Hotkey: run last run configuration? [message #480607] |
Mon, 17 August 2009 16:55  |
Originally posted by: mevanclark.hotmail.com
Hi all,
Something I do very frequently in Eclipse is re-run the most recently
run "Run Configuration." However, there does not seem to be a Command
available in Preferences->Keys so that I can create a key-binding for
this.
I resort to the mouse: using the "split button" down-arrow next to the
green "Run" button on the toolbar and selecting the first entry there.
I suppose I could also use the menu accelerators: Alt-r,t,1 but I
wouldn't mind something a little easier.
Hotkey Commands I have tried include:
"Run" (Ctrl-F11), but this runs the active file, not the most recently
run "Run Configuration." As my projects are fairly complex, I am not
usually looking at the file which contains the "main" method, so using
this hotkey would require locating and opening the class which does
contain the Main method.
There is "Run Last Launched External Tool," but I am not using
external tool configurations to launch my Java main() methods.
There is "Profile Last Launched," but I don't want to profile, I just
want to run.
There is "Rerun JUnit Test" -- which seems to do what I want, except
it's for JUnit tests, not main() methods.
So am I the only one who really reuses the same "Run Configuration"
over and over again iteratively while developing?? :-) This seems
like a no-brainer candidate for a hotkey to me, maybe I am just
missing something.
Mike
Re: Hotkey: run last run configuration? [message #480624 is a reply to message #480607] |
Mon, 17 August 2009 21:00   |
Mike Clark wrote:
> Hi all,
> this.
> want to run.
> missing something.
> Mike
This "feature" can be changed in
Window->Preferences->Run/Debug->Launching->Launch Operations. You can
choose to always run the previous application.
Re: Hotkey: run last run configuration? [message #481386 is a reply to message #480624] |
Thu, 20 August 2009 13:39  |
On Mon, 17 Aug 2009 20:00:35 -0500, David Wegener
<dpwegener@gmail.com> wrote:
>Mike Clark wrote:
>> Hi all,
That does it! Thanks very much.
Mike
FUDForum. Page generated in 0.06977 seconds
