Home » Language IDEs » ServerTools (WTP) » [WSDL Validator] wsp:PolicyReference validation problems.
[WSDL Validator] wsp:PolicyReference validation problems. [message #483465] |
Tue, 01 September 2009 16:55 |
Juan Pedro Silva Messages: 258 Registered: July 2009 |
--------------060507020800080008010700
Hi everybody, I'm having trouble trying to validate a wsdl file with
wsp:PolicyReference elements.
I had some other problems regarding the order in which the elements
appeared within the document (wsp:PolicyReference elements had to appear
before any child elements), but I fixed that.
However, now the validator is reporting a:
/The 'ServiceInterface_PortType' port type specified for the
'OnePort_Binding' binding is undefined. Check the
'ServiceInterface_PortType' port type name and ensure it is defined.
when this port type is defined just above the binding:
<wsdl:portType name = 'ServiceInterface_PortType'>
<wsdl:operation name = 'FirstOperation'>
<wsdl:input message = 'tns:FirstOperationRequest'/>
<wsdl:output message = 'tns:FirstOperationResponse'/>
</wsdl:operation>
<wsdl:operation name = 'SecondOperation'>
<wsp:PolicyReference URI =
'http://examples.com/PolicyDocument.xmi#Policy3'/>
<wsdl:input message = 'tns:SecondOperationRequest'/>
<wsdl:output message = 'tns:SecondOperationResponse'/>
</wsdl:operation>
</wsdl:portType>
If I delete the policy reference, the whole wsdl document validates
correctly.
However, if I'm not mistaken, according to
http://www.w3.org/Submission/WS-PolicyAttachment/#AttachingP olicyUsingWSDL1.1
this is a valid place for a policy reference, isn't it?.
Which could be the cause of this behavior?.
I thank you all in advance for your help.
Juan Pedro
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
wsp:PolicyReference elements.<br>
<br>
appear before any child elements), but I fixed that.<br>
However, now the validator is reporting a:<br>
<br>
<i>The 'ServiceInterface_PortType' port type specified for the
'ServiceInterface_PortType' port type name and ensure it is defined. <br>
</i><br>
when this port type is defined just above the binding:<br>
<font face="Courier New, Courier, monospace"><br>
<wsdl:portType name = 'ServiceInterface_PortType'><br>
<wsdl:operation name = 'FirstOperation'><br>
<wsdl:input message = 'tns:FirstOperationRequest'/><br>
<wsdl:output message = 'tns:FirstOperationResponse'/><br>
</wsdl:operation><br>
<wsdl:operation name = 'SecondOperation'><br>
'<a class="moz-txt-link-freetext" href="http://examples.com/PolicyDocument.xmi#Policy3'/">http://examples.com/PolicyDocument.xmi#Policy3'/</a>><br>
<wsdl:input message = 'tns:SecondOperationRequest'/><br>
<wsdl:output message = 'tns:SecondOperationResponse'/><br>
</wsdl:portType><br>
<br>
</font>If I delete the policy reference, the whole wsdl document
validates correctly. <br>
<a class="moz-txt-link-freetext" href=" http://www.w3.org/Submission/WS-PolicyAttachment/#AttachingP olicyUsingWSDL1.1"> http://www.w3.org/Submission/WS-PolicyAttachment/#AttachingP olicyUsingWSDL1.1</a>
this is a valid place for a policy reference, isn't it?.<br>
Which could be the cause of this behavior?. <br>
I thank you all in advance for your help.<br>
Best regards,<br>
Juan Pedro<br>
</body>
</html>
--------------060507020800080008010700--
Re: [WSDL Validator] wsp:PolicyReference validation problems. [message #483488 is a reply to message #483465] |
Tue, 01 September 2009 17:46 |
Valentin Messages: 36 Registered: July 2009 |
Member |
------=_NextPart_000_000A_01CA2B0A.8D134C80
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hi Juan, can you please specify what WTP version you are using? I =
suspect it's a 3.0.4 or older, because in 3.0.5 and newer we've made the =
required changes to allow extensibility elements for all WSDL elements. =
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D261070.
Regards, Valentin
"Juan Pedro Silva" <jpsilvagallino@gmail.com> wrote in message =
news:h7jjlh$4lg$1@build.eclipse.org...
Hi everybody, I'm having trouble trying to validate a wsdl file with =
I had some other problems regarding the order in which the elements =
appeared within the document (wsp:PolicyReference elements had to appear =
The 'ServiceInterface_PortType' port type specified for the =
'OnePort_Binding' binding is undefined. Check the =
'ServiceInterface_PortType' port type name and ensure it is defined.=20
<wsdl:portType name =3D 'ServiceInterface_PortType'>
<wsdl:operation name =3D 'FirstOperation'>
<wsdl:input message =3D 'tns:FirstOperationRequest'/>
<wsdl:output message =3D 'tns:FirstOperationResponse'/>
</wsdl:operation>
<wsdl:operation name =3D 'SecondOperation'>
<wsp:PolicyReference URI =3D =
<wsdl:input message =3D 'tns:SecondOperationRequest'/>
<wsdl:output message =3D 'tns:SecondOperationResponse'/>
</wsdl:operation>
</wsdl:portType>
If I delete the policy reference, the whole wsdl document validates =
correctly.=20
However, if I'm not mistaken, according to =
http://www.w3.org/Submission/WS-PolicyAttachment/#AttachingP olicyUsingWSD=
L1.1 this is a valid place for a policy reference, isn't it?.
Which could be the cause of this behavior?.=20
Juan Pedro
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META content=3D"text/html; charset=3Diso-8859-1" =
http-equiv=3DContent-Type>
<META name=3DGENERATOR content=3D"MSHTML 8.00.6001.18812">
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff text=3D#000000>
<DIV><FONT size=3D2 face=3DArial>Hi Juan, c</FONT><FONT size=3D2 =
face=3DArial>an you=20
please specify what WTP version you are using? I suspect it's a 3.0.4 or =
older,=20
because in 3.0.5 and newer we've made the required changes to allow=20
extensibility elements for all WSDL elements. See <A=20
href=3D"https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D261070">https://b=
ugs.eclipse.org/bugs/show_bug.cgi?id=3D261070</A>.</FONT> </DIV>
<DIV><FONT size=3D2 face=3DArial></FONT> </DIV>
<DIV><FONT size=3D2 face=3DArial>Regards, Valentin</FONT></DIV>
<BLOCKQUOTE=20
style=3D"BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; =
PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
<DIV>"Juan Pedro Silva" <<A=20
href=3D"mailto:jpsilvagallino@gmail.com">jpsilvagallino@gmail.com</A>>=
wrote=20
in message <A=20
href=3D"news:h7jjlh$4lg$1@build.eclipse.org">news:h7jjlh$4lg$1@build.ecli=
pse.org</A>...</DIV>Hi=20
everybody, I'm having trouble trying to validate a wsdl file with=20
wsp:PolicyReference elements.<BR><BR>I had some other problems =
regarding the=20
order in which the elements appeared within the document =
(wsp:PolicyReference=20
elements had to appear before any child elements), but I fixed=20
that.<BR>However, now the validator is reporting a:<BR><BR><I>The=20
'OnePort_Binding'=20
binding is undefined. Check the 'ServiceInterface_PortType' port type =
name and=20
ensure it is defined. <BR></I><BR>when this port type is defined just =
above=20
the binding:<BR><FONT=20
face=3D"Courier New, Courier, monospace"><BR><wsdl:portType name =
=3D=20
'ServiceInterface_PortType'><BR> =
<wsdl:operation name=20
=3D 'FirstOperation'><BR> =
<wsdl:input=20
message =3D =
'tns:FirstOperationRequest'/><BR> =20
<wsdl:output message =3D=20
'tns:FirstOperationResponse'/><BR> =20
</wsdl:operation><BR> <wsdl:operation name =
=3D=20
'SecondOperation'><BR> =20
<wsp:PolicyReference URI =3D '<A class=3Dmoz-txt-link-freetext=20
href=3D"http://examples.com/PolicyDocument.xmi#Policy3'/">http://examples=
..com/PolicyDocument.xmi#Policy3'/</A>><BR> &nbs=
p;=20
<wsdl:input message =3D=20
'tns:SecondOperationRequest'/><BR> =20
'tns:SecondOperationResponse'/><BR> =20
</wsdl:operation><BR></wsdl:portType> <BR><BR></FONT>If I =
delete=20
the policy reference, the whole wsdl document validates correctly.=20
<BR>However, if I'm not mistaken, according to <A =
href=3D" http://www.w3.org/Submission/WS-PolicyAttachment/#AttachingP olicy=
UsingWSDL1.1"> http://www.w3.org/Submission/WS-PolicyAttachment/#Attaching=
PolicyUsingWSDL1.1</A>=20
this is a valid place for a policy reference, isn't it?.<BR>Which =
could be the=20
cause of this behavior?. <BR>I thank you all in advance for your =
help.<BR>Best=20
regards,<BR> &=
nbsp; & nbsp; =20
Juan Pedro<BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_000A_01CA2B0A.8D134C80--
Current Time: Fri Apr 26 11:45:26 GMT 2024
Powered by FUDForum. Page generated in 0.03491 seconds
