Home » Modeling » Modeling (top-level project) » How to make sure that a resource is written
How to make sure that a resource is written [message #483877] Thu, 03 September 2009 09:00 Go to next message
Hi all
I'm trying to read an EMF resource. In case it does not exist, I create a
new one, add some default content to it and call save().
Now I've got the problem, that after the save(), the resource might still
not exist and an IOException is thrown when I try to load the resource. It
seems like a race condition to me, since it never occurs in the debugger.
So I helped myself with the following loop:
while
(!resource.getResourceSet().getURIConverter().exists(resourc e.getURI(),
Collections.EMPTY_MAP))
System.out.println("save it");
resource.save(saveOptions);
It is now clear, that save() does not guarantee the existence of the
resource after it has been called. I have seen up to 30 executions of the
while-loop until the resource finally existed.
My question is: how can I make sure, that the new resource really exists?
The while-loop does not look like a nice solution to me. Or am I
misunderstanding something?
Thanks for your helpful posts ;-)
Roland
Re: How to make sure that a resource is written [message #483995 is a reply to message #483877] Thu, 03 September 2009 16:36 Go to previous messageGo to next message
Roland,
Please post EMF questions to the EMF newsgroup, which I've added to the
"to" list of the reply. More comments below.
Roland Brand wrote:
> Hi all
> create a new one, add some default content to it and call save().
> still not exist and an IOException is thrown when I try to load the
> resource. It seems like a race condition to me, since it never occurs
> in the debugger. So I helped myself with the following loop:
> while
> the while-loop until the resource finally existed.
What's the value of the URI?
> exists? The while-loop does not look like a nice solution to me. Or am
> I misunderstanding something?
I wouldn't expect this kind of behavior...
> Roland
Re: How to make sure that a resource is written [message #484060 is a reply to message #483995] Fri, 04 September 2009 03:02 Go to previous messageGo to next message
Hi Ed
Oops, sorry.
> Roland Brand wrote:
>> Hi all
>> while
The URI is archive:file://home/rbrand/model.zip!/semantic.xmi
As you can probably guess, I have a Zipfile containing GMF resources: a
semantic model and a notation model.
>> Roland
Re: How to make sure that a resource is written [message #484200 is a reply to message #484060] Fri, 04 September 2009 11:05 Go to previous messageGo to next message
Roland,
Perhaps there is a bug in exists for this case. If you could create a
test case demonstrating the problem in a bugzilla report, I'll quickly
have a look and fix it if there is a basic problem.
Roland Brand wrote:
> Hi Ed
>> the "to" list of the reply. More comments below.
> Oops, sorry.
>> Roland Brand wrote:
>>> Hi all
>>> occurs in the debugger. So I helped myself with the following loop:
>>> while
>>> of the while-loop until the resource finally existed.
> a semantic model and a notation model.
>>> am I misunderstanding something?
>>> Roland
Re: How to make sure that a resource is written [message #484352 is a reply to message #484200] Mon, 07 September 2009 03:47 Go to previous messageGo to next message
Hi Ed
I think the exists() is working properly. When I omit the while-loop and
call resource.save() only once, I get an IOException when I try to read
the resource. It really does not exists for a short amount of time.
java.io.IOException: Archive entry not found
org.eclipse.emf.common.archive.ArchiveURLConnection.getInput Stream(ArchiveURLConnection.java:244)
org.eclipse.emf.ecore.resource.impl.ArchiveURIHandlerImpl.cr eateInputStream(ArchiveURIHandlerImpl.java:59)
org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterIm pl.createInputStream(ExtensibleURIConverterImpl.java:301)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1254)
Stepping into the resource.save() I could see that the OutputStream is
closed. But nevertheless it seems not to be written to disk directly.
Could there be OS caches? Is there a possiblity to flush the Zipfile?
Re: How to make sure that a resource is written [message #484435 is a reply to message #484352] Mon, 07 September 2009 09:16 Go to previous messageGo to next message
Roland,
It could well be an OS issue I suppose... I'm just not sure what to do
about it...
Roland Brand wrote:
> Hi Ed
> and call resource.save() only once, I get an IOException when I try to
> read the resource. It really does not exists for a short amount of time.
> at
> at
> at
> at
Re: How to make sure that a resource is written [message #484542 is a reply to message #484435] Tue, 08 September 2009 03:53 Go to previous messageGo to next message
Hi Ed
I just filed bug #288799 for this, hoping you can reproduce the problem.
Re: How to make sure that a resource is written [message #484641 is a reply to message #484542] Tue, 08 September 2009 10:38 Go to previous message
Roland,
Unfortunately it works fine for me so I can only assume that
network/filesystem issues specific to Linux are at play. I'm not even
in a position to reproduce OS-specific issues nor can I imagine how EMF
itself could address such things.
Roland Brand wrote:
> Hi Ed
Re: How to make sure that a resource is written [message #617812 is a reply to message #483877] Thu, 03 September 2009 16:36 Go to previous message
Roland,
Roland Brand wrote:
> Hi all
> while
> Roland
Re: How to make sure that a resource is written [message #617814 is a reply to message #483995] Fri, 04 September 2009 03:02 Go to previous message
Hi Ed
Oops, sorry.
> Roland Brand wrote:
>> Hi all
>> while
>> Roland
Re: How to make sure that a resource is written [message #617816 is a reply to message #484060] Fri, 04 September 2009 11:05 Go to previous message
Roland,
Roland Brand wrote:
> Hi Ed
> Oops, sorry.
>> Roland Brand wrote:
>>> Hi all
>>> while
>>> Roland
Re: How to make sure that a resource is written [message #617818 is a reply to message #484200] Mon, 07 September 2009 03:47 Go to previous message
Hi Ed
Re: How to make sure that a resource is written [message #617820 is a reply to message #484352] Mon, 07 September 2009 09:16 Go to previous message
Roland,
about it...
Roland Brand wrote:
> Hi Ed
> at
> at
> at
> at
Re: How to make sure that a resource is written [message #618206 is a reply to message #484435] Tue, 08 September 2009 03:53 Go to previous message
Hi Ed
Re: How to make sure that a resource is written [message #618207 is a reply to message #484542] Tue, 08 September 2009 10:38 Go to previous message
Roland,
Roland Brand wrote:
> Hi Ed
Previous Topic:How to make sure that a resource is written
Next Topic:[PMF] Current status
Current Time: Wed Sep 24 14:57:19 EDT 2025
Powered by FUDForum. Page generated in 0.06143 seconds
