| EMF object & propertyTester [message #482356] |
Wed, 26 August 2009 07:04   |
Eclipse User  |
In an extension definition of a popup menu contribution in the MANIFEST file (visibleWhen element), I'd like to test whether the object is a mymodel EMF instance ( myfile.mymodel file ).
Do I have to write the testProperty class or does EMF generates something that could help me ?
Is there a classical way to perform this task ?
Thanks a lot,
Cyril.
| Re: EMF object & propertyTester [message #482370 is a reply to message #482356] |
Wed, 26 August 2009 07:24    |
Eclipse User  |
--------------070500070503090203060407
Content-Type: text/plain; charset=UTF-8; format=flowed
Cyril,
You should be able to register the popup for specific types of objects,
e.g.,
      <objectContribution
            id="org.eclipse.emf.ecore.editor.CreateDynamicInstance"
           * objectClass="org.eclipse.emf.ecore.EClass">*
         <action
               id="org.eclipse.emf.ecore.editor.CreateDynamicInstanceAction "
               label="%_UI_CreateDynamicInstance_menu_item"
               menubarPath="additions"
class="org.eclipse.emf.ecore.action.CreateDynamicInstanceAction "
               enablesFor="1"/>
      </objectContribution>
Cyril Giraudon wrote:
> Hello,
> Thanks a lot,
> Cyril.
Content-Type: text/html; charset=UTF-8
<html>
<head>
  <meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Cyril,<br>
<br>
e.g.,<br>
<br>
      <objectContribution<br>
            id="org.eclipse.emf.ecore.editor.CreateDynamicInstance"<br >
           <b> objectClass="org.eclipse.emf.ecore.EClass"></b><br >
         <action<br>
id="org.eclipse.emf.ecore.editor.CreateDynamicInstanceAction "<br>
               label="%_UI_CreateDynamicInstance_menu_item"<br>
               menubarPath="additions"<br>
class="org.eclipse.emf.ecore.action.CreateDynamicInstanceAction "<br>
               enablesFor="1"/><br>
      </objectContribution><br>
<br>
<blockquote cite="mid:h734re$7v2$1@build.eclipse.org" type="cite">Hello,
  <br>
  <br>
  <br>
  <br>
  <br>
  <br>
  <br>
Thanks a lot,
  <br>
  <br>
Cyril.
  <br>
  <br>
</blockquote>
</body>
</html>
--------------070500070503090203060407--
| Re: EMF object & propertyTester [message #482462 is a reply to message #482370] |
Wed, 26 August 2009 12:13   |
Eclipse User  |
thanks Ed, but I use the command API.
I've finally succeeded with :
               <visibleWhen
                     checkEnabled="false">
                  <with
                        variable="selection">
                     <iterate
                           ifEmpty="false"
                           operator="or">
                        <and>
                           <instanceof
                                 value="org.eclipse.core.resources.IResource">
                           </instanceof>
                           <test
                                 property="org.eclipse.core.resources.extension"
                                 value="mymodel">
                           </test>
                        </and>
                     </iterate>
                  </with>
               </visibleWhen>
Cyril.
FUDForum. Page generated in 0.03459 seconds
