Home » Eclipse Projects » Eclipse Platform » Re: How to open URL contents in editor.
Re: How to open URL contents in editor. [message #481117] Wed, 19 August 2009 12:50 Go to next message
mkaditya wrote:
> Is there any way to open contents of a URL in editor instead of browser. For
> example if URL fetches XML contents i want to open it using XML editors.
Do you mean you want to do this as a user, or are you trying to
write a plug-in to do it?
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Re: How to open URL contents in editor. [message #481145 is a reply to message #481117] Wed, 19 August 2009 14:17 Go to previous messageGo to next message
I want to achieve that in WSDL editor hyperlinks.
"Nitin Dahyabhai" <nitind@us.ibm.com> wrote in message
news:h6half$aiq$1@build.eclipse.org...
>> For example if URL fetches XML contents i want to open it using XML
>> editors.
> Do you mean you want to do this as a user, or are you trying to write a
> plug-in to do it?
> Nitin Dahyabhai
> IBM Rational
Re: How to open URL contents in editor. [message #482639 is a reply to message #481145] Thu, 27 August 2009 08:21 Go to previous messageGo to next message
Putting it this way, are there any extension points which can be used to
customize code navigation ??
Regards,.
M.K.Aditya.
"mkaditya" <mkaditya@gmail.com> wrote in message
news:h6hfjt$fh1$1@build.eclipse.org...
>>> editors.
>> plug-in to do it?
>> Nitin Dahyabhai
>> IBM Rational
Re: How to open URL contents in editor. [message #482737 is a reply to message #482639] Thu, 27 August 2009 13:38 Go to previous messageGo to next message
>>>> editors.
>>> plug-in to do it?
used to
Yes, there's an extension point for contributing hyperlink
detectors: org.eclipse.ui.workbench.texteditor.hyperlinkDetectors .
You would assign your own to one of the targets supported by the
WSDL Editor, and write it so that it opens its target as you wish; I
suspect that's "org.eclipse.wst.wsdl.wsdlsource".
Nitin Dahyabhai
IBM Rational
Re: How to open URL contents in editor. [message #483355 is a reply to message #482737] Tue, 01 September 2009 06:11 Go to previous messageGo to next message
Thanx Nitin for your feedbacks. Your suggestion worked, however I ran into a
issue. Now it is showing code navigation links both for opening in
browser(which came from framework) and the one which i coded for. Is there
any way to remove the navigation links provided by the framework ?
M.K.Aditya.
news:h76ga5$2ic$2@build.eclipse.org...
>>>>> browser. For example if URL fetches XML contents i want to open it
>>>>> using XML editors.
>>>> plug-in to do it?
> used to
> Yes, there's an extension point for contributing hyperlink detectors:
> org.eclipse.ui.workbench.texteditor.hyperlinkDetectors . You would assign
> your own to one of the targets supported by the WSDL Editor, and write it
> so that it opens its target as you wish; I suspect that's
> Nitin Dahyabhai
> IBM Rational
Re: How to open URL contents in editor. [message #483996 is a reply to message #483355] Thu, 03 September 2009 16:33 Go to previous message
Not that I know of, but then I've not had a reason to try.
Nitin Dahyabhai
IBM Rational
Previous Topic:Working Set, Open - no more idalog?
Next Topic:[resources] thread safety - project occassionally programmatically invisible
Current Time: Fri Nov 07 22:53:56 EST 2025
Powered by FUDForum. Page generated in 0.04769 seconds
