Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Snippet234, synchronized table scroll problem on OSx
Re: Snippet234, synchronized table scroll problem on OSx [message #483206 is a reply to message #483080] |
Mon, 31 August 2009 14:56 |
Grant Gayed Messages: 2150 Registered: July 2009 |
This can probably be made to work by putting each of the Tables into a
ScrolledComposite, and scrolling the ScrolledComposites with setOrigin()
since this is pixel-based. For an example that does something like this see
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet296.java?view=co .
Note that I just added a listener to this snippet that makes using the
scroll wheel work, but snippet changes sometimes take a while to replicate
on the eclipse.org servers, so if the scroll wheel does not work for you
then add the following to the snippet:
* The following listener scrolls the Tree one item at a time
* in response to MouseWheel events.
tree.addListener(SWT.MouseWheel, new Listener() {
public void handleEvent(Event event) {
Point origin = sc.getOrigin();
if (event.count < 0) {
origin.y = Math.min(origin.y + tree.getItemHeight(),
tree.getSize().y);
} else {
origin.y = Math.max(origin.y - tree.getItemHeight(), 0);
sc.setOrigin(origin);
HTH,
Grant
"Wim Jongman" <wim.jongman@gmail.com> wrote in message
news:h7f2em$2r8$1@build.eclipse.org...
> This snippet
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet234.java?view=co
> The problem is that we can pixel scroll the table but that will not be
> detected because the scroll appears to be by item as vbar.getSelection()
> indicates. If you drag the thumb pixel by pixel, the second table will
only
> jump every $itemHeight$ pixels.
> Also the left table snippet does not react on mouse scroll in osx
snippet167
> uses an alternative listener which does react on mouse scroll.
> Is there a way to get this going neatly on OSx? Blocking the pixel
scrolling
> capabilities could be one solution. Is that possible?
> Regards,
> Wim Jongman
Re: Snippet234, synchronized table scroll problem on OSx [message #483269 is a reply to message #483206] |
Mon, 31 August 2009 19:50 |
Wim Jongman Messages: 423 Registered: July 2009 |
Hi Grant,
Great idea. Thanks for the pointer. I have two side by side synched trees
which work perfectly on Windows but look terrible on the Mac. I think I can
transform the two trees as you suggested. I will post back the result.
Wim Jongman
Posted with Salvo, the Eclipse based newsreader
> tree.getSize().y);
> } else {
> HTH,
> Grant
>> Hi,
>> This snippet
> only
> snippet167
> scrolling
>> Regards,
>> Wim Jongman
Re: Snippet234, synchronized table scroll problem on OSx [message #484335 is a reply to message #483206] |
Sun, 06 September 2009 21:49 |
Hi Grant,
I have a huge problem getting this to work in combination with the
SWT.VIRTUAL style and a jface lazytree contentprovider. I tried SWT.VIRTUAL
in combination with an SWT.SetData event listener which works great. However,
when I wrap a TreeViewer around the tree, I get a lot of errors.
Any ideas on this or should I try the JFACE newsgroup.
Here is your snippet with the SWT.VIRTUAL and with a gridlayout for sizing.
Please note that the SWT.NO_SCROLL eliminates the need for the expand
listeners.
Wim
* Copyright (c) 2000, 2008 IBM Corporation and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* IBM Corporation - initial API and implementation
package org.eclipse.swt.snippets;
* ScrolledComposite snippet: use a ScrolledComposite to scroll a virtual Tree
vertically
* For a list of all SWT example snippets see
* http://www.eclipse.org/swt/snippets/
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.ScrolledComposite;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.graphics.Rectangle;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Event;
import org.eclipse.swt.widgets.Listener;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Tree;
import org.eclipse.swt.widgets.TreeItem;
public class Snippet296Virtual {
final Display display = new Display();
Shell shell = new Shell(display);
shell.setBounds(10, 10, 300, 300);
shell.setLayout(new GridLayout(1, true));
final ScrolledComposite sc = new ScrolledComposite(shell, SWT.VERTICAL);
sc.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true, true));
// sc.setBounds (10, 10, 280, 200);
final Tree tree = new Tree(sc, SWT.VIRTUAL | SWT.NO_SCROLL);
tree.addListener(SWT.SetData, new Listener() {
TreeItem item = (TreeItem) event.item;
System.out.println(tree.indexOf(item));
TreeItem parentItem = item.getParentItem();
String text = null;
if (parentItem == null) {
text = "node " + tree.indexOf(item);
} else {
text = parentItem.getText() + " - "
+ parentItem.indexOf(item);
item.setText(text);
System.out.println(text);
item.setItemCount(10);
tree.setItemCount(100);
sc.setContent(tree);
sc.setExpandHorizontal(true);
//sc.setExpandVertical(true);
final int clientWidth = shell.getClientArea().width;
System.out.println("clientwidth " + clientWidth);
int prefHeight = tree.computeSize(SWT.DEFAULT, SWT.DEFAULT).y;
System.out.println("prefHeight " + prefHeight);
tree.setSize(clientWidth, prefHeight);
* The following listener ensures that a newly-selected item in the Tree
* is always visible.
tree.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
TreeItem[] selectedItems = tree.getSelection();
if (selectedItems.length > 0) {
Rectangle itemRect = selectedItems[0].getBounds();
Rectangle area = sc.getClientArea();
if (itemRect.x < origin.x
|| itemRect.y < origin.y
|| itemRect.x + itemRect.width > origin.x
+ area.width
|| itemRect.y + itemRect.height > origin.y
+ area.height) {
sc.setOrigin(itemRect.x, itemRect.y);
* The following listener scrolls the Tree one item at a time in
* response to MouseWheel events.
origin.y = Math.min(origin.y + tree.getItemHeight(), tree
.getSize().y);
} else {
Button downButton = new Button(shell, SWT.PUSH);
downButton.setBounds(10, 220, 120, 30);
downButton.setText("Down 10px");
downButton.addListener(SWT.Selection, new Listener() {
sc.setOrigin(0, sc.getOrigin().y + 10);
Button upButton = new Button(shell, SWT.PUSH);
upButton.setBounds(140, 220, 120, 30);
upButton.setText("Up 10px");
upButton.addListener(SWT.Selection, new Listener() {
sc.setOrigin(0, sc.getOrigin().y - 10);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
> tree.getSize().y);
> } else {
> HTH,
> Grant
>> Hi,
>> This snippet
> only
> snippet167
> scrolling
>> Regards,
>> Wim Jongman
Re: Snippet234, synchronized table scroll problem on OSx [message #484852 is a reply to message #484335] |
Wed, 09 September 2009 13:55 |
It looks like the snippet you posted is the swt-only one that doesn't show
errors, so I'm not sure what the problem is that you're seeing. That being
said, if the introduction of a TreeViewer is what makes errors start
happening then the eclipse.platform.jface newsgroup could be a better place
to post the jface snippet.
Grant
news:h81apk$41b$1@build.eclipse.org...
> Hi Grant,
SWT.VIRTUAL
However,
sizing.
> listeners.
> Wim
> * Contributors:
Tree
> vertically
> import org.eclipse.swt.widgets.Display;
> public static void main(String[] args) {
> String text = null;
> } else {
> item.setText(text);
> + area.width
> + area.height) {
> .getSize().y);
> } else {
> shell.open();
> display.sleep();
> display.dispose();
> > Hi,
see
replicate
> > tree.getSize().y);
> > } else {
> > HTH,
> > Grant
> >> Hi,
> >> This snippet
vbar.getSelection()
> > only
> > snippet167
> > scrolling
> >> Regards,
> >> Wim Jongman
Current Time: Tue Sep 24 19:45:47 GMT 2024
Powered by FUDForum. Page generated in 0.04328 seconds
