Home » Archived » Visual Editor (VE) » Design View
Design View [message #479770] Wed, 12 August 2009 09:23 Go to next message
I am creating an application. and I need to create fairly large SWT pages with the help of Visual Editor. So I just created Visual class using Composite. But on the design view when I resized this to length more than 3000 I got an error information that "Control is too large for picture. The picture has been clipped ".
Here's how code looks when I resized on design view.
private void initialize() {
setSize(new Point(474, 3041));
setLayout(new GridLayout());
Looks like VE have a restriction on the Figure's length on the Design view.
I have attached screenshot for reference.
Is there any way to increase the size by VE extension mechanism?
Thanks in advance!
[Updated on: Wed, 12 August 2009 09:35] by Moderator
Re: Page length [message #479796 is a reply to message #479770] Wed, 12 August 2009 10:32 Go to previous messageGo to next message
HI,
Sorry, this is a hard-coded restriction. If you try for larger than this
you run into memory restrictions. Images can only be so big, and larger
than that they just can't be made.
Sarvesh wrote:
> picture. The picture has been clipped ". Here's how code looks when I
> view. I have attached screenshot for reference.
> Thanks in advance!
Rich Kulp
Re: Page length [message #480216 is a reply to message #479796] Fri, 14 August 2009 08:13 Go to previous messageGo to next message
Thanks for reply!
can't we just compromise by increasing memory size or anything at run time?
would you be so kind to expose about the restrictions. Where is the restriction imposed? if I could override the Editor Edit part or Graphical Edit part of Widget to increase the size by 400 to 500?
Thank you so much!
-Sarvesh
Re: Page length [message #480230 is a reply to message #480216] Fri, 14 August 2009 09:23 Go to previous message
It was actually an OS limit. It didn't allow bitmaps much larger than that.
Sarvesh wrote:
> Thanks for reply!
> Thank you so much!
> -Sarvesh
Rich Kulp
Re: Page length [message #617410 is a reply to message #479796] Fri, 14 August 2009 08:13 Go to previous message
Thanks for reply!
Thank you so much!
-Sarvesh
Re: Page length [message #617411 is a reply to message #617410] Fri, 14 August 2009 09:23 Go to previous message
Sarvesh wrote:
> Thanks for reply!
> Thank you so much!
> -Sarvesh
Rich Kulp
Previous Topic:components properties pallete
Next Topic:Can't view any visual class property
Current Time: Sun Jun 15 12:15:11 EDT 2025
Powered by FUDForum. Page generated in 0.06905 seconds
