Re: Using JNDI in Eclipse [message #483066 is a reply to message #482589] |
Sun, 30 August 2009 15:44 |
Originally posted by: yoduderoo.netscape.net
Since JNDI is part of the JRE, there is no reason why you can't use
JNDI. I use JNDI to access LDAP and it works fine. To use JNDI to access
an object repository on a remote app server, might require some
app-server-specific client libs.
-y
Jan Kohnert wrote:
> Hello,
> is it possible to use JNDI within eclipse?
> I want to set up my datasource using JNDI properties so my old servlets
> can use the JNDI defined datasource also they are not running within
> tomcat anymore. (Java WS running on a eclipse environment instead of Axis).
> Thanks
FUDForum. Page generated in 0.02533 seconds
