| JRE installation doesn't exist [message #483326] |
Tue, 01 September 2009 03:14  |
Hello
i am using the eclipse to write test cases to validate a system
and an error is appearing to me "the specified JRE installation doesn't exist"
Knowing that i made sure ,from the project preferences, that the desired JRE is installed and i ran another workspace with the same JRE and it works properly
So Could anyone tell me what are the other possibilities that may cause this problem ?
Thank.
Mostafa Atef
| Re: JRE installation doesn't exist [message #483482 is a reply to message #483326] |
Tue, 01 September 2009 13:27  |
On 9/1/09 3:14 AM, Mostafa wrote:
> Hello
> exist"
> works properly
> this problem ?
I think the most likely cause is that the project was created and
defined to use a specific JRE name; when such a project is moved to or
checked out in another workspace, a JRE with that EXACT name must exist.
To avoid this problem, I always recommend choosing an Execution
Environment (EE) instead of a specific JRE. On any workspace, the
standard Execution Environments will all exist and be satisfied by the
JRE(s) that are defined for that workspace.
Hope this helps,
Eric
FUDForum. Page generated in 0.08996 seconds
