Exception in thubnail generation for outline view [message #480177] |
Fri, 14 August 2009 05:27  |
I am getting an exception when i close the application,
The thing is i have gef view in which i am generating a large class
diagram(1000<classes with aggrigation,realization and generalization
connections),
there is an outline view which shows the thumbnail of the relations view,
The relations view takes some time to load(pls give some advice to improve
rendering performance,the gui goes blank for some time in case of very
large no of classes),
but even after the relations view gets loaded the thumbnail view loads
slowly and is still loading,
now if i close the application i get the following exception
org.eclipse.swt.SWTException: Failed to execute runnable
(org.eclipse.swt.SWTException: Graphic is disposed)
at org.eclipse.swt.SWT.error(SWT.java:3777)
at org.eclipse.swt.SWT.error(SWT.java:3695)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:136)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
at org.eclipse.swt.widgets.Display.release(Display.java:3476)
at org.eclipse.swt.graphics.Device.dispose(Device.java:261)
ch.dgsl.iarc.application.internal.Application.start(Applicat ion.java:37)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:623)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Caused by: org.eclipse.swt.SWTException: Graphic is disposed
at org.eclipse.swt.SWT.error(SWT.java:3666)
at org.eclipse.swt.graphics.Font.getFontData(Font.java:183)
org.eclipse.draw2d.ScaledGraphics.getCachedFontData(ScaledGr aphics.java:458)
at org.eclipse.draw2d.ScaledGraphics.zoomFont(ScaledGraphics.ja va:753)
at org.eclipse.draw2d.ScaledGraphics.setLocalFont(ScaledGraphic s.java:686)
at org.eclipse.draw2d.ScaledGraphics.setFont(ScaledGraphics.jav a:638)
at org.eclipse.draw2d.Figure.paint(Figure.java:1045)
at org.eclipse.draw2d.Figure.paintChildren(Figure.java:1087)
at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1123)
at org.eclipse.draw2d.Figure.paint(Figure.java:1051)
net.java.amateras.uml.classdiagram.figure.ext.ClassFigure.pa int(ClassFigure.java:44)
at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1119)
net.java.amateras.uml.editpart.RootEditPart$1.paint(RootEdit Part.java:75)
org.eclipse.draw2d.parts.Thumbnail$ThumbnailUpdater.run(Thum bnail.java:159)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
... 18 more
How to solve this?
Also zooming is also slow how can i improve it???
Re: Exception in thubnail generation for outline view [message #481501 is a reply to message #480177] |
Fri, 21 August 2009 05:58  |
For slow performance of zoom i found the problem,
the problem was shortestpathrouter this router makes zooming scrolling and
loading also slow,
There is a hack in logic example for using shortestpathrouter but it
doesnt help in my case,
The exception is still coming any suggestions??
vijay wrote:
> connections),
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 18 more
> How to solve this?
FUDForum. Page generated in 0.24614 seconds
