Home » Eclipse Projects » DSDP - Target Management » Command to start a telnet terminal view on a specific machine
Command to start a telnet terminal view on a specific machine [message #480598] Mon, 17 August 2009 15:01 Go to next message
I'm using the org.eclipse.tm.terminal.telnet plugin version 2.0.1 to provide a terminal
view (telnet) in my rcp application and I would like to programmatically open a terminal
view on a specific machine using the API of the plugin. How could I do this?
Is there a command that allows this with the required arguments (ip address, user name,
password)?
Vincent
Re: Command to start a telnet terminal view on a specific machine [message #482133 is a reply to message #480598] Tue, 25 August 2009 09:19 Go to previous messageGo to next message
Anybody has idea on this question?
Re: Command to start a telnet terminal view on a specific machine [message #582262 is a reply to message #480598] Tue, 25 August 2009 09:19 Go to previous messageGo to next message
Re: Command to start a telnet terminal view on a specific machine [message #676236 is a reply to message #582262] Fri, 03 June 2011 06:42 Go to previous message
Hi Vincent,
I am also interested by this issue, did you find a solution since your post?
Thanks in advance
Ali.
Previous Topic:How launch a terminal SSH in my RCP application
Next Topic:Possible to use SystemRemoteFileDialog/SystemRemoteFolderDialog without RSE open
Current Time: Tue Nov 04 22:11:52 EST 2025
Powered by FUDForum. Page generated in 0.03623 seconds
