Home » Archived » Voicetools » How to Download VTP 3.0 Source Code
| Re: How to Download VTP 3.0 Source Code [message #497132 is a reply to message #497125] |
Thu, 12 November 2009 10:02   |
Jay, I think you're on the right track. Attached is the current
CoreTeamSet.xml -- we really need to host this somewhere publically, but
for now here it is.
Good luck,
Randy
In <hdh6sq$205$1@build.eclipse.org> wrote:
> Hello Randy,
> In this thread, you mention CoreTeamSet.xml. Where can I get a copy
> of this file? I'm trying to build VTP. Can you confirm if I'm on the
> right track so far: 1. checkout https://dev.eclipse.org/svnroot/
> technology/org.eclipse.vtp/F ramework/trunk/plugins/ 2. checkout https://
> dev.eclipse.org/svnroot/technology/org.eclipse.vtp/D esktop/trunk/
> plugins/ 3. In Eclipse, in a fresh workspace, use 'import existing
> projects into workspace' to import projects downloaded in steps 1 and
> 2 above.
> After step 3, there are build errors and I'm hoping CoreTeamSet.xml
> brings in the right settings to fix those errors.
> Jay
| Re: How to Download VTP 3.0 Source Code [message #497383 is a reply to message #497132] |
Thu, 12 November 2009 23:46   |
Hi Randy,
The dtd referenced by CoreTeamSet.xml is not available it seems. Thus, import fails. The dtd referenced is: http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd
Is there another version of CoreTeamSet.xml?
I created a psf file by placing <psf>...</psf> portion of the xml file into a new file. I was then able to import the psf file, allowing Eclipse to connect using CVS and download many dependencies.
However, there are still many errors in the workspace. Errors are in org.eclipse.vtp.modules.attacheddata.ui, org.eclipse.vtp.desktop.model.interactive.core. Some dependencies are still missing. Some of the missing parts are BrandManager, ConfigurationException, IBrand, FormatterRegistration, FormatterRegistrationManager.
Jay
| Re: How to Download VTP 3.0 Source Code [message #578820 is a reply to message #578805] |
for now here it is.
Good luck,
Randy
> Hello Randy,
> 2 above.
> Jay
| Re: How to Download VTP 3.0 Source Code [message #663426 is a reply to message #483378] |
Mon, 04 April 2011 21:35   |
Hi all,
Is there a neat document that details the 1, 2, 3,... step-by-step instructions to download, build, and deploy VTP? I suppose a general description of the different plugins, etc. that make up the project would be useful as well. Trying to make sense out of all of these bit and pieces all over the place is a bit confusing! I worked on a similar framework for my previous company before and I'm willing to contribute to the advancement of VTP but first I must be able to download it, build it, and deploy it. I did take the OpenVXML studio and that is working fine but the VTP framework for eclipse I have not tried just because I do not feel there is a good document that shows HOW-TO. I may use this for an IVR solution at my current employer and so I have an incentive to make sure that it is production quality. Please help with providing all details on getting me started!
Carlos
PS: I do have subclipse setup and can take stuff via SVN;
| Re: How to Download VTP 3.0 Source Code [message #664474 is a reply to message #578859] |
Sat, 09 April 2011 06:37  |
Hi Randy,
I've done all the steps above and upon saving and then importing the CoreTeamSet.xml file as instructed I get "The specified file is not a valid Team Project Set file" What am I doing wrong here? I'm not familiar with these kinds of files and their usage so perhaps I missing something. I'm assuming this has nothing to do with your comment '...you may need to specify "anonymous" for the
username on some of the servers'? But where would I do this? Would I have gotten a prompt to do so? As soon as I browsed to the CoreTeamSet.xml, it tooks a few seconds to come back with the error message above.
Thanks In Advance!
Carlos
Current Time: Tue Oct 28 03:18:07 EDT 2025
Powered by FUDForum. Page generated in 0.09789 seconds
