Re: Babel Build [message #489684 is a reply to message #489667] |
Mon, 05 October 2009 14:46 |
Stefan Stern Messages: 9 Registered: July 2009 |
Hello
We currently use the Babel packs with build id '3.5.0.v20090620043401'.
There is a bug, where the format-type string was translated into German,
which causes an Exception when opening the problems view. This bug is
known: https://bugs.eclipse.org/bugs/show_bug.cgi?id=288030 and
https://bugs.eclipse.org/bugs/show_bug.cgi?id=282139
The valid translation is available, too. There was suspicion that this
problem might occur in other places as well, and therefore the bug
wasn't solved.
Right now this causes us some trouble, thats why I edited the
message-file in the JAR of the lang-pack and repaired the corrupted string.
If you plan to build within a week or so, I will not roll out my
manually fixed JAR. If you do not plan to release a build for a while, I
will use my fixed JAR and hope the bug won't reappear in other places.
Stefan
Kit Lo schrieb:
> Stefan, Galileo (Eclipse 3.5.0) language packs should work for Galileo
> SR1 (Eclipse 3.5.1) also. The rebuild of language packs for Galileo SR1
> is just to pick up newer translations since Galileo.
> What and how did you fix the language packs manually? Can you share that
> with us? Maybe you can contribute to the Babel project?
Re: Babel Build [message #579852 is a reply to message #579836] |
Hello
wasn't solved.
Stefan
FUDForum. Page generated in 0.06660 seconds
