Home » Modeling » EMF » Two features named in the model by the same name
Re: Two features named in the model by the same name [message #483174 is a reply to message #483144] |
Mon, 31 August 2009 13:19 |
Ed Merks Messages: 33142 Registered: July 2009 |
A feature's name must be unique among all the features of the class
itself along with the closure of all its super classes. If you turn to
the other tab, you'll probably still be able to generate code, though
it's going to have problems because of this.
ETTAIB M wrote:
> Hi all,
> I'm facing a problem when I try to generate an 'EMF Generator Model'
> from an ecore inupt model, actually, the input model is just an
> extension of the UML2 ecore model with reference to some profiles, the
> errors given are like this:
> Problems encountered in the model. There may not be two features named
> 'base_Operation',
> so, I can't generate my genModel, nor the model code.
> In fact base_Operation is an attribute that is declared in many
> classes in the profiles, but I don't understand why it occures while
> having different classes!
> can anybody give a idea how to resolve this please.
> Thanks in advance
> m.ettaib
Ed Merks
Re: Two features named in the model by the same name [message #483185 is a reply to message #483174] |
Mon, 31 August 2009 13:56 |
--=-73oYZ3Q+0EqYYVFHllkb
Content-Type: text/plain
Hi, Ed, m.ettaib,
Yes, most likely the problem is that a stereotype that extends the
Operation metaclass already inherits a metaclass extension to Operation
from a super-stereotype. It is, actually, forbidden by the UML for a
stereotype to redefine (implicitly or explicitly) an inherited metaclass
extension, if my memory serves me right.
Christian
> ETTAIB M wrote:
> > Hi all,
> > 'base_Operation',
> > Thanks in advance
> > m.ettaib
Content-Type: text/html; charset="utf-8"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.24.1.1">
</HEAD>
<BODY>
Hi, Ed, m.ettaib,<BR>
<BR>
Yes, most likely the problem is that a stereotype that extends the Operation metaclass already inherits a metaclass extension to Operation from a super-stereotype. It is, actually, forbidden by the UML for a stereotype to redefine (implicitly or explicitly) an inherited metaclass extension, if my memory serves me right.<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
ETTAIB M wrote:
> Hi all,
> 'base_Operation',
> Thanks in advance
> m.ettaib
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-73oYZ3Q+0EqYYVFHllkb--
Re: Two features named in the model by the same name [message #483411 is a reply to message #483343] |
Tue, 01 September 2009 14:21 |
Comments below.
ETTAIB wrote:
> Hi Ed and Christian,
> Indeed, I can generate the genmodel enspite of the errors, but this
> genmodel could not be opened with EMF Generator, nor generate the code
> model.
It's a common mistake to assume it can't be opened because it opens to
the error tab. The other tabs are still available.
> In fact, a feature's name is unique among all the classes and there is
> no relation between these classes such inheritance.
I doubt that. The validator looks at the features in
getEAllStructuralFeatures and complains if there are duplicates, so I'm
pretty sure it's not going to find them if they don't exist.
> And the operation metaclasses are not stereotyped at all, so I can't
> figure yet what is really going on.
I'm not in a good position to comment on the UML stuff, so when it comes
to profiles and stereotypes, best to use the UML2 newsgroup. Perhaps UML
is doing stuff with what it's loading (implicit inheritance?) that I'm
not aware of...
> here is the code of one of my profiles
> "com.bluage.profile.bo.profile.uml" where the attribute base_Operation
> is creating the problem. just in case if you can figure something from
> it.
> Thanks very much
> <xmi:XMI xmi:version="2.1"
> xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:Ecore="http://www.eclipse.org/uml2/schemas/Ecore/5"
> xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
> xmlns:uml="http://www.eclipse.org/uml2/3.0.0/UML"
> xsi:schemaLocation="http://www.eclipse.org/uml2/schemas/Ecore/5
> pathmap://UML_PROFILES/Ecore.profile.uml#_z1OFcHjqEdy8S4Cr8R c_NA">
> <uml:Profile xmi:id="_boProfile" name="bo"
> metamodelReference="_19PvUJ9KEd2fxPczPj7-fg">
> <eAnnotations xmi:id="_u7TEoZ9MEd2fxPczPj7-fg"
> source="http://www.eclipse.org/uml2/2.0.0/UML">
> <contents xmi:type="ecore:EPackage"
> xmi:id="_u7TEop9MEd2fxPczPj7-fg" name="bo"
> nsURI="http://www.bluage.com/profiles/bo" nsPrefix="bo">
> <eClassifiers xmi:type="ecore:EClass"
> xmi:id="_u7TEo59MEd2fxPczPj7-fg" name="attach">
> <eAnnotations xmi:id="_u7TEpJ9MEd2fxPczPj7-fg"
> references="_455tsJ9KEd2fxPczPj7-fg"/>
> <eStructuralFeatures xmi:type="ecore:EReference"
> xmi:id="_u7TEpZ9MEd2fxPczPj7-fg" name="base_Operation" ordered="false"
> lowerBound="1">
> <eType xmi:type="ecore:EClass"
> href="http://www.eclipse.org/uml2/3.0.0/UML#//Operation"/>
> </eStructuralFeatures>
> </eClassifiers>
> xmi:id="_u7TEp59MEd2fxPczPj7-fg" name="detach">
> <eAnnotations xmi:id="_u7TEqJ9MEd2fxPczPj7-fg"
> references="_Ayc-UJ9LEd2fxPczPj7-fg"/>
> xmi:id="_u7TEqZ9MEd2fxPczPj7-fg" name="base_Operation" ordered="false"
> lowerBound="1">
> </eClassifiers>
> xmi:id="_u7TEq59MEd2fxPczPj7-fg" name="formula">
> <eAnnotations xmi:id="_u7TErJ9MEd2fxPczPj7-fg"
> references="_GpqpUJ9LEd2fxPczPj7-fg"/>
> xmi:id="_u7TErZ9MEd2fxPczPj7-fg" name="base_Operation" ordered="false"
> lowerBound="1">
> <eStructuralFeatures xmi:type="ecore:EAttribute"
> xmi:id="_u7TEr59MEd2fxPczPj7-fg" name="binary_java" ordered="false"
> lowerBound="1">
> <eType xmi:type="ecore:EDataType"
> href="http://www.eclipse.org/emf/2002/Ecore#//EString"/>
> xmi:id="_u7TEsZ9MEd2fxPczPj7-fg" name="binary_net" ordered="false"
> lowerBound="1">
> </eClassifiers>
> xmi:id="_u7TEs59MEd2fxPczPj7-fg" name="getter">
> <eAnnotations xmi:id="_u7TEtJ9MEd2fxPczPj7-fg"
> references="_Vskn0J9LEd2fxPczPj7-fg"/>
> xmi:id="_u7TEtZ9MEd2fxPczPj7-fg" name="base_Operation" ordered="false"
> lowerBound="1">
> </eClassifiers>
> xmi:id="_u7TEt59MEd2fxPczPj7-fg" name="ocl_impl">
> <eAnnotations xmi:id="_u7TEuJ9MEd2fxPczPj7-fg"
> references="_ezz5IJ9LEd2fxPczPj7-fg"/>
> xmi:id="_u7TEuZ9MEd2fxPczPj7-fg" name="base_Operation" ordered="false"
> lowerBound="1">
> </eClassifiers>
> xmi:id="_u7TEu59MEd2fxPczPj7-fg" name="ocl_sql">
> <eAnnotations xmi:id="_u7TEvJ9MEd2fxPczPj7-fg"
> references="_k2f0UJ9LEd2fxPczPj7-fg"/>
> xmi:id="_u7TEvZ9MEd2fxPczPj7-fg" name="base_Operation" ordered="false"
> lowerBound="1">
> </eClassifiers>
> xmi:id="_u7TEv59MEd2fxPczPj7-fg" name="PK_BUSINESS_OBJECT">
> <eAnnotations xmi:id="_u7TEwJ9MEd2fxPczPj7-fg"
> references="_pp548J9LEd2fxPczPj7-fg"/>
> xmi:id="_u7TEwZ9MEd2fxPczPj7-fg" name="base_Package" ordered="false"
> lowerBound="1">
> href="http://www.eclipse.org/uml2/3.0.0/UML#//Package"/>
> </eClassifiers>
> xmi:id="_u7TEw59MEd2fxPczPj7-fg" name="PK_BUSINESS">
> <eAnnotations xmi:id="_u7TExJ9MEd2fxPczPj7-fg"
> references="_zcWDYJ9LEd2fxPczPj7-fg"/>
> xmi:id="_u7TExZ9MEd2fxPczPj7-fg" name="base_Package" ordered="false"
> lowerBound="1">
> </eClassifiers>
> xmi:id="_u7TEx59MEd2fxPczPj7-fg" name="setter">
> <eAnnotations xmi:id="_u7TEyJ9MEd2fxPczPj7-fg"
> references="_Hiw_EJ9MEd2fxPczPj7-fg"/>
> xmi:id="_u7TEyZ9MEd2fxPczPj7-fg" name="base_Operation" ordered="false"
> lowerBound="1">
> </eClassifiers>
> xmi:id="_u7TEy59MEd2fxPczPj7-fg" name="specific_impl">
> <eAnnotations xmi:id="_u7TEzJ9MEd2fxPczPj7-fg"
> references="_PsKIEJ9MEd2fxPczPj7-fg"/>
> xmi:id="_u7TEzZ9MEd2fxPczPj7-fg" name="base_Operation" ordered="false"
> lowerBound="1">
> </eClassifiers>
> </contents>
> </eAnnotations>
> <elementImport xmi:id="_yeeiYJ9KEd2fxPczPj7-fg">
> <importedElement xmi:type="uml:PrimitiveType"
> href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#Boolea n"/>
> </elementImport>
> <elementImport xmi:id="_yeeiYZ9KEd2fxPczPj7-fg">
> href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#Intege r"/>
> </elementImport>
> <elementImport xmi:id="_yeeiYp9KEd2fxPczPj7-fg">
> href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#String"/>
> </elementImport>
> <elementImport xmi:id="_yeeiY59KEd2fxPczPj7-fg">
> href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#Unlimi tedNatural"/>
> </elementImport>
> <packageImport xmi:id="_19PvUJ9KEd2fxPczPj7-fg">
> <importedPackage xmi:type="uml:Model"
> href="pathmap://UML_METAMODELS/UML.metamodel.uml#_0"/>
> </packageImport>
> <packagedElement xmi:type="uml:Stereotype"
> xmi:id="_455tsJ9KEd2fxPczPj7-fg" name="attach">
> <ownedAttribute xmi:id="_9M-FYp9KEd2fxPczPj7-fg"
> name="base_Operation" association="_9M-FYJ9KEd2fxPczPj7-fg">
> <type xmi:type="uml:Class"
> href="pathmap://UML_METAMODELS/UML.metamodel.uml#Operation"/>
> </ownedAttribute>
> </packagedElement>
> xmi:id="_Ayc-UJ9LEd2fxPczPj7-fg" name="detach">
> <ownedAttribute xmi:id="_Db4esp9LEd2fxPczPj7-fg"
> name="base_Operation" association="_Db4esJ9LEd2fxPczPj7-fg">
> </ownedAttribute>
> </packagedElement>
> xmi:id="_GpqpUJ9LEd2fxPczPj7-fg" name="formula">
> <ownedAttribute xmi:id="_IxtT4p9LEd2fxPczPj7-fg"
> name="base_Operation" association="_IxtT4J9LEd2fxPczPj7-fg">
> </ownedAttribute>
> <ownedAttribute xmi:id="_K0sfUJ9LEd2fxPczPj7-fg" name="binary_java">
> <type xmi:type="uml:PrimitiveType"
> </ownedAttribute>
> <ownedAttribute xmi:id="_Pr-XUJ9LEd2fxPczPj7-fg" name="binary_net">
> </ownedAttribute>
> </packagedElement>
> xmi:id="_Vskn0J9LEd2fxPczPj7-fg" name="getter">
> <ownedAttribute xmi:id="_bWOX8p9LEd2fxPczPj7-fg"
> name="base_Operation" association="_bWOX8J9LEd2fxPczPj7-fg">
> </ownedAttribute>
> </packagedElement>
> xmi:id="_ezz5IJ9LEd2fxPczPj7-fg" name="ocl_impl">
> <ownedAttribute xmi:id="_h4WoMp9LEd2fxPczPj7-fg"
> name="base_Operation" association="_h4WoMJ9LEd2fxPczPj7-fg">
> </ownedAttribute>
> </packagedElement>
> xmi:id="_k2f0UJ9LEd2fxPczPj7-fg" name="ocl_sql">
> <ownedAttribute xmi:id="_mnvvgp9LEd2fxPczPj7-fg"
> name="base_Operation" association="_mnvvgJ9LEd2fxPczPj7-fg">
> </ownedAttribute>
> </packagedElement>
> xmi:id="_pp548J9LEd2fxPczPj7-fg" name="PK_BUSINESS_OBJECT">
> <ownedAttribute xmi:id="_rfxOYp9LEd2fxPczPj7-fg"
> name="base_Package" association="_rfxOYJ9LEd2fxPczPj7-fg">
> href="pathmap://UML_METAMODELS/UML.metamodel.uml#Package"/>
> </ownedAttribute>
> </packagedElement>
> xmi:id="_zcWDYJ9LEd2fxPczPj7-fg" name="PK_BUSINESS">
> <ownedAttribute xmi:id="_Cy7y4p9MEd2fxPczPj7-fg"
> name="base_Package" association="_Cy7y4J9MEd2fxPczPj7-fg">
> </ownedAttribute>
> </packagedElement>
> xmi:id="_Hiw_EJ9MEd2fxPczPj7-fg" name="setter">
> <ownedAttribute xmi:id="_MoNO4p9MEd2fxPczPj7-fg"
> name="base_Operation" association="_MoNO4J9MEd2fxPczPj7-fg">
> </ownedAttribute>
> </packagedElement>
> xmi:id="_PsKIEJ9MEd2fxPczPj7-fg" name="specific_impl">
> <ownedAttribute xmi:id="_SCNZcp9MEd2fxPczPj7-fg"
> name="base_Operation" association="_SCNZcJ9MEd2fxPczPj7-fg">
> </ownedAttribute>
> </packagedElement>
> <packagedElement xmi:type="uml:Extension"
> xmi:id="_9M-FYJ9KEd2fxPczPj7-fg" name="Operation_attach"
> memberEnd="_9M-FYZ9KEd2fxPczPj7-fg _9M-FYp9KEd2fxPczPj7-fg">
> <ownedEnd xmi:type="uml:ExtensionEnd"
> xmi:id="_9M-FYZ9KEd2fxPczPj7-fg" name="extension_attach"
> type="_455tsJ9KEd2fxPczPj7-fg" aggregation="composite"
> association="_9M-FYJ9KEd2fxPczPj7-fg"/>
> </packagedElement>
> xmi:id="_Db4esJ9LEd2fxPczPj7-fg" name="Operation_detach"
> memberEnd="_Db4esZ9LEd2fxPczPj7-fg _Db4esp9LEd2fxPczPj7-fg">
> xmi:id="_Db4esZ9LEd2fxPczPj7-fg" name="extension_detach"
> type="_Ayc-UJ9LEd2fxPczPj7-fg" aggregation="composite"
> association="_Db4esJ9LEd2fxPczPj7-fg"/>
> </packagedElement>
> xmi:id="_IxtT4J9LEd2fxPczPj7-fg" name="Operation_formula"
> memberEnd="_IxtT4Z9LEd2fxPczPj7-fg _IxtT4p9LEd2fxPczPj7-fg">
> xmi:id="_IxtT4Z9LEd2fxPczPj7-fg" name="extension_formula"
> type="_GpqpUJ9LEd2fxPczPj7-fg" aggregation="composite"
> association="_IxtT4J9LEd2fxPczPj7-fg"/>
> </packagedElement>
> xmi:id="_bWOX8J9LEd2fxPczPj7-fg" name="Operation_getter"
> memberEnd="_bWOX8Z9LEd2fxPczPj7-fg _bWOX8p9LEd2fxPczPj7-fg">
> xmi:id="_bWOX8Z9LEd2fxPczPj7-fg" name="extension_getter"
> type="_Vskn0J9LEd2fxPczPj7-fg" aggregation="composite"
> association="_bWOX8J9LEd2fxPczPj7-fg"/>
> </packagedElement>
> xmi:id="_h4WoMJ9LEd2fxPczPj7-fg" name="Operation_ocl_impl"
> memberEnd="_h4WoMZ9LEd2fxPczPj7-fg _h4WoMp9LEd2fxPczPj7-fg">
> xmi:id="_h4WoMZ9LEd2fxPczPj7-fg" name="extension_ocl_impl"
> type="_ezz5IJ9LEd2fxPczPj7-fg" aggregation="composite"
> association="_h4WoMJ9LEd2fxPczPj7-fg"/>
> </packagedElement>
> xmi:id="_mnvvgJ9LEd2fxPczPj7-fg" name="Operation_ocl_sql"
> memberEnd="_mnvvgZ9LEd2fxPczPj7-fg _mnvvgp9LEd2fxPczPj7-fg">
> xmi:id="_mnvvgZ9LEd2fxPczPj7-fg" name="extension_ocl_sql"
> type="_k2f0UJ9LEd2fxPczPj7-fg" aggregation="composite"
> association="_mnvvgJ9LEd2fxPczPj7-fg"/>
> </packagedElement>
> xmi:id="_rfxOYJ9LEd2fxPczPj7-fg" name="Package_PK_BUSINESS_OBJECT"
> memberEnd="_rfxOYZ9LEd2fxPczPj7-fg _rfxOYp9LEd2fxPczPj7-fg">
> xmi:id="_rfxOYZ9LEd2fxPczPj7-fg" name="extension_PK_BUSINESS_OBJECT"
> type="_pp548J9LEd2fxPczPj7-fg" aggregation="composite"
> association="_rfxOYJ9LEd2fxPczPj7-fg"/>
> </packagedElement>
> xmi:id="_Cy7y4J9MEd2fxPczPj7-fg" name="Package_PK_BUSINESS"
> memberEnd="_Cy7y4Z9MEd2fxPczPj7-fg _Cy7y4p9MEd2fxPczPj7-fg">
> xmi:id="_Cy7y4Z9MEd2fxPczPj7-fg" name="extension_PK_BUSINESS"
> type="_zcWDYJ9LEd2fxPczPj7-fg" aggregation="composite"
> association="_Cy7y4J9MEd2fxPczPj7-fg"/>
> </packagedElement>
> xmi:id="_MoNO4J9MEd2fxPczPj7-fg" name="Operation_setter"
> memberEnd="_MoNO4Z9MEd2fxPczPj7-fg _MoNO4p9MEd2fxPczPj7-fg">
> xmi:id="_MoNO4Z9MEd2fxPczPj7-fg" name="extension_setter"
> type="_Hiw_EJ9MEd2fxPczPj7-fg" aggregation="composite"
> association="_MoNO4J9MEd2fxPczPj7-fg"/>
> </packagedElement>
> xmi:id="_SCNZcJ9MEd2fxPczPj7-fg" name="Operation_specific_impl"
> memberEnd="_SCNZcZ9MEd2fxPczPj7-fg _SCNZcp9MEd2fxPczPj7-fg">
> xmi:id="_SCNZcZ9MEd2fxPczPj7-fg" name="extension_specific_impl"
> type="_PsKIEJ9MEd2fxPczPj7-fg" aggregation="composite"
> association="_SCNZcJ9MEd2fxPczPj7-fg"/>
> </packagedElement>
> <profileApplication xmi:id="_pjdvMJ9KEd2fxPczPj7-fg">
> <eAnnotations xmi:id="_pjdvMZ9KEd2fxPczPj7-fg"
> <references xmi:type="ecore:EPackage"
> href=" pathmap://UML_PROFILES/Ecore.profile.uml#_z1OFcHjqEdy8S4Cr8R c_NA"/>
> </eAnnotations>
> <appliedProfile href="pathmap://UML_PROFILES/Ecore.profile.uml#_0"/>
> </profileApplication>
> <profileApplication xmi:id="_pjngMJ9KEd2fxPczPj7-fg">
> <eAnnotations xmi:id="_pjngMZ9KEd2fxPczPj7-fg"
> href=" pathmap://UML_PROFILES/Standard.profile.uml#_yzU58YinEdqtvbn fB2L_5w"/>
> </eAnnotations>
> <appliedProfile
> href="pathmap://UML_PROFILES/Standard.profile.uml#_0"/>
> </uml:Profile>
> <Ecore:EPackage xmi:id="_qx2N4J9KEd2fxPczPj7-fg"
> base_Package="_boProfile" packageName="bo" nsPrefix="bo"
> nsURI="http://www.bluage.com/profiles/bo" prefix="bo"/>
> </xmi:XMI>
Ed Merks
Current Time: Fri Apr 26 19:11:52 GMT 2024
Powered by FUDForum. Page generated in 0.06192 seconds
