Home » Archived » BIRT » Nested tables + truncated images + Word emitter
Nested tables + truncated images + Word emitter [message #485010] Thu, 10 September 2009 04:49 Go to next message
--------------000805040609040806030301
We have images contained in a table which is itself nested within
another table. When we output the report using the Word emitter the
images are truncated by the page break and sometimes by the right
margin. Please see the attached report "reportTest.doc" which contains
many examples. Note that this does not happen with the pdf emitter.
The attached small example report design and associated csv file
reproduces this behaviour. To use the design, please ensure the data
source location points to the someData.csv file.
We are using 2.3.2.r232_v20090211. Any help with solving this issue
would be much appreciated.
Kind Regards,
James
Content-Type: text/xml;
name="truncateImageTest.rptdesign"
Content-Disposition: inline;
filename="truncateImageTest.rptdesign"
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.3.2.r232_20090202 Build &lt;2.3.2.v20090218-0730></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<data-sources>
<oda-data-source extensionID="org.eclipse.datatools.connectivity.oda.flatfile " name="Data Source" id="43">
<property name="HOME">C:\Documents and Settings\jamesw\Desktop</property>
<property name="DELIMTYPE">COMMA</property>
<property name="CHARSET">UTF-8</property>
<property name="INCLCOLUMNNAME">NO</property>
<property name="INCLTYPELINE">NO</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.datatools.connectivity.oda.flatfile.dataSet " name="Data Set" id="44">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">COLUMN_1</property>
<property name="dataType">string</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">COLUMN_1</property>
<property name="nativeDataType">12</property>
</structure>
</list-property>
<property name="queryText">select "COLUMN_1" from someData.csv : {"COLUMN_1","COLUMN_1",STRING}</property>
<xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
<model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>COLUMN_1</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>-1</design:precision>
<design:scale>-1</design:scale>
<design:nullability>Unknown</design:nullability>
</design:attributes>
<design:usageHints>
<design:label>COLUMN_1</design:label>
<design:formattingHints/>
</design:usageHints>
</design:resultColumnDefinitions>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">"Verdana"</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="topMargin">0.25in</property>
<property name="leftMargin">0.25in</property>
<property name="bottomMargin">0.25in</property>
<property name="rightMargin">0.25in</property>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<grid name="aSection" id="10">
<property name="width">100%</property>
<column id="11"/>
<row id="12">
<cell id="13">
<table id="25">
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<expression name="expression">dataSetRow["COLUMN_1"]</expression>
</structure>
</list-property>
<column id="36"/>
<header>
<row id="26">
<cell id="27"/>
</row>
</header>
<detail>
<row id="999">
<cell id="991">
<label id="1000">
<property name="fontSize">16pt</property>
<property name="fontWeight">bold</property>
<text-property name="text">TITLE LEVEL 1</text-property>
</label>
</cell>
</row>
<row id="32">
<cell id="33">
<table id="1001">
<structure>
</structure>
</list-property>
<column id="1018"/>
<column id="1019"/>
<column id="1020"/>
<header>
<row id="1002">
<cell id="1003">
<property name="colSpan">3</property>
<property name="rowSpan">1</property>
</cell>
</row>
</header>
<detail>
<row id="1006">
<cell id="1007">
<label id="1022">
<property name="color">#800000</property>
<text-property name="text">TITLE LEVEL 2</text-property>
</label>
</cell>
</row>
<row id="1010">
<cell id="1011">
<image id="1024">
<property name="source">embed</property>
<property name="imageName">ABigImage.png</property>
</image>
</cell>
</row>
</detail>
<footer>
<row id="1014">
<cell id="1015">
</cell>
</row>
</footer>
</table>
</cell>
</row>
</detail>
<footer>
<row id="34">
<cell id="35"/>
</row>
</footer>
</table>
</cell>
</row>
</grid>
</body>
<list-property name="images">
<structure>
<property name="name">ABigImage.png</property>
<property name="data">
iVBORw0KGgoAAAANSUhEUgAAAlsAAAGpCAMAAACNqQPMAAAAAXNSR0IArs4c 6QAAAARnQU1BAACxjwv8
YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgAABdwnLpR PAAAAwBQTFRFAAAACAgI
EBAQGBgYICAgKCgoMDAwODg4QEBASEhIUFBQWFhYYGBgaGhocHBweHh4f39/ h4eHj4+Pl5eXn5+fp6en
r6+vt7e3v7+/x8fHz8/P19fX39/f5+fn7+/v9/f3////AAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAm5/7 QgAAABh0RVh0U29mdHdh
cmUAUGFpbnQuTkVUIHYzLjM2qefiJQAARDRJREFUeF7tnYl26jgMhlm60Raa FkopZXv/pxyHEOuXLdnO
wtwE0nPmnDstJLb8WZZkyR6dhp9BAteRwOg0Gn4GCVxHAgNb15Hr8NRRrreu oxGHp963BMzkGti6bwSu
1vuBrauJ9u4fPLB19whcTQADW1cT7d0/eGDr7hG4mgAGtq4m2rt/8MDW3SNw NQEMbF1NtHf/4IGtu0fg
agIY2LqaaO/+wQNbd4/A1QQwsHU10d79gwe27h6BqwlgYOtqor37Bw9s3T0C VxPAwNbVRHv3Dx7YunsE
riaAga2rifbuHzywdfcIXE0AA1tXE+3dP3hg6+4RuJoABrauJtq7f/DA1t0j cDUBDGxdTbR3/+CBrbtH
4GoCGNi6mmjv/sEDW3ePwNUEMLB1NdHe/YMHtu4egasJIJmt9Qv9bNtpzsI+ sc7zfuy3V3W+XvM7e/vW
Rc0n3M/Xktl6MZ8sf1oSKz2yjrxXtjlZna/X/M7OvvWl5hPu52upbJFMzTfG x1YENLDVihg7+5BUtjJQ
W6PRspX+DGy1IsbOPiSVrSlj66mV/gxstSLGzj4kka0fhtZo9NtGhwa22pBi d5+RyNabw9Z7Gz0a2GpD
it19Rhpb+7HD1njfQpcGtloQYocfkcbWV4mWZeyrhT4NbLUgxA4/Io2tpwtb 4/cSsscW+jSw1YIQO/yI
JLa2JVFPZNP/NO/UwFZzGXb5CUlsLWxA/mgXxdfmvWrG1rDn03wErvuEFLaO k5Kt9ck6jC1Y883Yuq5c
hqc3l0AKW9/WSTyc6N9Z45cPbDUWYacfkMLWDAx4WhSnjfs1sNVYhJ1+QAJb tE2dR0wpirpu2rGBraYS
7Pb3E9iibeo8UYoWxVnTng1sNZVgt7+fwNaDDZweTF9oURztGnZtYKuhADv+ 9ThbG2vJF4qKFsWmKYID
Wx2Ho2Hz4mwRS0XuMC2K04YpggNbDQev41+PsnWgbep8SWSL4nezzg1sNZNf 178dZWtpl8QyQXxuf/Pc
rHcSW/tlNs/LHRbZsqWKj8Mmm50LKLJsXcyO/+9nt/k8v3yerTbKu3+/iw6/ VmrdYbPMsveiLiTLsu9K
aSn7n+z8xVmW/dRaen7Ny89PWGRZIJMvyla5TU2JzL+Ub9Ns+D22jt+vmMvz sAg9f2tkWvxsdFj2X48s
O+h1VQpzV367WkbHwb7VqS6yz6PWfNvAYN6Gydz3fXaf1lHKP/L8lTLUh/WC BsWGHueJfO0y9srxm118
rECDdVP71Zvdpjm/fPL+rUybGFt2m3o0snODhquZNe+y9elmiY1GD58qNwl1 Pls3pdH0djwvJGFdlIdK
akyt87HPy4rn7T94Gng+DDO+wf/D2DsP1DSLqdaVz1XJ12t8qm/8V44mHwXR VqCBCqZfLPeiWfsu6s0Y
W3abekThrE/70GYFP5ytv2emYeyE1LRSlK09Ld7sydPzCF+ZrR8+ucsGXMA7 260kWmze41+I9RVTOp7A
ZgEVbh67Y8sCffvxvLDF2dK+b2asNCcibB1p8pHhvqdWNSr4YWx9+Urr8po3 2ZiIsbWRRzd/6KtRDldl
6/ghzhPzS6vpd/JUMmuMvt+xDpOVv1PX88bDV0U8mhvVFWPrsNC/bzSuv5JG 2FpbGU3AFCDF2qjgB9nK
tMHIV3RR10fYsqmy0oOfDldlS+XGtOVSabDWyR9pyofWi4Cw5qrak/Xk5VGz Y4ytnb4YF8/wDKQIW0QR
tplCXI0KfoCtEFoKXGG2bIKsPAxPhyvqrWNwFM6axa2b4ou2rKhVXci7qMB1 FCwt/OLsGNZbW998dEX7
6ngiYbZg9UNfkxK6ymlYyR4uP0xshdGS4QqyFZyjuUyerEZu35ZXrJrLUOSJ b38BrZWv2ZI4I7OFBlpW
e+FGmW/PbLRJsuXXofWwfPczd0TCbJEW5vnxZCU3SREUfY5HE3QxwRvHw5v4 /nuILWf1mM6zz81XtkBz
xY5u62wx/TI1USDHSlqcDvib55cXHicxQyIYAc70ezDBqdUmj3K9ukbYoxTI cPyah0X2ZWJvc1RGViIC
W2QbFRw9f2TrzdpEubjuemavDrNFzeY2IoS4qoWH2IT02RovrJd0WDKZ+UkX AbageaZ/b+T5bwTXsW22
aEGcfl6U/d8njuF4azv++HmhaMcjFv66xqr4Hr7YVNvzKJl0ogJYMUYic1qE 1kKYxmdrx/TsE8Sg90tm
ADCbK8gWbVNTcKugg2Zag4Ifj60Z87+5s+XtL+lsHZHKR75E+JGOttmyCwQ6 TgccwnKgHlifUDH5qwEs
aRNhOq9w8H029vjnZ64Vfz2t6X8fR4q3Oo9d4MRBJzfIFi3xrtqARad+wY/L lhfQ+AWRTF0DV2cLja13
b4Fwva0rseWqHt9cenOatgKTxnXoQRPLXvMehen5AmhsfbjGnBdo89hC7F/8 4O4B3AQ0XkJswTa1qzXA
yK9f8OOwJWw1bAEu95gAlS1cPqSNA/riWcVchy0/zuQ6j772gbCJ224Kho2V DbwDqB93ksLmykiyYRxb
zmULli8/0HAOAwNcsMccYou2qTG4VWBPT6tvzTO2xuIu1pbmsvselS1Yfrw5 yjc3rseWEFN2zGGJesLP
iRvC6WcQ2ecKCAB6c1QThGnlYDeHy2ULyEkIcNCKG2KLmuQ/EiSl9jYWmGBs yRiciO+R8x6NLZCxlqfB
PLlr6C1Rl7MAEfeoLpIioTqbaaTRAhUwtPA5ZMJYudSVQ8QseoctEOiLtpd+ JK1JfQ+w9Uf+pa+HYTOo
dsEPsiU6znnP6UNOKqLGFs3BsbY1B5K4zpoobiQwH1X8hJovTkIIuOU0DZ3p QqaeZ7SWbO0RfIct4m6q
b6SDQWitvQBbZBJLviAYzHULfpAtNQ1oR6sif4/GFs0gfW8NDZAr6C155cBF Udkro5WCebdk3frGCS0O
1KkJWzEg0q0nc2LjOFtgvobiTaQ17WqvswWaSRokGJ66BT/AVsAhoGnD+6yw RabJOJCuAo7TFdiSi1TA
/xkpg0wahnnf1NXguWe0zjC2yBQPrTDganA5kxIJ5rATD3Y919kCksX9LWhM zYIfYCug+qAdbLVX2CLT
JDQO8ND22dI28MHpVewWWs+ZZ3M0IfD3l3zZCmaR07rG2CI4QpYxOKmcLQoW hg1rGs1S5+ps0dSW9VLA
Y44Z8Ze/gykV+AboT7ZQKGzRQ4PnZpLE2mdLy5ikd2r0kUxlr3kTzEul5zNx 0q9Dmc9g6zG2DqQNg5ll
J5oXJYMqW6DB5ckC63DNgh/CQHESCxGRDcwmjswWxeTCLgZJon22NOVC1pSm UqlPde5jkNkilyxc3kDr
MWOLNHxkB4aW3lIXqWxR+FqzH8FmqVfwQ2wFY/skcKZAZbbot+GYLomsfba0 1GLqr5ZSeQ22aBaFM9BJ
ZzK2aEUNKgATQLUKrnQlVLbI3dKyzcBmqVfwQ7IOJokr/o/MFim5sChILbfP lrbAU3+1udiIrZ1sb1Hk
M5wkTFEExlZ8QpTdJWIuk0tjC+IVmt0ChpCUFBI3umyzw8MLlgBqBJktUqaR yIgdiNbZUhdj39p1ZVSb
rcPPArec8bnkc4VLNUjvIFsg/HAuPm7VXCDW2KLVV19mIcRVq+DHyjqyJUnS we7JbJFNE7Y8TxbC1tlS
BRZ3M+qwddh8vbupDMgWabNIgZoVM7IFu02xaIDnjypsAa5JEchaBT9W1pFd I4pw4Vois0X2bKQYyy6e
rbOllmARW9owVWPLRCbmL2IGK7LlmUHagmIXT+wA7lOTxxj510XTKGxBrsDc Vnt6/4CkkDoFP6lskQ5F
70lmi5oUWZOtidtDtn7X2dtLKMkY+p5uWFoxI1vBxH4NsYsbrLClFTipwNYp +LFsRRxuOQghskXRGL7v
4YNm/eDW2VJX+Fb01vciYWygu+QJxYbIihnZAiWTrLbKfH+ZLdimTn1ijRt+ UtkiLxp9P5EtangMGfv1
2Ac5lvG6ar08pTlbv/NwEUc5WNBmUjzqWn35tBUzfjBYiqexcXmAzFZiuRI+ u8YNP1bWEQ+E2MKXiGyR
eRBDpodsUZ59bMIDWySmWmyR7GPvhL9fNKTMVrwWzXtTjRTB6mxhqO3e2NKO IChHYgI6rT22lHMPwqBd
5rXIllsxlIRs9YIfy1Yk5Z7mDjqUIlsUlovZW33TW1vygIXheJibcJ6450MV PjF7S1wTk6sisVEhtqJ1
khJs1Qt+Uu0tCpxgPERkC8Ix/8xPVK2DJvaWcnZJPhBP78silieylW4liH5i rTUxwJZ3o12S3hpVLvhJ
ZatCDAJ27SORQiu0mGHWCVteDgVMXz6WYKuKbJGfGMsPFtmibeXq4XFpTazl GyiV5iHtkcpWldgpTYNI
GNlKsg9ssZTjvIuTF1NV7cpWZCtdk9vhkGMQ1eu5JLZoB2G6if2gR1npYEQj mNTYqbwPJ8dOyQuJqFEb
he4DW7z4+fWyBrpsUXwCRoK2CUeRXTA77MhWurnmaxGBLdimjqRVmMdBDaNb iBPdrLbMROIXxAsG0WS2
iMOIb3G9ver27S3mWynHkRlpyzqbtFl4917eqyZzLeYcJbEFbmf8kMMTOBJV UwRFJew3kXYt2K6lzBbZ
/fpBVPkryDDrgd6iCTMa64CAhkJ7gByz0LlvpxMZZqi3QNHETsv0Rs7XW7BN HfNa86fhZmbFgp/EHBua
tSz6J7NFHw43nozj7rOFuySBlV5JWSDrOWwx+Qdy58MLNFQc3bMeNf8hcrCD FAb98iWIu1Qs+KHpGJwS
5AYzV0VmC8p8go4i+T/dZwtymUIjArMc9VZqEIKWKyU3sLKj6LMFCjjJOMez OyLWoqM16U3BKaF8TGYL
gjzBHXDKCes+W+RbBTc/wL1HthKz+yDTk7FFMzsmKM8x99gCzRrbgCpQwbK7 amgTNCFjHhrE1JvCllbO
yLkGMyImsn8f36JsmqANCZYvG+Z4CUjeRTihi427og19s9jAOTE3MCw3VsF4 bEFQIbHWBKL41ax5Yis0
vtQgbkEpbKXJAvyVzrOVeCw2ppgztkhQoQxOOFCEsQVqL6w5wJnVcprJ4U/N JUUPORHHgnpYfQOLIjWI
GxsKWyda7XRtCAcBtH9GUtsxCNCxoYQRHAbGFkCXqXEhPGqRr1c0SuF0BKiF vthSrt6CzQXtzBO3fThh
KhX8AFu6U0fui9M1jS0wO1SnCt7cfbZAEwemIDs/hTNIvsBYCyqxb3O2gNmQ 4oKPld932YIFLnl/EM/p
S4iIWTZxhDWFBxrGMTY0tkCJa+euwMFLVzjH5op6S9c7J3YyNWcLLNYnxXlm CXucLVQdAb0JaqvMb3fY
wmJpVX+6f8D4Szhiyb+JbGnnGcFnHGw1tk4gJ3Miv/Dzw1LNO29vARp6kAfD jCP39gPYMpLB55nLjg8H
C4F6xtIJPmTXF4eteoc8QAZ3qpHm2FujkXwAF6R4uHJV2cKjdCW4OFrdXxNh L0c9IunAszmdJQeP0pXg
4miNHLaYzaPoPUTbmsUOW6DZKqxuuMZUSBFEvWWO6haajdlDbkK+yha7dOLF C7nhkbX5Dlzn9Rb6PIoN
/OskDroWBg7Qqxe1dE8XdmNPuGA+iTFPPJeWYgWcLThUq0qqH5g4o5R9oss6 xdkaPXvNxk55pobOFlyp
bW7Iutzgdnnn1quS6T5bmPMkTt2lW0/mWa/Y6wn3tzfRM8CP+O0HQeewa7mo hZwtCPsk7feUxgxmvqYX
/Dhsjaa82ewoeP980ABb7Dj10XRemqD7pZBR2322wOAajf2jJPb+9QPe4MGZ xLmqtpee7r7cQTB/9mLm
/OqChbNDt2VChSNRGVtweuEoVqHNbGSMjqSGLlh865IeMiPJbec4GcfV7lxx TCpzR0h+A65cYdJ9tpge
Hj1zZ41fLnuRo+9ROSaVASj/kSvS/P0YXkAx+QAlwMkaobXP2NLi/nGPEfRq esEP5dhQ5tF0Zi6aWfOr
d8xfhYNfAnrL3PMVudporB48G+nrP6lPdJLMXz8358Xhd/PF6hUptC5kPHhw kczP/5ooZyQV8nDv3nqY
m82dTbZwryJip98ztkA/Vgqwn05oDiZb8/Z1q9i1YVJrgmxF4Br/ECNVDEtz daodEmd2k6fUdnzLDG3S
zYmfdBOOlMcXhmuypQ5IkY60WjJ+SQCyBet66BxaaWbjzEpeZIgtuArBmU75 /47FKG6YrSBc5oEqI13U
WyfMwBQElP9qalQZGV6Skx+Cy1zkEpkcKUUUEz5QyBZ4/OlG02Us0J5LDegD W6HrLCdyNDjC1mmnXkb5
ZIahZ2zFbtYczXIDm8ZfXDt8H7nkNI/UxBRvoIrt8hj3piFkC4IkqXjYWY7W XmpFCLB1Oqg1kc9KUliM
LXNBlmiqjs9OVM/YOh2DRajTgiVyqZRI0Kdohk7OJkeMrVPsyIB3N4YEbME2 dbVcmbxlGLx1L8TTlhlk
y0w6sd/CFduXx8XZOh0+vNjN+FLK0De2tJlyXg6/yrAzdVfZ+dvPnSirMeLn RUwhytbptIbQurs0T311
BGxBmKRajt+5acE4p0wXZ+u0FVruxlLgQQlsmU//fcJTx2/f5SjQFK92SMq/ seXP3d7Lh9gQWWjz62vH
Fifc5N2mVlCQINNtzm8PzYKx55WwqwJsfdLZbdVyk89N2cHJb4kHva3Kr5SW 59+ChaBeV6E8+q19YeQY
nNPf5sd8drVBA5dmabxODkV9sG91fFfqv5oIY/ubaf2iPok7boelG+mclRfH Fm3c0yAEqwW2+X3A2Tel
iJrv0lwNDt/f18xdYJ4/5GAoi0HovP5vf/n9NEfimR/DQuWapSqNJPswOWRS 5fHX++zvV3YOe76Y8xx/
IucSVGoFOQLRgp58qhaNMNFIfR+ma2xVEkeDD9MsrRjJa/DObn+VogSxdSC1 H/fKVvuSTJV4Vz9Hjmil
7b5Ad+6VLXJc2pJkV5lJbZdNdqiSghd8+M2xtTMmaoIZYr316sccpA5WVz63 zdYJqxzlKVTIkgp38ebY
OjuA45e37DvoZNrwTMVa8K4AU6EdZ9Ny8vKerUNzjpybKmnp96W3KL0xlIFG uwDVQhAVhrQzHyVqQld6
URgwMYIU79/N6a2kgDtsrUcd7rgMO/6JhIA7nmJT724mSQY3xxZUIeuLIuX0 hC6A7jgzqc1LOl+YFHm1
nKNQI26OLUpiGqmRK8gcrLbjkzqcnfocZBOrNj3k32StNf722KKNzYmydbWB TYsED6o1Wf+rB1G85UE5
mQgSjqsls9+XLY+HzT2IqyIWPKUd1fOvoGjpvaCU/JKW/B2YAd6iIr89vYXZ Po+Cpb6ErC71fISWRrUb
j8GkYKeSI2/gEbO6JklnrqX16/bYgg1907mHJQvqHFYskef2AxBnCmiDy0jk iZuh+yVLm2ktAGFee4Ns
YR1ynjlncio2m9N+s1l9OCkqtx83LRQMO6XGzLdZllcK7TabpXthXmtx0/y1 t8jWX6SArIzJy+ZYmr7v
16f4SSR2T8L7h2yO1e3rLbIVrU4sZCofbVBXkN3+Xqw6sZDIuaCjvZ+bZOv0 m3CFZcuCbG9IrvKkdYIu
f0/Y46/SuNtk67T1ijAc/V9U+9zRzyZ2J2ZR7dPmz42yZcqGgqprdn9ZW8cs qLq8CrDmlN0sW6c9L+xA
vfVW4Wyx5iLuzBN279p8G79fY67dLltmSNdvwlR9/rqGHDsDULAhx2+pxHi2 bDFgCu+/abZMP7crOGvl
6TVbt+sK9QMp1srf5fzFhkuf39otFmJvunW2ejj4N9Pkga2bGcrOdWRgq3ND cjMNGti6maHsXEcGtjo3
JDfToIGtmxnKznVkYKtzQ3IzDRrYupmh7FxHBrY6NyQ306CBrZsZys51ZGCr c0NyMw0a2LqZoexcRwa2
OjckN9Ogga2bGcrOdWRgq3NDcjMNGti6maHsXEcGtjo3JDfToIGtmxnKznVk YKtzQ3IzDRrYupmh7FxH
BrY6NyQ306CBrZsZys51pAJb6+J6oPNPS8WjC/vAOoL5sd9uvdw80Jy9fWuN mwDrdLO336nAFh5e1ZJY
6ZF1BJh2g2KdJ4e+k3TIeNsv7eXz0tmCm9LNxRPtHHkysNVLaBIbnc5Whicq jNo5u3BgK3GYevmxdLb4
GTvtXCg0sNVLaBIbncwW3JR+VmD6dZ+Jb84/NrBVQVi9+2gyW3BT+pmtVs4h H9jqHTAVGpzKFp5RfmZr
3Ma5OgNbFYaqdx9NZcvelG1PtGrjDvGBrd4BU6HBqWyVR/6P7bXGbdxXNbBV Yah699FEtuyNl09k0/80
7+zAVnMZdvcJiWzZCwcXR7sovjbvVTO2hj2f5iNwzSeksUVX8K1P1mFswZpv xtY15TI8u7kE0tii+/UO
J/p31vj1A1uNRdjhB6SxNSv3e4wBT4vitHG/BrYai7DDD0hii7ap84gpRVEb 3yM+sNVhNBo3LYkt2qbO
E6VoUWx8R9zAVuMB7PADktiyx5GP89PZaVFsfLfxwFaH0WjctBS26Pa9QlHR otg0RXBgq/EAdvgBKWwR
S0XuMC2K04YpggNbHUajcdMS2DrQpTjFhSWwKH43a8DAVjP5dfvbCWwtbcLp y6Uvc/ub52a9k9jaL7N5
Xu6wyJYtVXwcNtnsXECR/f/X+ew2n+eXz7PVRrlK6Pe76HC1y4YOm2WWvRd1 IVmWfVdKS9n/ZOcvzrKa
1/n8mpefn7DIMjWTL4Etupm+TGT+tWyNmg2/x5ZzUdbDIvT8rZFp8bPREd9/ 8Ws6X1flOr4rv10to+Ng
3+pUF9nnUWu+bWAwl9hk7t+Atvtk19w/f6VYGYf1ggbFhh7niXztMvbK8Ztd fKxAg3VT+9Ubvytv8v4t
Tps4W3abejSyc4OGq5k177L16d9J96Bf0JpQ57N1UxrzzLN5IQnrojxUUr5q nY99XlY8b//hX7U64xv8
P4y9MyXTLHZT2srnquTrNT7VN/4rR5OPgmgr0HKBEgTzi+VepGOkqz3jbNlt 6hGFsz7tQ5sV/HC2/p6p
rfCvR00rRdna0+LNnjw9j/CV2fqRL8K8gHe2W0m02LzHvxDrK6Z0PIHNAirc PHYn3Z9oHvJ4XtjibGnf
NzPWnxNRto40+chw31OfGhX8MLa+1Dtv32RjIsbWRr9W+NUoh6uydfwQ54n5 pdX0O3kqmbVT3+9Yh8nK
3xm6iPtbv1Z4blRXjK3DInQt8dRdSaNsra2MJmAKkGJtVPCDbGXaYOSWiqjr I2zZVFnpwU+Hq7KlcmPa
cqk0WAcu1NaUD60XAWHNVbUn68nLo2bHGFs7fTEunuEYSFG2iCJsM4W4GhX8 AFshtBS4wmzZBFl5GJ4O
V9Rbx+AonDWLWzfFF21ZUau6kHdRgesoWFr4xdkxrLe2vvnoivaVeSIxtmD1 Q1+TEroaFfwQW2G0ZLiC
bAXnaC6TJ6uR27flFavmMhR54ttfQGuZj4l5l5HZQgMtq71wo8y3ZzbaJNny 69B6WL77GR2RGFukhXl+
PFnJTVIERZ/j0QRdTPDG8fAmvv8eYstZPabz7HPzlS3QXLGj2zpbTL9MTRTI sZIWpwP+5vnlhcdJzKAI
RoAz/R5McGq1yaNcr64R9igFMhy/5mGRfZnY2xyVkZWIwBbZRgVHzx/ZerM2 US6uu57h1TG2qNncRoQQ
V7XwEDMGfLbGC+slHZZMZn7SRYAtaJ7p4Rt5/hvBdWybLVoQp58XZf/3iWM4 3tqOP35eKNrxiIW/rrEq
vocvNtX2PEomnagAVoyRyJwWobUQpvHZ2jE9+wRXyu+XzAAAmyvCFm1TU3Cr oINmWoOCH4+tGfO/ubPl
7S/pbB2RSieG4Uc62mbLLhDoOB1wCMuBemB9QsXkrwawpE2E6bzCwffZ2OOf n7lW/PW0pv99HCne6jx2
gROHnNwIW7TEu2oDFp36BT8uW15A4xdEMnUNXJ0tNLbevQXC9bauxJarenxz 6c1p2gpMGtehB00se817
FKbnC6Cx9eE6kl6gzWMLsX/xg7sHcBPIeAmzBdvUrtYAI79+wY/DlrDVsAW4 3GMCVLZw+ZA2DuiLZxVz
Hbb8OJPrPPraB8ImbrspGDZWNvAOoH7cSQqbKyPJhnFsOZctWL7cQEPBKfqg do85zBZtU2Nwq3gcoVrf
mmdsjcVdrC3NZfc9Kluw/HhzlG9uXI8tIabsmMMS9YSfEzeE088gss8VEAD0 5qgmCNPKwW4Ol8sWqKWE
AEe54obZoib5jwRJqb0NbV7kf2NsyRiciO+R8x6NLZCxlqfBPLlr6C1Rl7MA EXpUVk4kVGczjTRaoAKG
Fj6HTBgrl7ry1cyid9gCgb5oe+lH0ppl34Ns/ZF/6eth2AyqXfCDbImOMwfQ SUXU2KI5ONa25kAS11kT
xY0E5qOKn1DzxUlSAbecpqEzXcjU84zWkq09gu+wRdxN9Y10MAgv1l6QLTKJ JV8QDOa6BT/IlpoGtKNV
kb9HY4tmkL63hgbIFfSWvHLgoqjsldFKwQKgZN36xgktDtSpCVsxINKtJ3Ni 4zhbYL6G4k2kNS+rfYgt
0EzSIMHw1C34AbYCDgFNG95nhS0yTc6lI8oPOE5XYMsP9ObNAP9npAwyaRjm fVNXg+ee0TrDek2meGiF
AVeDy5mUSDCHnXi4rOchtoBkcX8LGiPLMmZuob0VUH3QDrbaK2yRaRIaB3ho +2xpG/jg9Cp2C63nzLM5
mhD4+0u+bAWzyGldY6InOEKWMTipnC0KFoYNa9IUhc4NsUVTW9ZLAY85SlXx AWpNaEKB/mQLhcIWPTR4
biZJrH22tIxJeqdGH8lU9po3wbxUej4bAPp1KPMZbD3G1oG0YTCz7ETzomAw wBZocHmywDpcs+CHMFCc
xEJEZAOziSOzRTG5sItBkmifLU25kDWlqVTqU537GGS2yCULlzfQeszYIg0f 2YGhpbfQRQG2KHyt2Y9g
s9Qr+CG2grF9EjhToDJb9NtwTJdE1j5bWmox9VdLqbwGWzSLwhnopDMZW7Si BhWACaBaBVe4EgG2yN3S
ss3AZqlX8EOyDiaJK/6PzBYpubAoSC23z5ZmElB/tbnYiK2dbG9R5DOcJExR BMZWfEKU3SVizpNLZwvi
FZrdAoZQvYIf2+zw8IIlgBpBZouUaSQyYgeidbbUxdi1dn0Ga7N1+FngljM+ mXyucKkG6R1kC4QfzsXH
rZozxDpbtPrqyyyEuGoV/FhZR7YkSTrYPZktsmnClufJQtg6W6rA4m5GHbYO m693N5UB2SJtFilQs2JG
tmC3KRYNcPxRlS3ANSkCWavgx8qa2ej+bKYIF64lMltkz0aKsezi2TpbagkW saUNUzW2TGRi/iJmsKIM
HTNIW7BB72AHcJ+aPMbIv86aRmULcgXmttrT+wckhdQp+Elli3Qoek8yW9Qk XYjnv1gTt4ds/a6zt5dQ
kjH0Pd2wtGJGtoKJ/RpiZzdYZUsrcFKBrVPwY9mKONxyEEJki6IxfN/DB836 wa2zpa7wreit70XC2EB3
yROKDZEVM7IFSiZZbRX5/hpbsE2d+sQaN/ykskVeNPp+IlvU8Bgy9uuxD3Is 43XVenlKc7Z+5+EijnKw
oM2keNS1+vJpK2b8YLAUT2Pj/ACNrcRyJXx2jRt+rKwjHgixhS8R2SLzIIZM D9miPPvYhAe2SEy12CLZ
x94Jfz9rSI2teC2a96YaKYLV2cJQ272xpR1BUI7EBHRae2wp5x6EQTvPa4Ut t2IoCdnqBT+WrUjKPc0d
dChFtigsF7O3+qa3tuQBC8PxMDfhPHHPhyp8YvaWuCYmV0Vio0JsReskJdiq F/yk2lsUOMF4iMgWhGP+
mZ+oWgdN7C3l7JJ8IJ7el0UsT2Qr3UoQ/cRaa2KALe9GuyS9Napc8JPKVoUY BOzaRyKFVmgxw6wTtrwc
Cpi+fCzBVhXZIj8xlh8sskXbylXD4/KaWMs3UCrNQ9ojla0qsVOaBpEwspVk H9hiKcd5Fycvpqrala3I
Vromt8MhxyCq1nPJbNEOwnQT+0GPstLBiEYwqbFTeR9Ojp2SFxJRo3YLtw9s 8eLn18sa6LJF8QkYCdom
HEV2weywI1vp5prbGpEt2KaOpFWYx0ENo1uIEzF4gK1I/IJ4wSCazBZxGPEt rrdX3b69xXwr5TiywjO7
/KDOJm0W3r2X96rJXIs5R0lsgdsZP+TwBI5E1RRBUQn7RNKuBdu1lNkiu18/ iCp/BRlmPdBbNGFGYx0Q
0FDIFjlmoXPfTicyzFBvgaKJnZbpjJykt2CbOua15k/DzcyKBT+JOTY0a1n0 T2aLPhxuPBnH3WcLd0kC
K72SskDWc9hi8g/kzocXaKg4uhJbsIMUBv3CKcRdKhb80HQMTglyg5mrIrMF ZT5BR5H8n+6zBblMoRGB
WY56KzUIQcuVkhtY0VGU2AIFnGSc49kdEWvR0Zr0puCUUD4mswVBnuAOOOWE dZ8t8q2Cmx/g3iNbidl9
kOnJ2KKZHROU45gLbIFmjW1AFahg2V01tAmakDEPDWLqTWFLK2fkXIMZERPZ v49vUTZN0IYEy5cNc7wE
JO8inNDFxl3Rhr5ZbOCcmBsYlpuLghHYgqBCYq0JRPGrWfPEVmh8qUHcglLY SpMF+CudZyvxWGxMMWds
kaBCGZxwoAhjC9ReWHOAM6vlNJPDn5pLih5yIo4F9bD6BhZFahA3NhS2TrTa 6doQDgJo/4yktmMQoGND
CSM4DIwtgC5T40J41CJfr2iUwukIUAt9tqV8vQWbC9qZJ277cMJUKvgBtnSn jtwXp2saW2B2qE4VvLn7
bIEmDkxBdn4KZ5B8gbEWVGLf5mwBsyHFBR8rvu+zBQtc8v4gntOXEBGzbOII awoPNIxjbGhsgRLXzl2B
g5eucI7NFfWWrndO7GRqzhZYrE+K88wS9jhbqDoCehPUVpHf7rGFxdKq/nT/ gPGXcMSSfxPZ0s4zgs84
2GpsnUBO5kR+4eeHpZp33t4CNPQgD4YZRyOHAdgyksHnmcuODwcLgXrG0gk+ dFlfPLbqHfIAGdypRppj
b5k7ZUQMIMXDlavKFh6lK8HF0er+mgh7OeoRSQeezeksOXiUrgQXR2vksMVs HkXvIdoXs9hjCzRbhdUN
15gKKYKot8xR3UKzMXvITchX2WKXTrx4ITc8sjbffuu83kKfR7GBf53EQdfC wAF69aKW7unCbuwJF8wn
MeaJ59KWsQKXLThUq0qqH5g4o5R9oss6xdkaPXvNxk55pobOFlypbW7Iutzg dnnn1quS6T5bmPMkTt2l
W0/mWa/Y6wn3tzfRM8CP+O0HQeewa7nKFrpsQdgnab+nNGYw8zW94MdhazTl zWZHwfvngwbYYsepj6bz
0vzYL4WM2u6zBQbXaOwfJbH3rx/wBg/OJM5Vtb30dPflDoL5sxcz51cXLJwd ui0Tqj0S1WELTi8cxSq0
mY2M0ZHU0IVzlu45O2RGktvOcTKOq9254phU5o6Q/AZcucKk+2wxPTx65oY6 v1z2kmPje1SOSWUAyn/k
ijR/P4YXUEw+QAlwskZk7TtsaXH/uMcIejW94IdybMq8I3Px6cxcNLPmV++Y vwoHvwT0lrnnK3K10Vg9
eDbS139Sn+gkmb9+bs6Lw+/mi9UrUmhdyHjw4CKZn/81Uc5IKuTh3r31MDeb O5ts4V5FBKffO2yBfqwU
YD+d0BxMtubt61axa8Ok1gTZisA1/iFGqhiW5upUOyTO7CZPqe34lhnapJsT P+kmHCmPLwzXZEsdkCId
abVkeEkAZwvW9dA5tNLMxpmVvMgQW3AVgjOd8v8di1HcMFtBuMwDVUa6qLdO mIEpCCj/1dSoMjK8JCc/
BJe5yCUyOVKKKCY4UJwt8PjTjabLWKA9lxrQB7ZC11lO5GhwhK3TTr2M8skM Q8/Yit2sOZrlBjaNv7h2
+D5yyWkeqYkp3kAV2+Ux/KYhzhYESVLxsLMcrb3UihBg63RQayKflaSwGFvm gizRVB2fnaiesXU6BotQ
pwVL5FIpkaBP0QydnE2OGFun2JEB7zyGxNiCbepquTJ5yzB4616Ipy0zyJaZ dGK/vSu27cPibJ0OH17s
ZnwpZegbW9pMOS+HX2XYmbqr7Pzt506U1Rjx8yKmEGXrdFpDaN1dmqeuOmJs QZikWo7fuWnBOKdMF2fr
tBVa7sZS4EEJbJlP/33CU8dv3+Uo0BSvdkjKv7Hlz93ey4fYEFlo8+trxxYn 3OTdplZQkCDTbc5vD82C
seeVt6vC2Pqks9uq5Safm7KDk98SD3pblV8pLc+/BQtBva5CefRb+8LIMTin v82P+exqgwYuzdJ4nRyK
+mDf6viu1H81Ecb2N9P6RX0Sd9wOSzfSOSsvji3auKdBCFYLbPP7gLPvMkX0 /F2aq8Hh+/uauQvM84cU
DHViEDqv/9tffj/NkXjmx7BQsWapWhPJPkwOmVR7wbU+/fuVncOeL+Y8x5/I uQSV2kCOQLSgJ5+qRSNM
NFLbh+keW5XE0eDDNEsrRvIavLPbX6UoQWwdSOvH/bLVtiTT5N3lT5EjWmm7 T+3S/bJFjks7kuwyNWlt
s8kOVVLwAo++QbZ2xkRNMEOst171mIO0gerSp7bZOmGVozyFCllSoW7eIFtn B3D88pZ9B51MG56pWAve
JWgS23I2LScv79k6NOfIuamSln5feovSG0MZaLQLUC0EkTicnfoYURO60ovC gIkRpFgfb1BvJQXcYWs9
6nDHZNj5vycE3PEUm3p3M/lSuEG2oApZXxQppyd0AXTnqUlrYNL5wqTIq+Uc 6U24QbYoiWmkRq4gc7Da
jk/aYHbsU5BNrNr0kH+TtdT8W2SLNjYnytbVBjYtEjyolmT97x5D8ZYH5WQi SDiulsx+X7Y8Hjb3IK6K
WPCUdlTPv8OilTeDUvJLWvI3YAZ4a4r8FvUWZvs8Cpb6ErK61PMRWhnTrjwE k4KdSo68iUfM6poknbmW
0rNbZAs29E33HpYsqHNYsUSe2w9AnCmgDS4jkSduhu6XLG2mpQCEeelNsoV1 yHnmnMmp2GxO+81m9eGk
qNx+3LRQMOyUGjPfZlleKbTbbJbuhXktxU3zl94mW3+RArIyJi+bYyn6vm+f 4SeR2D0J7x+yOVavt7fJ
VrQ6sZCpfLRBPUF2/Vux6sRCIueCjrZ+bpSt02/CFZatCrKtAbnac9YJuvw9 YY8/vYG3ytZp6xVhOPq/
qPa5o59N7E7MotqnvZ+bZcuUDQVV1+z+sraOWVB1ORVgzRm7YbZOe17YgXrr rcLZYs2F3Jkn7N61+TZ+
b3+u3TJbZkjXb8JUff5qX46dwSfSkOO3VGI8W7YWMIX33zhbpqfbFZy18vSa rdt0hfqCFGvn73L+YsOl
z2/tFgvdFVu9HP6baPTt662bGKZedmJgq5fD1otGD2z1Yph62ciBrV4OWy8a PbDVi2HqZSMHtno5bL1o
9MBWL4apl40c2OrlsPWi0QNbvRimXjZyYKuXw9aLRg9s9WKYetnIga1eDlsv Gj2w1Yth6mUjB7Z6OWy9
aPTAVi+GqZeNHNjq5bD1otEDW70Ypl42cmCrl8PWi0YPbPVimHrZyIGtXg5b Lxo9sNWLYeplIwe2ejls
vWj0wFYvhqmXjRzY6uWw9aLRA1u9GKZeNnJgq5fD1otGD2z1Yph62ciBrV4O Wy8aPbDVi2HqZSMHtno5
bL1o9MBWL4apl40c2OrlsPWi0QNbvRimXjZyYKuXw9aLRg9s9WKYetnIga1e DlsvGj2w1Yth6mUjB7Z6
OWy9aPTAVi+GqZeNHNjq5bD1otEDW70Ypl42Mp2t9Qv9tHTT0sI+sY7sfuy3 W76bLdiYvX3rok6j7+k7
6WzhTc8tiZUeWUfkdJNpVufrNb+zMxIrfl5qPuFuvpbMFsnUfGXczv2gA1s3 zVkyW5mdr/k/lq0IZWCr
FTF29SHJbPELaZ9a6c/AViti7OpDUtn6YWprNPpto0MDW21IsbPPSGXrzWHr vY0eDWy1IcXOPiORrb17
Ne+4jUtoB7Y6y0UbDUtk66tUW5axrxbePrDVghC7+4hEtp4ubI3fS8geW+jT wFYLQuzuI9LY2pZEPZFN
/9O8UwNbzWXY4SeksbUo2Voc7aL42rxXzdga9nyaj8BVn5DE1nFSsrU+WYex BWu+GVtXlcvw8OYSSGLr
2wYgDif6d9b47QNbjUXY5QcksTUDA54WxWnjfg1sNRZhlx+QwhZtU+cRU4qi rpt2bGCrqQQ7/f0Utmib
Ok+UokVx1rRnA1tNJdjp76ew9WADpwfTF1oUR7uGXRvYaijAbn89ga2NteQL RUWLYtMUwYGtbsPRsHUJ
bBFLRe4wLYrThimCA1sNR6/bX4+zdaBt6nxJZIvid7PODWw1k1/Hvx1na2mX xDJBfG5/89ysdxJb+2U2
z8sdFtmypYqPwyabnQsosmxdzI7/72e3+Ty/fJ6tNsq7f7+LDr9Wat1hs8yy 96IuJMuy70ppKfuf7PzF
WZb91Fp6fs3Lz09YZJmeyRdnq9ympkTmX8rlajb8HlvH71fME3tYhJ6/NTIt fjY6LPuvR5Z59roqhbkr
v10to+Ng3+pUF9nnUWu+bWAwb8Nk7vs+u0/rKOUfef5KGerDekGDYkOP80S+ dhl75fjNLj5WoMG6qf3q
zW7TnF8+ef+Wp02ULbtNPRrZuUHD1cyad9n6dLPERqOHT5WbhDqfrZvSaLo7 nheSsC7KQyU1ptb52Odl
xfP2HzwNPB+GGd/g/2HsnQdqmsVU68rnquTrNT7VN/4rR5OPgmgr0EAF0y+W e9GsfZf0ZpQtu009onDW
p31os4IfztbfM9MwdkJqWinK1p4Wb/bk6XmEr8zWD5/cZQMu4J3tVhItNu/x L8T6iikdT2CzgAo3j92x
ZYG+/Xhe2OJsad83M1aYEzG2jjT5yHDfU6saFfwwtr58pXV5zZtsTMTY2sij mz/01SiHq7J1/BDnifml
1fQ7eSqZNUbf71iHycrfqet54+GrIh7NjeqKsXVY6N83GtdbSWNsra2MJmAK kGJtVPCDbGXaYOQruqjr
I2zZVFnpwU+Hq7KlcmPacqk0WOvkjzTlQ+tFQFhzVe3JevLyqNkxxtZOX4yL Z7gGUowtogjbTCGuRgU/
wFYILQWuMFs2QVYehqfDFfXWMTgKZ83i1k3xRVtW1Kou5F1U4DoKlhZ+cXYM 662tbz66on3lnkiELVj9
0NekhK5yGlayh8sPE1thtGS4gmwF52gukyerkdu35RWr5jIUeeLbX0Br5Wu2 JM7IbKGBltVeuFHm2zMb
bZJs+XVoPSzf/cwckQhbpIV5fjxZyU1SBEWf49EEXUzwxvHwJr7/HmLLWT2m 8+xz85Ut0Fyxo9s6W0y/
TE0UyLGSFqcD/ub55YXHScyYCEaAM/0eTHBqtcmjXK+uEfYoBTIcv+ZhkX2Z 2NsclZGViMAW2UYFR88f
2XqzNlEurrue8dURtqjZ3EaEEFe18BCbkD5b44X1kg5LJjM/6SLAFjTPdPCN PP+N4Dq2zRYtiNPPi7L/
+8QxHG9txx8/LxTteMTCX9dYFd/DF5tqex4lk05UACvGSGROi9BaCNP4bO2Y nn2CGPR+yQwAtLnCbNE2
NQW3CjpopjUo+PHYmjH/mztb3v6SztYRqXzkS4Qf6WibLbtAoON0wCEsB+qB 9QkVk78awJI2EabzCgff
Z2OPf37mWvHX05r+93GkeKvz2AVOHHByw2zREu+qDVh06hf8uGx5AY1fEMnU NXB1ttDYevcWCNfbuhJb
rurxzaU3p2krMGlchx40sew171GYni+AxtaHa8x5gTaPLcT+xQ/uHsBNAOMl yBZsU7taA4z8+gU/DlvC
VsMW4HKPCVDZwuVD2jigL55VzHXY8uNMrvPoax8Im7jtpmDYWNnAO4D6cScp bK6MJBvGseVctmD58gIN
Z1DRB6U95iBbtE2Nwa0Ce0K1vjXP2BqLu1hbmsvue1S2YPnx5ijf3LgeW0JM 2TGHJeoJPyduCKefQWSf
KyAA6M1RTRCmlYPdHC6XLVBLCQEOu+IG2aIm+Y8ESam9jQUmGFsyBifie+S8 R2MLZKzlaTBP7hp6S9Tl
LEDEPKpSUCRUZzONNFqgAoYWPodMGCuXuvLNzKJ32AKBvmh76UfSmrbvIbb+ yL/09TBsBtUu+EG2RMc5
7zl9yElF1NiiOTjWtuZAEtdZE8WNBOajip9Q88VJCAG3nKahM13I1POM1pKt PYLvsEXcTfWNdDAIS2sv
xBaZxJIvCAZz3YIfZEtNA9rRqsjfo7FFM0jfW0MD5Ap6S145cFFU9spopWDe LVm3vnFCiwN1asJWDIh0
68mc2DjOFpivoXgTac1ytQ+wBZpJGiQYnroFP8BWwCGgacP7rLBFpsk4kK4C jtMV2JKLVMD/GSmDTBqG
ed/U1eC5Z7TOMLbIFA+tMOBqcDmTEgnmsBMP5XoeYAtIFve3oDE1C36ArYDq g3aw1V5hi0yT0DjAQ9tn
S9vAB6dXsVtoPWeezdGEwN9f8mUrmEVO6xpji+AIWcbgpHK2KFgYNqxpNC86 N8AWTW1ZLwU85pgRf/k7
mFKBb4D+ZAuFwhY9NHhuJkmsfba0jEl6p0YfyVT2mjfBvFR6PhMn/TqU+Qy2 HmPrQNowmFl2onlxYVBn
CzS4PFlgHa5Z8EMYKE5iISKygdnEkdmimFzYxSBJtM+WplzImtJUKvWpzn0M MlvkkoXLG2g9ZmyRho/s
wNDSe9FFOlsUvtbsR7BZ6hX8EFvB2D4JnClQmS36bTimSyJrny0ttZj6q6VU XoMtmkXhDHTSmYwtWlGD
CsAEUK2Cu7gSOlvkbmnZZmCz1Cv4IVkHk8QV/0dmi5RcWBSklttnS1vgqb/a XGzE1k62tyjyGU4SpigC
Yys+IcruEjHF5FLZgniFZreAISQlhcSNLtvs8PCCJYAaQWaLlGkkMmIHonW2 1MXYs3Y9EdVm6/CzwC1n
fDD5XOFSDdI7yBYIP5yLj1s1BcQqW7T66ssshLhqFfxYWUe2JEk62D2ZLbJp wpbnyULYOluqwOJuRh22
DpuvdzeVAdkibRYpULNiRrZgtykWDXD9UY0twDUpAlmr4MfKOuzcwgkUuJbI bJE9GynGsotn62ypJVjE
ljZM1dgykYn5i5jBimy5ZpC6ntjFEzuA+9TkMUb+VWgajS3IFZjbak/vH5AU UqfgJ5Ut0qHoPclsUZMi
a7I1cXvI1u86e3sJJRlD39MNSytmZCuY2K8hVrjBGltagZMKbJ2CH8tWxOGW gxAiWxSN4fsePmjWD26d
LXWFb0VvfS8Sxga6S55QbIismJEtUDLJauuS76+wBdvUqU+sccNPKlvkRaPv J7JFDY8hY78e+yDHMl5X
rZenNGfrdx4u4igHC9pMikddqy+ftmLGDwZL8TQ2igcobCWWK+Gza9zwY2Ud 8UCILXyJyBaZBzFkesgW
5dnHJjywRWKqxRbJPvZO+HuhIRW24rVo3ptqpAhWZwtDbffGlnYEQTkSE9Bp 7bGlnHsQBq2Y1zJbbsVQ
ErLVC34sW5GUe5o76FCKbFFYLmZv9U1vbckDFobjYW7CeeKeD1X4xOwtcU1M rorERoXYitZJSrBVL/hJ
tbcocILxEJEtCMf8Mz9RtQ6a2FvK2SX5QDy9L4tYnshWupUg+om11sQAW96N dkl6a1S54CeVrQoxCNi1
j0QKrdBihlknbHk5FDB9+ViCrSqyRX5iLD9YZIu2lSuHx8U1sZZvoFSah7RH KluUHRiPndI0iISRrST7
wBZLOc67OHkxVdWubEW20jW5HQ45BlG5nktki3YQppvYD3qUlQ5GNIJJjZ3K +3By7JS8kIgatVHoPrDF
i59fL2ugyxbFJ2AkaJtwFNkFs8OObKWba54WkdiCbepIWoV5HNQwuoU4EYMH 2IrEL4gXDKLJbBGHEd/i
envV7dtbzLdSjiMrHLPLD+ps0mbh3Xt5r5rMtZhzlMQWuJ3xQw5P4EhUTREU lbBPJO1asF1LmS2y+/WD
qPJXkGHWA71FE2Y01gEBDYVskWMWOvftdCLDDPUWKJrYaZnuyAl6C7apY15r /jTczKxY8JOYY0OzlkX/
ZLbow+HGk3HcfbZwlySw0ispC2Q9hy0m/0DufHiBhoqjK8W3YAcpDPqFU4i7 VCz4oekYnBLkBjNXRWYL
ynyCjiL5P91nC3KZQiMCsxz1VmoQgpYrJTewqqMo6C1QwEnGOZ7dEbEWHa1J bwpOCeVjMlsQ5AnugFNO
WPfZIt8quPkB7j2ylZjdB5mejC2a2TFBuY65zxZo1tgGVIEKlt1VQ5ugCRnz 0CCm3hS2tHJGzjWYETGR
/fv4FmXTBG1IsHzZMMdLQPIuwgldbNwVbeibxQbOibmBYbkpFYzPFgQVEmtN IIpfzZontkLjSw3iFpTC
VposwF/pPFuJx2JjijljiwQVyuCEA0UYW6D2wpoDnFktp5kc/tRcUvSQE3Es qIfVN7AoUoO4saGwdaLV
TteGcBBA+2cktR2DAB0bShjBYWBsAXSZGhfCoxb5ekWjFE5HgFrowpby9BZs LmhnnrjtwwlTqeAH2NKd
OnJfnK5pbIHZoTpV8ObuswWaODAF2fkpnEHyBcZaUIl9m7MFzIYUF3zs8n2P LVjgkvcH8Zy+hIiYZRNH
WFN4oGEcY0NjC5S4du4KHLx0hXNsrqi3dL1zYidTc7bAYn1SnGeWsMfZQtUR 0Jugti757S5bWCyt6k/3
Dxh/CUcs+TeRLe08I/iMg63G1gnkZE7kF35+WKp55+0tQEMP8mCYceTefgBb RjL4PHPZ8eFgIVDPWDrB
h8r1xWWr3iEPkMGdaqQ59tZoJB/ABSkerlxVtvAoXQkujlb310TYy1GPSDrw bE5nycGjdCW4OFojhy1m
8yh6D9EuzWKXLdBsFVY3XGMqpAii3jJHdQvNxuwhNyFfZYtdOvHihdzwyNp8 +63zegt9HsUG/nUSB10L
Awfo1YtauqcLu7EnXDCfxJgnnktrYwUOW3CoVpVUPzBxRin7RJd1irM1evaa jZ3yTA2dLShoNDdkXW5w
u7xz61XJdJ8tzHkSp+7SrSfzrFfs9YT725voGeBH/PaDoHPYtVy2hQ5bEPZJ 2u8pjRnMfE0v+HHYGk15
s9lR8P75oAG22HHqo+m8NEH3SyGjtvtsgcE1GvtHSez96we8wYMziXNVbS89 3X25g2D+7MXM+dUFC2eH
bsuESkeicrbg9MJRrEKb2cgYHUkNXbD41iU3ZEaS285xMo6r3bnimFTmjpD8 Bly5wqT7bDE9PHrmzhq/
XPYiR9+jckwqA1D+I1ek+fsxvIBi8gFKgJM1Amufs6XF/eMeI+jV9IIfyrGh zKPpzFw0s+ZX75i/Cge/
BPSWuecrcrXRWD14NtLXf1Kf6CSZv35uzovD7+aL1StSaF3IePDgIpmf/zVR zkgq5OHevfUwN5s7m2zh
XkWEp99ztkA/Vgqwn05oDiZb8/Z1q9i1YVJrgmxF4Br/ECNVDEtzdaodEmd2 k6fUdnzLDG3SzYmfdBOO
lMcXhmuypQ5IkY60WjJ2SQBjC9b10Dm00szGmZW8yBBbcBWCM53y/x2LUdww W0G4zANVRrqot06YgSkI
KP/V1KgyMrwkJz8El7nIJTI5UoooJmygGFvg8acbTZexQHsuNaAPbIWus5zI 0eAIW6edehnlkxmGnrEV
u1lzNMsNbBp/ce3wfeSS0zxSE1O8gSq2y2Ocm4YYWxAkScXDznK09lIrQoCt 00GtiXxWksJibJkLskRT
dXx2onrG1ukYLEKdFiyRS6VEgj5FM3RyNjlibJ1iRwa8OzEkZAu2qavlyuQt w+CteyGetswgW2bSif32
r9gunxZn63T48GI340spQ9/Y0mbKeTn8KsPO1F1l528/d6KsxoifFzGFKFun 0xpC6+7SPPXUEbIFYZJq
OX7npgXjnDJdnK3TVmi5G0uBByWwZT799wlPHb99l6NAU7zaISn/xpY/d3sv H2JDZKHNr68dW5xwk3eb
WkFBgky3Ob89NAvGnlf+rgqy9Ulnt1XLTT43ZQcnvyUe9LYqv1Jann8LFoJ6 XYXy6Lf2hZFjcE5/mx/z
2dUGDVyapfE6ORT1wb7V8V2p/2oijO1vpvWL+iTuuB2WbqRzVl4cW7RxT4MQ rBbY5vcBZ982RTT/Ls3V
4PD9fc3cBeb5QwyG8hiEzuv/9pffT3MknvkxLFStWarURrIPk0MmlZ5/tQ// fmXnsOeLOc/xJ3IuQaVG
kCMQLejJp2rRCBONVPdhOsdWJXE0+DDN0oqRvAbv7PZXKUoQWwcS+3G3bLUu yUSBd/dj5IhW2u7TO3S3
bJHj0pIkuwtNYstsskOVFLzQs2+PrZ0xURPMEOutVz7mIHGouvOxbbZOWOUo T6FCllSwk7fH1tkBHL+8
Zd9BJ9OGZyrWgncHmeSWnE3Lyct7tg7NOXJuqqSl35feovTGUAYa7QJUC0Ek D2iHPkjUhK70ojBgYgQp
2sPb01tJAXfYWo863FEZdv0DCQF3PMWm3t1MghBujy2oQtYXRcrpCV0A3XVo EtuXdL4wKfJqOUeBNtwe
W5TENFIjV5A5WG3HJ3E0u/UxyCZWbXrIv8naav0NskUbmxNl62oDmxYJHlRb sv5nz6F4y4NyMhEkHFdL
Zr8vWx4Pm3sQV0UseEo7quefUdHOi0Ep+SUt+SswA7w9RX6DeguzfR4FS30J WV3q+QjtDGpHnoJJwU4l
R97CI2Z1TZLOXEvq2A2yBRv6pncPSxbUOaxYIs/tByDOFNAGl5HIEzdD90uW NtNWAMK89RbZwjrkPHPO
5FRsNqf9ZrP6cFJUbj9uWigYdkqNmW+zLK8U2m02S/fCvLbipvlbb5Ktv0gB WRmTl82xJH3fsw/xk0js
noT3D9kcq9nZm2QrWp1YyFQ+2qCmIDv+tVh1YiGRc0FHaz+3ydbpN+EKy3YF 2dqIXOlB6wRd/p6wx1+h
eTfK1mnrFWE4+r+o9rmjn03sTsyi2qfFn1tly5QNBVXX7P6yto5ZUHW5FWDN Ibtdtk57XtiBeuutwtli
zWXcmSfs3rX5Nn6/wly7YbbMkK7fhKn6/HUFOXaGn3BDjt9SifFs2V7AFN5/ 22yZjm5XcNbK02u2btUV
6glSrJm/y/mLDZc+v7VbLIRvunm2+jj6N9Lmga0bGcgOdmNgq4ODciNNGti6 kYHsYDcGtjo4KDfSpIGt
GxnIDnZjYKuDg3IjTRrYupGB7GA3BrY6OCg30qSBrRsZyA52Y2Crg4NyI00a 2LqRgexgNwa2OjgoN9Kk
gq3hZ5DAVSQwsHUVsQ4PzfXW8DNI4DoS+A9va+i/pR0dwAAAAABJRU5ErkJg gg==
</property>
</structure>
</list-property>
</report>
Content-Type: application/vnd.ms-excel;
name="someData.csv"
filename="someData.csv"
U09NRV9EQVRBDQpTT01FX0RBVEENClNPTUVfREFUQQ0KU09NRV9EQVRBDQpT T01FX0RBVEEN
ClNPTUVfREFUQQ0K
Content-Type: application/msword;
name="reportTest.doc"
filename="reportTest.doc"
PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiIHN0YW5kYWxv bmU9InllcyI/
Pg0KPD9tc28tYXBwbGljYXRpb24gcHJvZ2lkPSJXb3JkLkRvY3VtZW50Ij8+ DQo8dzp3b3Jk
RG9jdW1lbnQgeG1sbnM6dz0iaHR0cDovL3NjaGVtYXMubWljcm9zb2Z0LmNv bS9vZmZpY2Uv
d29yZC8yMDAzL3dvcmRtbCIgeG1sbnM6dj0idXJuOnNjaGVtYXMtbWljcm9z b2Z0LWNvbTp2
bWwiIHhtbG5zOncxMD0idXJuOnNjaGVtYXMtbWljcm9zb2Z0LWNvbTpvZmZp Y2U6d29yZCIg
eG1sbnM6c2w9Imh0dHA6Ly9zY2hlbWFzLm1pY3Jvc29mdC5jb20vc2NoZW1h TGlicmFyeS8y
MDAzL2NvcmUiIHhtbG5zOmFtbD0iaHR0cDovL3NjaGVtYXMubWljcm9zb2Z0 LmNvbS9hbWwv
MjAwMS9jb3JlIiB4bWxuczp3eD0iaHR0cDovL3NjaGVtYXMubWljcm9zb2Z0 LmNvbS9vZmZp
Y2Uvd29yZC8yMDAzL2F1eEhpbnQiIHhtbG5zOm89InVybjpzY2hlbWFzLW1p Y3Jvc29mdC1j
b206b2ZmaWNlOm9mZmljZSIgeG1sbnM6ZHQ9InV1aWQ6QzJGNDEwMTAtNjVC My0xMWQxLUEy
OUYtMDBBQTAwQzE0ODgyIiB4bWxuczp3c3A9Imh0dHA6Ly9zY2hlbWFzLm1p Y3Jvc29mdC5j
b20vb2ZmaWNlL3dvcmQvMjAwMy93b3JkbWwvc3AyIiB3Om1hY3Jvc1ByZXNl bnQ9Im5vIiB3
OmVtYmVkZGVkT2JqUHJlc2VudD0ibm8iIHc6b2N4UHJlc2VudD0ibm8iIHht bDpzcGFjZT0i
cHJlc2VydmUiPjx3Omlnbm9yZUVsZW1lbnRzIHc6dmFsPSJodHRwOi8vc2No ZW1hcy5taWNy
b3NvZnQuY29tL29mZmljZS93b3JkLzIwMDMvd29yZG1sL3NwMiIvPjxvOkRv Y3VtZW50UHJv
cGVydGllcz48bzpMYXN0QXV0aG9yPmphbWVzdzwvbzpMYXN0QXV0aG9yPjxv OlJldmlzaW9u
PjI8L286UmV2aXNpb24+PG86VG90YWxUaW1lPjU8L286VG90YWxUaW1lPjxv OkNyZWF0ZWQ+
MjAwOS0wOS0xMFQwODo0MzowMFo8L286Q3JlYXRlZD48bzpMYXN0U2F2ZWQ+ MjAwOS0wOS0x
MFQwODo0ODowMFo8L286TGFzdFNhdmVkPjxvOlBhZ2VzPjE8L286UGFnZXM+ PG86V29yZHM+
NDQ1PC9vOldvcmRzPjxvOkNoYXJhY3RlcnM+MjU0MzwvbzpDaGFyYWN0ZXJz PjxvOkxpbmVz
PjIxPC9vOkxpbmVzPjxvOlBhcmFncmFwaHM+NTwvbzpQYXJhZ3JhcGhzPjxv OkNoYXJhY3Rl
cnNXaXRoU3BhY2VzPjI5ODM8L286Q2hhcmFjdGVyc1dpdGhTcGFjZXM+PG86 VmVyc2lvbj4x
MS4wMDAwPC9vOlZlcnNpb24+PC9vOkRvY3VtZW50UHJvcGVydGllcz48dzpm b250cz48dzpk
ZWZhdWx0Rm9udHMgdzphc2NpaT0iVGltZXMgTmV3IFJvbWFuIiB3OmZhcmVh c3Q9IlRpbWVz
IE5ldyBSb21hbiIgdzpoLWFuc2k9IlRpbWVzIE5ldyBSb21hbiIgdzpjcz0i VGltZXMgTmV3
IFJvbWFuIi8+PHc6Zm9udCB3Om5hbWU9IlZlcmRhbmEiPjx3OnBhbm9zZS0x IHc6dmFsPSIw
MjBCMDYwNDAzMDUwNDA0MDIwNCIvPjx3OmNoYXJzZXQgdzp2YWw9IjAwIi8+ PHc6ZmFtaWx5
IHc6dmFsPSJTd2lzcyIvPjx3OnBpdGNoIHc6dmFsPSJ2YXJpYWJsZSIvPjx3 OnNpZyB3OnVz
Yi0wPSIyMDAwMDI4NyIgdzp1c2ItMT0iMDAwMDAwMDAiIHc6dXNiLTI9IjAw MDAwMDAwIiB3
OnVzYi0zPSIwMDAwMDAwMCIgdzpjc2ItMD0iMDAwMDAxOUYiIHc6Y3NiLTE9 IjAwMDAwMDAw
Ii8+PC93OmZvbnQ+PC93OmZvbnRzPjx3OnN0eWxlcz48dzp2ZXJzaW9uT2ZC dWlsdEluU3R5
bGVuYW1lcyB3OnZhbD0iNCIvPjx3OmxhdGVudFN0eWxlcyB3OmRlZkxvY2tl ZFN0YXRlPSJv
ZmYiIHc6bGF0ZW50U3R5bGVDb3VudD0iMTU2Ii8+PHc6c3R5bGUgdzp0eXBl PSJwYXJhZ3Jh
cGgiIHc6ZGVmYXVsdD0ib24iIHc6c3R5bGVJZD0iTm9ybWFsIj48dzpuYW1l IHc6dmFsPSJO
b3JtYWwiLz48dzpyUHI+PHd4OmZvbnQgd3g6dmFsPSJUaW1lcyBOZXcgUm9t YW4iLz48dzpz
eiB3OnZhbD0iMjQiLz48dzpzei1jcyB3OnZhbD0iMjQiLz48dzpsYW5nIHc6 dmFsPSJFTi1H
QiIgdzpmYXJlYXN0PSJFTi1HQiIgdzpiaWRpPSJBUi1TQSIvPjwvdzpyUHI+ PC93OnN0eWxl
Pjx3OnN0eWxlIHc6dHlwZT0iY2hhcmFjdGVyIiB3OmRlZmF1bHQ9Im9uIiB3 OnN0eWxlSWQ9
IkRlZmF1bHRQYXJhZ3JhcGhGb250Ij48dzpuYW1lIHc6dmFsPSJEZWZhdWx0 IFBhcmFncmFw
aCBGb250Ii8+PHc6c2VtaUhpZGRlbi8+PC93OnN0eWxlPjx3OnN0eWxlIHc6 dHlwZT0idGFi
bGUiIHc6ZGVmYXVsdD0ib24iIHc6c3R5bGVJZD0iVGFibGVOb3JtYWwiPjx3 Om5hbWUgdzp2
YWw9Ik5vcm1hbCBUYWJsZSIvPjx3eDp1aU5hbWUgd3g6dmFsPSJUYWJsZSBO b3JtYWwiLz48
dzpzZW1pSGlkZGVuLz48dzpyUHI+PHd4OmZvbnQgd3g6dmFsPSJUaW1lcyBO ZXcgUm9tYW4i
Lz48L3c6clByPjx3OnRibFByPjx3OnRibEluZCB3Onc9IjAiIHc6dHlwZT0i ZHhhIi8+PHc6
dGJsQ2VsbE1hcj48dzp0b3Agdzp3PSIwIiB3OnR5cGU9ImR4YSIvPjx3Omxl ZnQgdzp3PSIx
MDgiIHc6dHlwZT0iZHhhIi8+PHc6Ym90dG9tIHc6dz0iMCIgdzp0eXBlPSJk eGEiLz48dzpy
aWdodCB3Onc9IjEwOCIgdzp0eXBlPSJkeGEiLz48L3c6dGJsQ2VsbE1hcj48 L3c6dGJsUHI+
PC93OnN0eWxlPjx3OnN0eWxlIHc6dHlwZT0ibGlzdCIgdzpkZWZhdWx0PSJv biIgdzpzdHls
ZUlkPSJOb0xpc3QiPjx3Om5hbWUgdzp2YWw9Ik5vIExpc3QiLz48dzpzZW1p SGlkZGVuLz48
L3c6c3R5bGU+PHc6c3R5bGUgdzp0eXBlPSJwYXJhZ3JhcGgiIHc6c3R5bGVJ ZD0iVE9DNCI+
PHc6bmFtZSB3OnZhbD0idG9jIDQiLz48d3g6dWlOYW1lIHd4OnZhbD0iVE9D IDQiLz48dzph
dXRvUmVkZWZpbmUvPjx3OnNlbWlIaWRkZW4vPjx3OnJzaWQgdzp2YWw9IjAw OUIzQzhGIi8+
PHc6cFByPjx3OnBTdHlsZSB3OnZhbD0iVE9DNCIvPjwvdzpwUHI+PHc6clBy Pjx3eDpmb250
IHd4OnZhbD0iVGltZXMgTmV3IFJvbWFuIi8+PHc6bGFuZyB3OnZhbD0iRU4t R0IiIHc6ZmFy
ZWFzdD0iRU4tR0IiIHc6YmlkaT0iQVItU0EiLz48L3c6clByPjwvdzpzdHls ZT48L3c6c3R5
bGVzPjx3OnNoYXBlRGVmYXVsdHM+PG86c2hhcGVkZWZhdWx0cyB2OmV4dD0i ZWRpdCIgc3Bp
ZG1heD0iMjA1MCIvPjxvOnNoYXBlbGF5b3V0IHY6ZXh0PSJlZGl0Ij48bzpp ZG1hcCB2OmV4
dD0iZWRpdCIgZGF0YT0iMSIvPjwvbzpzaGFwZWxheW91dD48L3c6c2hhcGVE ZWZhdWx0cz48
dzpkb2NQcj48dzp2aWV3IHc6dmFsPSJwcmludCIvPjx3Onpvb20gdzpwZXJj ZW50PSIxMDAi
Lz48dzphdHRhY2hlZFRlbXBsYXRlIHc6dmFsPSIiLz48dzpkZWZhdWx0VGFi U3RvcCB3OnZh
bD0iNzIwIi8+PHc6Y2hhcmFjdGVyU3BhY2luZ0NvbnRyb2wgdzp2YWw9IkRv bnRDb21wcmVz
cyIvPjx3OnZhbGlkYXRlQWdhaW5zdFNjaGVtYS8+PHc6c2F2ZUludmFsaWRY TUwgdzp2YWw9
Im9mZiIvPjx3Omlnbm9yZU1peGVkQ29udGVudCB3OnZhbD0ib2ZmIi8+PHc6 YWx3YXlzU2hv
d1BsYWNlaG9sZGVyVGV4dCB3OnZhbD0ib2ZmIi8+PHc6Zm9vdG5vdGVQcj48 dzpmb290bm90
ZSB3OnR5cGU9InNlcGFyYXRvciI+PHc6cCB3c3A6cnNpZFI9IjAwMzQ0NDZG IiB3c3A6cnNp
ZFJEZWZhdWx0PSIwMDM0NDQ2RiI+PHc6cj48dzpzZXBhcmF0b3IvPjwvdzpy PjwvdzpwPjwv
dzpmb290bm90ZT48dzpmb290bm90ZSB3OnR5cGU9ImNvbnRpbnVhdGlvbi1z ZXBhcmF0b3Ii
Pjx3OnAgd3NwOnJzaWRSPSIwMDM0NDQ2RiIgd3NwOnJzaWRSRGVmYXVsdD0i MDAzNDQ0NkYi
Pjx3OnI+PHc6Y29udGludWF0aW9uU2VwYXJhdG9yLz48L3c6cj48L3c6cD48 L3c6Zm9vdG5v
dGU+PC93OmZvb3Rub3RlUHI+PHc6ZW5kbm90ZVByPjx3OmVuZG5vdGUgdzp0 eXBlPSJzZXBh
cmF0b3IiPjx3OnAgd3NwOnJzaWRSPSIwMDM0NDQ2RiIgd3NwOnJzaWRSRGVm YXVsdD0iMDAz
NDQ0NkYiPjx3OnI+PHc6c2VwYXJhdG9yLz48L3c6cj48L3c6cD48L3c6ZW5k bm90ZT48dzpl
bmRub3RlIHc6dHlwZT0iY29udGludWF0aW9uLXNlcGFyYXRvciI+PHc6cCB3 c3A6cnNpZFI9
IjAwMzQ0NDZGIiB3c3A6cnNpZFJEZWZhdWx0PSIwMDM0NDQ2RiI+PHc6cj48 dzpjb250aW51
YXRpb25TZXBhcmF0b3IvPjwvdzpyPjwvdzpwPjwvdzplbmRub3RlPjwvdzpl bmRub3RlUHI+
PHc6Y29tcGF0Lz48d3NwOnJzaWRzPjx3c3A6cnNpZFJvb3Qgd3NwOnZhbD0i MDBBQjQ4RUYi
Lz48d3NwOnJzaWQgd3NwOnZhbD0iMDAwQzYwMTYiLz48d3NwOnJzaWQgd3Nw OnZhbD0iMDAz
NDQ0NkYiLz48d3NwOnJzaWQgd3NwOnZhbD0iMDBBQjQ4RUYiLz48d3NwOnJz aWQgd3NwOnZh
bD0iMDBFRDQ1RDUiLz48L3dzcDpyc2lkcz48L3c6ZG9jUHI+PHc6Ym9keT48 d3g6c2VjdD48
dzp0Ymw+PHc6dGJsUHI+PHc6dGJsT3ZlcmxhcCB3OnZhbD0iTmV2ZXIiLz48 dzp0YmxXIHc6
dz0iMTE1MjAiIHc6dHlwZT0iZHhhIi8+PHc6dGJsTGF5b3V0IHc6dHlwZT0i Rml4ZWQiLz48
dzp0YmxDZWxsTWFyPjx3OmxlZnQgdzp3PSIxMCIgdzp0eXBlPSJkeGEiLz48 dzpyaWdodCB3
Onc9IjEwIiB3OnR5cGU9ImR4YSIvPjwvdzp0YmxDZWxsTWFyPjx3OnRibExv b2sgdzp2YWw9
IjAxRTAiLz48L3c6dGJsUHI+PHc6dGJsR3JpZD48dzpncmlkQ29sIHc6dz0i MTE1MjAiLz48
L3c6dGJsR3JpZD48dzp0ciB3c3A6cnNpZFI9IjAwQUI0OEVGIj48dzp0YmxQ ckV4Pjx3OnRi
bENlbGxNYXI+PHc6dG9wIHc6dz0iMCIgdzp0eXBlPSJkeGEiLz48dzpib3R0 b20gdzp3PSIw
IiB3OnR5cGU9ImR4YSIvPjwvdzp0YmxDZWxsTWFyPjwvdzp0YmxQckV4Pjx3 OnRjPjx3OnRj
UHI+PHc6dGNXIHc6dz0iMTE1MjAiIHc6dHlwZT0iZHhhIi8+PC93OnRjUHI+ PHc6dGJsPjx3
OnRibFByPjx3OnRibE92ZXJsYXAgdzp2YWw9Ik5ldmVyIi8+PHc6dGJsVyB3 Onc9IjExNTIw
IiB3OnR5cGU9ImR4YSIvPjx3OnRibExheW91dCB3OnR5cGU9IkZpeGVkIi8+ PHc6dGJsQ2Vs
bE1hcj48dzpsZWZ0IHc6dz0iMTAiIHc6dHlwZT0iZHhhIi8+PHc6cmlnaHQg dzp3PSIxMCIg
dzp0eXBlPSJkeGEiLz48L3c6dGJsQ2VsbE1hcj48dzp0YmxMb29rIHc6dmFs PSIwMUUwIi8+
PC93OnRibFByPjx3OnRibEdyaWQ+PHc6Z3JpZENvbCB3Onc9IjExNTIwIi8+ PC93OnRibEdy
aWQ+PHc6dHIgd3NwOnJzaWRSPSIwMEFCNDhFRiI+PHc6dGJsUHJFeD48dzp0 YmxDZWxsTWFy
Pjx3OnRvcCB3Onc9IjAiIHc6dHlwZT0iZHhhIi8+PHc6Ym90dG9tIHc6dz0i MCIgdzp0eXBl
PSJkeGEiLz48L3c6dGJsQ2VsbE1hcj48L3c6dGJsUHJFeD48dzp0clByPjx3 OnRibEhlYWRl
ci8+PC93OnRyUHI+PHc6dGM+PHc6dGNQcj48dzp0Y1cgdzp3PSIxMTUyMCIg dzp0eXBlPSJk
eGEiLz48L3c6dGNQcj48dzpwIHdzcDpyc2lkUj0iMDBBQjQ4RUYiIHdzcDpy c2lkUkRlZmF1
bHQ9IjAwQUI0OEVGIj48dzpwUHI+PHc6clByPjx3OnZhbmlzaC8+PC93OnJQ cj48L3c6cFBy
PjwvdzpwPjwvdzp0Yz48L3c6dHI+PHc6dHIgd3NwOnJzaWRSPSIwMEFCNDhF RiI+PHc6dGJs
UHJFeD48dzp0YmxDZWxsTWFyPjx3OnRvcCB3Onc9IjAiIHc6dHlwZT0iZHhh Ii8+PHc6Ym90
dG9tIHc6dz0iMCIgdzp0eXBlPSJkeGEiLz48L3c6dGJsQ2VsbE1hcj48L3c6 dGJsUHJFeD48
dzp0Yz48dzp0Y1ByPjx3OnRjVyB3Onc9IjExNTIwIiB3OnR5cGU9ImR4YSIv Pjwvdzp0Y1By
Pjx3OnAgd3NwOnJzaWRSPSIwMEFCNDhFRiIgd3NwOnJzaWRSRGVmYXVsdD0i MDAzNDQ0NkYi
Pjx3OnI+PHc6clByPjx3OnJGb250cyB3OmFzY2lpPSJWZXJkYW5hIiB3OmZh cmVhc3Q9IlZl
cmRhbmEiIHc6aC1hbnNpPSJWZXJkYW5hIiB3OmNzPSJWZXJkYW5hIi8+PHd4 OmZvbnQgd3g6
dmFsPSJWZXJkYW5hIi8+PHc6Yi8+PHc6Y29sb3Igdzp2YWw9IjAwMDAwMCIv Pjx3OnN6IHc6
dmFsPSIzMiIvPjx3OnN6LWNzIHc6dmFsPSIzMiIvPjwvdzpyUHI+PHc6dD5U SVRMRSBMRVZF
TCAxPC93OnQ+PC93OnI+PC93OnA+PC93OnRjPjwvdzp0cj48dzp0ciB3c3A6 cnNpZFI9IjAw
QUI0OEVGIj48dzp0YmxQckV4Pjx3OnRibENlbGxNYXI+PHc6dG9wIHc6dz0i MCIgdzp0eXBl
PSJkeGEiLz48dzpib3R0b20gdzp3PSIwIiB3OnR5cGU9ImR4YSIvPjwvdzp0 YmxDZWxsTWFy
Pjwvdzp0YmxQckV4Pjx3OnRjPjx3OnRjUHI+PHc6dGNXIHc6dz0iMTE1MjAi IHc6dHlwZT0i
ZHhhIi8+PC93OnRjUHI+PHc6dGJsPjx3OnRibFByPjx3OnRibE92ZXJsYXAg dzp2YWw9Ik5l
dmVyIi8+PHc6dGJsVyB3Onc9IjExNTIwIiB3OnR5cGU9ImR4YSIvPjx3OnRi bExheW91dCB3
OnR5cGU9IkZpeGVkIi8+PHc6dGJsQ2VsbE1hcj48dzpsZWZ0IHc6dz0iMTAi IHc6dHlwZT0i
ZHhhIi8+PHc6cmlnaHQgdzp3PSIxMCIgdzp0eXBlPSJkeGEiLz48L3c6dGJs Q2VsbE1hcj48
dzp0YmxMb29rIHc6dmFsPSIwMUUwIi8+PC93OnRibFByPjx3OnRibEdyaWQ+ PHc6Z3JpZENv
bCB3Onc9IjExNTIwIi8+PC93OnRibEdyaWQ+PHc6dHIgd3NwOnJzaWRSPSIw MEFCNDhFRiI+
PHc6dGJsUHJFeD48dzp0YmxDZWxsTWFyPjx3OnRvcCB3Onc9IjAiIHc6dHlw ZT0iZHhhIi8+
PHc6Ym90dG9tIHc6dz0iMCIgdzp0eXBlPSJkeGEiLz48L3c6dGJsQ2VsbE1h cj48L3c6dGJs
UHJFeD48dzp0clByPjx3OnRySGVpZ2h0IHc6dmFsPSIyNzYiLz48dzp0YmxI ZWFkZXIvPjwv
dzp0clByPjx3OnRjPjx3OnRjUHI+PHc6dGNXIHc6dz0iMTE1MjAiIHc6dHlw ZT0iZHhhIi8+
PHc6dm1lcmdlIHc6dmFsPSJyZXN0YXJ0Ii8+PC93OnRjUHI+PHc6cCB3c3A6 cnNpZFI9IjAw
QUI0OEVGIiB3c3A6cnNpZFJEZWZhdWx0PSIwMEFCNDhFRiI+PHc6cFByPjx3 OnJQcj48dzp2
YW5pc2gvPjwvdzpyUHI+PC93OnBQcj48L3c6cD48L3c6dGM+PC93OnRyPjx3 OnRyIHdzcDpy
c2lkUj0iMDBBQjQ4RUYiPjx3OnRibFByRXg+PHc6dGJsQ2VsbE1hcj48dzp0 b3Agdzp3PSIw
IiB3OnR5cGU9ImR4YSIvPjx3OmJvdHRvbSB3Onc9IjAiIHc6dHlwZT0iZHhh Ii8+PC93OnRi
bENlbGxNYXI+PC93OnRibFByRXg+PHc6dHJQcj48dzp0ckhlaWdodCB3OnZh bD0iMjc2Ii8+
PC93OnRyUHI+PHc6dGM+PHc6dGNQcj48dzp0Y1cgdzp3PSIxMTUyMCIgdzp0 eXBlPSJkeGEi
Lz48dzp2bWVyZ2Ugdzp2YWw9InJlc3RhcnQiLz48L3c6dGNQcj48dzpwIHdz cDpyc2lkUj0i
MDBBQjQ4RUYiIHdzcDpyc2lkUkRlZmF1bHQ9IjAwMzQ0NDZGIj48dzpyPjx3 OnJQcj48dzpy
Rm9udHMgdzphc2NpaT0iVmVyZGFuYSIgdzpmYXJlYXN0PSJWZXJkYW5hIiB3 OmgtYW5zaT0i
VmVyZGFuYSIgdzpjcz0iVmVyZGFuYSIvPjx3eDpmb250IHd4OnZhbD0iVmVy ZGFuYSIvPjx3
OmIvPjx3OmNvbG9yIHc6dmFsPSI4MDAwMDAiLz48dzpzeiB3OnZhbD0iMzIi Lz48dzpzei1j
cyB3OnZhbD0iMzIiLz48L3c6clByPjx3OnQ+VElUTEUgTEVWRUwgMjwvdzp0 PjwvdzpyPjwv
dzpwPjwvdzp0Yz48L3c6dHI+PHc6dHIgd3NwOnJzaWRSPSIwMEFCNDhFRiI+ PHc6dGJsUHJF
eD48dzp0YmxDZWxsTWFyPjx3OnRvcCB3Onc9IjAiIHc6dHlwZT0iZHhhIi8+ PHc6Ym90dG9t
IHc6dz0iMCIgdzp0eXBlPSJkeGEiLz48L3c6dGJsQ2VsbE1hcj48L3c6dGJs UHJFeD48dzp0
clByPjx3OnRySGVpZ2h0IHc6dmFsPSIyNzYiLz48L3c6dHJQcj48dzp0Yz48 dzp0Y1ByPjx3
OnRjVyB3Onc9IjExNTIwIiB3OnR5cGU9ImR4YSIvPjx3OnZtZXJnZSB3OnZh bD0icmVzdGFy
dCIvPjwvdzp0Y1ByPjx3OnAgd3NwOnJzaWRSPSIwMEFCNDhFRiIgd3NwOnJz aWRSRGVmYXVs
dD0iMDBBQjQ4RUYiPjx3OnI+PHc6cGljdD48djpzaGFwZXR5cGUgaWQ9Il94 MDAwMF90NzUi
IGNvb3Jkc2l6ZT0iMjE2MDAsMjE2MDAiIG86c3B0PSI3NSIgbzpwcmVmZXJy ZWxhdGl2ZT0i
dCIgcGF0aD0ibUA0QDVsQDRAMTFAOUAxMUA5QDV4ZSIgZmlsbGVkPSJmIiBz dHJva2VkPSJm
Ij48djpzdHJva2Ugam9pbnN0eWxlPSJtaXRlciIvPjx2OmZvcm11bGFzPjx2 OmYgZXFuPSJp
ZiBsaW5lRHJhd24gcGl4ZWxMaW5lV2lkdGggMCIvPjx2OmYgZXFuPSJzdW0g QDAgMSAwIi8+
PHY6ZiBlcW49InN1bSAwIDAgQDEiLz48djpmIGVxbj0icHJvZCBAMiAxIDIi Lz48djpmIGVx
bj0icHJvZCBAMyAyMTYwMCBwaXhlbFdpZHRoIi8+PHY6ZiBlcW49InByb2Qg QDMgMjE2MDAg
cGl4ZWxIZWlnaHQiLz48djpmIGVxbj0ic3VtIEAwIDAgMSIvPjx2OmYgZXFu PSJwcm9kIEA2
IDEgMiIvPjx2OmYgZXFuPSJwcm9kIEA3IDIxNjAwIHBpeGVsV2lkdGgiLz48 djpmIGVxbj0i
c3VtIEA4IDIxNjAwIDAiLz48djpmIGVxbj0icHJvZCBANyAyMTYwMCBwaXhl bEhlaWdodCIv
Pjx2OmYgZXFuPSJzdW0gQDEwIDIxNjAwIDAiLz48L3Y6Zm9ybXVsYXM+PHY6 cGF0aCBvOmV4
dHJ1c2lvbm9rPSJmIiBncmFkaWVudHNoYXBlb2s9InQiIG86Y29ubmVjdHR5 cGU9InJlY3Qi
Lz48bzpsb2NrIHY6ZXh0PSJlZGl0IiBhc3BlY3RyYXRpbz0idCIvPjwvdjpz aGFwZXR5cGU+
PHc6YmluRGF0YSB3Om5hbWU9IndvcmRtbDovLzAzMDAwMDAxLnBuZyI+aVZC T1J3MEtHZ29B
QUFBTlNVaEVVZ0FBQWxzQUFBR3BDQU1BQUFDTnFRUE1BQUFBQVhOU1IwSUFy czRjNlFBQUFB
Um5RVTFCQUFDeA0Kand2OFlRVUFBQUFnWTBoU1RRQUFlaVlBQUlDRUFBRDZB QUFBZ09nQUFI
VXdBQURxWUFBQU9wZ0FBQmR3bkxwUlBBQUFBd0JRVEZSRg0KQUFBQUNBZ0lF QkFRR0JnWUlD
QWdLQ2dvTURBd09EZzRRRUJBU0VoSVVGQlFXRmhZWUdCZ2FHaG9jSEJ3ZUho NGYzOS9oNGVI
ajQrUA0KbDVlWG41K2ZwNmVucjYrdnQ3ZTN2NysveDhmSHo4L1AxOWZYMzkv ZjUrZm43Ky92
OS9mMy8vLy9BQUFBQUFBQUFBQUFBQUFBQUFBQQ0KQUFBQUFBQUFBQUFBQUFB QUFBQUFBQUFB
QUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFB QUFBQUFBQQ0K
QUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFB QUFBQUFBQUFB
QUFBQUFBQUFBQUFBQUFBQUFBQUFBQQ0KQUFBQUFBQUFBQUFBQUFBQUFBQUFB QUFBQUFBQUFB
QUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFB QQ0KQUFBQUFB
QUFBQUFBQUFBQUFBQUFBQQ0KQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFB QUFBQUFBQUFB
QUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQQ0KQUFB QUFBQUFBQUFB
QUFBQUFBQUFBQQ0KQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFB QUFBQUFBQUFB
QUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQQ0KQUFBQUFBQUFB QUFBQUFBQUFB
Re: Nested tables + truncated images + Word emitter [message #485216 is a reply to message #485010] Thu, 10 September 2009 15:50 Go to previous messageGo to next message
James,
I believe this has been fixed in 2.5. I tried your report with 2.5 and
no images were messed up by the page breaks.
Jason
James Willans wrote:
> Hello,
> Kind Regards,
> James
Re: Nested tables + truncated images + Word emitter [message #485383 is a reply to message #485216] Fri, 11 September 2009 11:07 Go to previous messageGo to next message
Hi Jason,
Thanks, I appreciate your response. Yes this looks to be fixed in 2.5,
although I have now hit issue #283984 which is frustrating since we
can't upgrade to 2.5.1 at this stage because of all the other
dependencies it brings in!
James
Jason Weathersby wrote:
> James,
> Jason
>> Hello,
>> contains many examples. Note that this does not happen with the pdf
>> emitter.
>> Kind Regards,
>> James
Re: Nested tables + truncated images + Word emitter [message #485430 is a reply to message #485383] Fri, 11 September 2009 13:28 Go to previous message
James,
As a work around can you put page breaks in after each image?
Jason
> Hi Jason,
> James
>> James,
>> and no images were messed up by the page breaks.
>> Jason
>>> Hello,
>>> emitter.
>>> Kind Regards,
>>> James
Previous Topic:Date format strings using locale
Next Topic:How Business Intelligence and GIS are becoming more integrated.
Current Time: Mon Nov 03 08:52:46 EST 2025
Powered by FUDForum. Page generated in 0.03744 seconds
