Home » Newcomers » Newcomers » Shortcut problem
Shortcut problem [message #483229] Mon, 31 August 2009 12:19 Go to next message
Originally posted by: jedlicka.poll.cz
--------------000903090600090000070408
Content-Type: text/plain; charset=ISO-8859-2; format=flowed
I have created my actions and I have defined some shortcuts for
them. One of these shortcuts is CTRL+F. When I press CTRL+F there appear
list with options of action for this shortcut (see attachment). This is
ok because for the same shortcut is in RCP defined action Find and
Replace. But can this shortcut work only for my actions? That means to
disable default action (Find and Replace) and to do only my action. If
it is possible could you please advice how to set this up? Any example?
Thanks.
Martin
Content-Type: image/gif;
name="key.GIF"
Content-Disposition: inline;
filename="key.GIF"
R0lGODlhgQAuAPcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/ AP//AAAA//8A
/wD//////wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMwAAZgAAmQAAzAAA/wAz AAAzMwAzZgAz
mQAzzAAz/wBmAABmMwBmZgBmmQBmzABm/wCZAACZMwCZZgCZmQCZzACZ/wDM AADMMwDMZgDM
mQDMzADM/wD/AAD/MwD/ZgD/mQD/zAD//zMAADMAMzMAZjMAmTMAzDMA/zMz ADMzMzMzZjMz
mTMzzDMz/zNmADNmMzNmZjNmmTNmzDNm/zOZADOZMzOZZjOZmTOZzDOZ/zPM ADPMMzPMZjPM
mTPMzDPM/zP/ADP/MzP/ZjP/mTP/zDP//2YAAGYAM2YAZmYAmWYAzGYA/2Yz AGYzM2YzZmYz
mWYzzGYz/2ZmAGZmM2ZmZmZmmWZmzGZm/2aZAGaZM2aZZmaZmWaZzGaZ/2bM AGbMM2bMZmbM
mWbMzGbM/2b/AGb/M2b/Zmb/mWb/zGb//5kAAJkAM5kAZpkAmZkAzJkA/5kz AJkzM5kzZpkz
mZkzzJkz/5lmAJlmM5lmZplmmZlmzJlm/5mZAJmZM5mZZpmZmZmZzJmZ/5nM AJnMM5nMZpnM
mZnMzJnM/5n/AJn/M5n/Zpn/mZn/zJn//8wAAMwAM8wAZswAmcwAzMwA/8wz AMwzM8wzZswz
mcwzzMwz/8xmAMxmM8xmZsxmmcxmzMxm/8yZAMyZM8yZZsyZmcyZzMyZ/8zM AMzMM8zMZszM
mczMzMzM/8z/AMz/M8z/Zsz/mcz/zMz///8AAP8AM/8AZv8Amf8AzP8A//8z AP8zM/8zZv8z
mf8zzP8z//9mAP9mM/9mZv9mmf9mzP9m//+ZAP+ZM/+ZZv+Zmf+ZzP+Z///M AP/MM//MZv/M
mf/MzP/M////AP//M///Zv//mf//zP///yH5BAEAABAALAAAAACBAC4AAAj/ AFEIHEiwoMGD
CBMqXMiwocOHCv/5k/gPhT8UFTNaxMix4kWNHjty/CiSpEaTI0WGBLmRJcqV GKnBPClzok1/
NiniFJgTY86fOoMCHSq0KNGjRpMi/UkNKYqmSnXyvElV4kecVbFazYpzq1et YLuG5Ur2q9iz
E6eh9aq2rFaeFFNQJHhxqcWoS/HqzctXbFGLfCUK/JrxrU6/EwELRUw46+Gh jME+Xgy55uSJ
NSP7hZu4sNSBcwdf5Ly3dODTSqESfXp66lbAN31e7dpyrFm3a23rzs27atvb /37vTnx3olyf
Um3epVvctHPU0C//jWxUdPKgijvu9CzZsffG4LuH/9ecM3NlyotJ+2xeV3D7 uuyfy4/OV/Vf
+3YVg2Vudf3Anfr1BtxwAwpIoFbCrZVgWaTJRd98ED7Yl1PUDSUaeej9hKGG kHWYoXTfiYeT
ZY6Z96FA1OBDzYoqsrhiii+2CKOLNM5oo4w4xqhjjTnyuOONP/YIpI8+unag gUjipmSBS9q2
IFtJVhSfhBFWSSWHSlUolHUhksfehnOB+Z1+II5X3ngkjkcacaAht9p8zdG1 15QR4ieUnUcZ
udORyjV5lmx17YkkoEwW+iSCUa7JnUb/CQZaT6IRFJp6c03qaKRsWjoanVge peVPFyrH3Hsb
9clYbSd11qd7HnUmm3b9cf9XXHGapSmZiZ1KCZSbILlaKaQ8zUoqsLOO6t5y /8Up6VJ46tSs
hQEG2idspbK63XbZzQYoYK96le1Iic0mraECHrqWorzCqu518E27qqqFCSvv sHH+muVSn362
JajDSrmmpN1uqh+t/nHbqMGRwvWfh5ih+WFsnFopMb8TG/WsRBeDGm2hfHKc aJQdI1qWuVWh
uKI/MKJ8csovoqyiyk2xvPLLLcscM80zx5wzzC7rfLPPPfNsc9A14/xzqA+b mbSIYiqda5e2
+oWrdIpeWbHV9GWc8Wcgd+3n1x6DTXJwiUaM9dVoM2xUvqIu3TTTancZt9PS TX1T1JBVnfbe
ZzN+xWxrG4fsddiEC+5buWX3zfficz+tFNKOw+12429Xfl6udhOmt+KcM641 4IMbXnjopKeF
+JKbM666hJ+y7ejksEdueexl3uqw7CjCLKPuNdfI+8q+//i7z7sLb3zwyNs4 /PI66gm26NCX
Tu7Iia9uPdatAw7R9tx37/332wcEADs=
--------------000903090600090000070408--
Re: Shortcut problem [message #483276 is a reply to message #483229] Mon, 31 August 2009 16:32 Go to previous messageGo to next message
for commands you can define your own schema. This is described here:
http://www.vogella.de/articles/EclipseCommands/article.html
Best regards, Lars
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
Martin Jedlička wrote:
> I have created my actions and I have defined some shortcuts for them.
> One of these shortcuts is CTRL+F. When I press CTRL+F there appear list
> with options of action for this shortcut (see attachment). This is ok
> because for the same shortcut is in RCP defined action Find and Replace.
> But can this shortcut work only for my actions? That means to disable
> default action (Find and Replace) and to do only my action. If it is
> Thanks.
> Martin
Re: Shortcut problem [message #483300 is a reply to message #483276] Mon, 31 August 2009 17:24 Go to previous message
Super!
Thank you very much!
M.
Lars Vogel napsal(a):
> Best regards, Lars
Previous Topic:Shortcut problem
Next Topic:Upgrading Eclipse
Current Time: Sat Nov 08 09:48:40 EST 2025
Powered by FUDForum. Page generated in 0.09126 seconds
