Re: comparing 0.95 with 1.0 [message #479962 is a reply to message #479944] |
Thu, 13 August 2009 09:38 |
Alex Panchenko Messages: 342 Registered: July 2009 |
Hi Vlad,
DLTK 1.0 is compatible with Eclipse 3.4 (you should use appropriate
version of EMF as well).
There is no maintenance planned for 0.95, since most problems could not
be solved without changing API. And API changes require to increment
version number.
Alex
Vlad Dumitrescu wrote:
> Hi!
> I am considering porting our Erlang IDE (http://erlide.org) on DLTK, but
> am stuck on Eclipse 3.4, which means DLTK 0.95.
> I couldn't find an executive summary of things that are changed in 1.0,
> is there any?
> The big thing I notice is the use of EMF, which probably has a bunch of
> new stuff in the 3.5 release.
> Will there be any maintenance on 0.95? I suppose not, but it doesn't
> hurt to ask.
> best regards,
> Vlad
FUDForum. Page generated in 0.03105 seconds
