Home » Eclipse Projects » Plugin Development Environment (PDE) » Eclipse stopped treating plug-in project as a plug-in project - again!
Eclipse stopped treating plug-in project as a plug-in project - again! [message #479674] |
Tue, 11 August 2009 22:46 |
Michael Sullivan Messages: 37 Registered: July 2009 |
Member |
I posted this comment last month. Since then, I have encountered the
problem again.
I have an OSGi plug-in that I am using in Eclipse and testing in the
built-in equinox OSGi container. I'm using a bunch of other bundles with
it. At some point after closing an instance of the server, Eclipse just
decides that this isn't a bundle anymore. Other bundles that are
dependent on the exported packages say that these packages are no longer
available. The package no longer shows up in the run configuration
check-box list.
The PDE menu does not, however, give me the option of converting the
project to a plug-in project. It realizes the project already IS a
plug-in. It's the rest of the PDE that disagrees. I 've checked all of
the plugin, classpath files, etc. Is there some kind of external file,
perhaps the run-configuration file, that would contain config data
determining whether or not this project gets treated like a plug in?
It's frustrating - the only way I could fix the problem last time was make
a new plug in project under a different name and copy everything to it.
Note, this is an entirely different plug-in from the one I had problems
with in the past.
Mike
http://dev.eclipse.org/newslists/news.eclipse.platform.pde/m sg01980.html
Re: Eclipse stopped treating plug-in project as a plug-in project - again! [message #479678 is a reply to message #479674] |
Tue, 11 August 2009 23:31 |
Chris Aniszczyk Messages: 674 Registered: July 2009 |
> problem again.
> with it. At some point after closing an instance of the server, Eclipse
> just decides that this isn't a bundle anymore. Other bundles that are
> check-box list.
> make a new plug in project under a different name and copy everything to
> it.
> with in the past.
What's your .classpath file? What's in the .project file?
Let's start there to see what the problem may be. Do you have something
external (like maven) that may touch project files?
In Eclipse 3.5, the Target Platform State view should show you PDE's
view on the world (OSGi state).
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: Eclipse stopped treating plug-in project as a plug-in project - again! [message #600568 is a reply to message #479674] |
> problem again.
> check-box list.
> it.
> with in the past.
Current Time: Sat Apr 27 04:13:33 GMT 2024
Powered by FUDForum. Page generated in 0.06003 seconds
