Home » Language IDEs » Java Development Tools (JDT) » headless new JavaProject from sources
headless new JavaProject from sources [message #482465] Wed, 26 August 2009 12:16 Go to next message
I need to create programatically a java project from existing sources (in
a headless environment). Just like you would if you'd go to file - new
JavaProject - select "Create project form existing source" - enter the
folder name - click finish.
I've tried something like this :
NewJavaProjectWizardPageOne p = new NewJavaProjectWizardPageOne();
NewJavaProjectWizardPageTwo p2 = new NewJavaProjectWizardPageTwo(p);
p.setProjectLocationURI(new URI(string)); // path to project
p.setProjectName("myProject");
p2.performFinish(new NullProgressMonitor());
but I get a
java.lang.NoClassDefFoundError:
org/eclipse/jdt/ui/wizards/NewJavaProjectWizardPageOne
at rcp.Application.createProject(Application.java:46)
at rcp.Application.start(Application.java:33)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
even if I add the jface jar file to the classpath with the -cp option...
Thank you,
George
Re: headless new JavaProject from sources [message #482648 is a reply to message #482465] Thu, 27 August 2009 08:47 Go to previous messageGo to next message
> (in a headless environment). Just like you would if you'd go to file -
> new JavaProject - select "Create project form existing source" - enter
> the folder name - click finish.
Wizard is UI and hence it obviously won't work in headless mode.
Dani
> but I get a
> at
> Thank you,
> George
Re: headless new JavaProject from sources [message #482774 is a reply to message #482648] Thu, 27 August 2009 17:57 Go to previous message
> Dani
Yes, but (some of) the code that creates the java project from sources is
written in the classes NewJavaProjectWizard...
So I hacked my way to a solution. I basically copied these classes (and a
couple of other classes) in the application code and changed them so that
they don't have anything to do with the UI. Then, of course, I used those
instead of the "real" ones.
George
Previous Topic:Connection to JNDI datasource
Next Topic:Using/testing Java Preferences API within Eclipse
Current Time: Thu Nov 06 22:16:45 EST 2025
Powered by FUDForum. Page generated in 0.03814 seconds
