Home » Archived » M2M (model-to-model transformation) » [QVTO] How to generate a trace file
Re: [QVTO] How to generate a trace file [message #480840 is a reply to message #480618] |
Tue, 18 August 2009 16:02 |
Originally posted by: dvorak.radek.gmail.com
Hi Derek,
> I am calling QVT transformations from Java. Can someone point me to the
> right API for configuring the generation of a trace file?
Not possible for now, it will be after resolution of
https://bugs.eclipse.org/bugs/show_bug.cgi?id=282645.
I can fix it next week.
> Also, are the ExecutionContext configuration properties documented
> anywhere?
Not sure I understand any specific problem you have here.
Basically, you can setup a value for a property identified by its name.
Only primitive types for configuration properties are supported.
See http://wiki.eclipse.org/QVTOML/Examples/InvokeInJava for a usage
example.
If you find anything unclear or wrong, let me know so we can fix it.
/Radek
Re: [QVTO] How to generate a trace file [message #480935 is a reply to message #480840] |
Wed, 19 August 2009 01:39 |
Derek Palma Messages: 141 Registered: July 2009 |
Hi Radek,
Regarding the configuration property question, I have no specific problem. I
just wanted to understand how they are used and what is available. I was
thinking that perhaps that is now you would configure trace file generation.
In the InvokeInJava example I did not understand what
context.setConfigProperty("keepModeling", true);
is for.
Derek
"radek dvorak" <dvorak.radek@gmail.com> wrote in message
news:op.uyu767tg12y5f2@kliste.local...
> Hi Derek,
>> anywhere?
> example.
> Regards,
> /Radek
Re: [QVTO] How to generate a trace file [message #480957 is a reply to message #480935] |
Wed, 19 August 2009 07:51 |
Hi Derek,
All configuration properties are declared in your transformation source
file.
The runtime execution takes care of values to properties binding,
in Java invocation via the ExecutionContext class.
There are no predefined configuration properties, these are only user
defined.
I think It should be clear from the OMG spec, but I can see we should not
rely too much
on the precondition that users have read it all ;).
I will try to complement the javadoc somehow.
/Radek
On Wed, 19 Aug 2009 03:39:04 +0200, Derek Palma <derek.palma@gmail.com>
wrote:
> Hi Radek,
> problem. I just wanted to understand how they are used and what is
> available. I was thinking that perhaps that is now you would configure
> is for.
> Derek
>> Hi Derek,
>>> the right API for configuring the generation of a trace file?
>>> anywhere?
>> example.
>> Regards,
>> /Radek
Re: [QVTO] How to generate a trace file [message #481059 is a reply to message #480957] |
Wed, 19 August 2009 12:59 |
Hi Radek,
I have read the Spec but can't say I remember it all... But I will search
for "configuration properties" in the spec.
Derek
news:op.uywf4spw12y5f2@kliste.local...
> Hi Derek,
> file.
> defined.
> rely too much
> /Radek
> wrote:
>> Hi Radek,
>> is for.
>> Derek
>>> Hi Derek,
>>>> anywhere?
>>> example.
>>> Regards,
>>> /Radek
Re: [QVTO] How to generate a trace file [message #481157 is a reply to message #481059] |
Wed, 19 August 2009 20:12 |
Hi Derek,
> search for "configuration properties" in the spec.
No doubts, it's pretty a multiphase reading ;). Just wanted to put things
right,
I would like to encourage users to ask whatever in this newsgroup.
At least it should help to reveal unclear, unexplained areas that
a majority of people might face. /* if not already answered in previous
posts ;) */
The 8.2.1.1 section in the spec might give an understanding of this topic.
/Radek
> Derek
>> Hi Derek,
>> file.
>> defined.
>> not rely too much
>> /Radek
>> wrote:
>>> Hi Radek,
>>> is for.
>>> Derek
>>>> Hi Derek,
>>>>> anywhere?
>>>> name.
>>>> example.
>>>> Regards,
>>>> /Radek
Current Time: Fri Apr 26 19:33:38 GMT 2024
Powered by FUDForum. Page generated in 0.08853 seconds
