SWT.SetData in virtual table not working when SWT.MeasureItem is added [message #479624] |
Tue, 11 August 2009 18:10 |
PM Messages: 14 Registered: July 2009 |
I have a TableViewer created with VIRTUAL flag. To this table i have added
some listeners of the following type, SWT.SetData, SWT.MeasureItem,
SWT.EraseItem, SWT.PaintItem (custom draw to display multi line in
columns. Without these listeners i am not able to display multi lines in
columns).
SWT.SetData has a logic to get more data from backend with scroll. Our
goal is to not get all the data from backend at once since this could
choke our backend servers. So we make this iterative call as the user
scrolls down.
Without custom draw listeners the SWT.SetData works fine. It is able to
calculate how many rows are visible on the viewer. Somehow when the custom
draw listeners are added (especially SWT.MeasureItem) the behaviour of
SWT.SetData changes. It keeps making iterating calls to be backend and
gets all the data and then does the calculation of how many rows to
display on the viewer.
This behaviour is causing a big problem for us. Since some of the views
have large amount of data to display. When the TableViewer is created it
takes a long time for the view to display since it keeps making call to
get data from backend. Can anyone explain whats causing this behaviour.
Any co-relation between the SWT.SetData and SWT.MeasureItem listeners? I
have some code snippets below to explain the problem.
Priyanka
private void createTable ()
GridData gridData = new GridData(GridData.FILL_BOTH);
gridData.horizontalSpan = 4;
gridData.verticalSpan=2;
gridData.heightHint=350;
gridData.grabExcessHorizontalSpace = true;
gridData.grabExcessVerticalSpace = true;
gridData.horizontalAlignment = SWT.FILL;
gridData.verticalAlignment = SWT.FILL;
tabViewer = new TableViewer(parent, SWT.VIRTUAL | SWT.BORDER |
SWT.V_SCROLL | SWT.H_SCROLL | SWT.MULTI | SWT.FULL_SELECTION);
tabViewer.getTable().setLayoutData(gridData);
int i=0;
for (Iterator<ColumnAttributes> itr = columns.iterator();
itr.hasNext();i++)
ColumnAttributes colObj = itr.next();
TableViewerColumn column = new TableViewerColumn(tabViewer,
colObj.getColumnStyle());
column.getColumn().setWidth(colObj.getColumnWidth());
column.getColumn().setText(colObj.getColumnName());
column.getColumn().setMoveable(colObj.getColumnMoveable());
} //end for loop
if (this.contentProvider != null) {
this.tabViewer.setContentProvider(contentProvider);
else
tabViewer.setContentProvider(new TopsContentProvider());
if (this.labelProvider != null)
tabViewer.setLabelProvider(labelProvider);
else
tabViewer.setLabelProvider(new TopsLabelProvider());
tabViewer.setUseHashlookup(true);
// call to get backend data
if (daoComponent != null) {
if (this.dataAdapter != null)
model = this.dataAdapter.getData(0);
else
model = daoComponent.getData(0);
else
model = new java.util.ArrayList<ITopsModelObject>();
tabViewer.setInput(model);
tabViewer.getTable().setLinesVisible(true);
tabViewer.getTable().setHeaderVisible(true);
tabViewer.getTable().getVerticalBar().setEnabled(true);
tabViewer.getTable().getHorizontalBar().setEnabled(true);
tabViewer.getControl().setEnabled(true);
tabViewer.refresh();
final Table table = tabViewer.getTable();
// Provide the callback handler--this handler
// is invoked when the table needs new rows
tabViewer.getTable().addListener(SWT.SetData, new Listener() {
public void handleEvent(Event event) {
int rowIndex = table.indexOf((TableItem)event.item);
TableItem row = table.getItem(rowIndex);
Object dataRow = model.get(rowIndex);
/* This logic is added to get more data from back end. In most
cases
* services return only finite subset of data.
* Model gets updated every time after making subsequent service
calls.
* DAO Component holds the max count a model can hold. If the max
count
* is reached or no more data, fetch data call is no longer made.
if ( ((rowIndex+1) == (model.size())) && getMoreDataFlag()) {
int modelLengthBefore = model.size();
List<ITopsModelObject> newModel;
if (dataAdapter != null)
newModel = dataAdapter.getData(rowIndex+1);
else
newModel = daoComponent.getData(rowIndex + 1);
// ideally Lists should never be returned as null
if (newModel == null || (newModel.size() ==
modelLengthBefore) )
setMoreDataFlag(false);
else {
updateModel(newModel);
row.setData(dataRow);
table.addListener(SWT.MeasureItem, new Listener() {
TableItem item = (TableItem)event.item;
String text = item.getText(event.index);
// this if clause is added for non-text items like image. For
some reason
// item.getImage() is returning null for checkbox cell editors.
We dont
// want to repaint the images.
if (text != null && !text.equals("")) {
Point size = event.gc.textExtent(text);
event.width =
tabViewer.getTable().getColumn(event.index).getWidth();
int lines = size.x / (event.width + 1);
event.height = Math.max(event.height, size.y + lines);
table.addListener(SWT.EraseItem, new Listener() {
event.detail &= ~SWT.FOREGROUND;
table.addListener(SWT.PaintItem, new Listener() {
event.gc.drawText(text, event.x, event.y, true);
public void updateModel(List<ITopsModelObject> newModel)
setMoreDataFlag(true);
this.model = newModel;
this.tabViewer.setInput(model);
tabViewer.setItemCount(model.size());
this.tabViewer.refresh();
//packColumns();
Re: SWT.SetData in virtual table not working when SWT.MeasureItem is added [message #482160 is a reply to message #479624] |
Tue, 25 August 2009 14:47 |
Grant Gayed Messages: 2150 Registered: July 2009 |
Hi, sorry for the late reply,
The use of SWT.VIRTUAL and the custom draw callbacks should not interfere
with each other. I did a quick swt-only test of this and it seems to work
fine (tried on win2000).
My guess is that the TableViewer is getting confused because you're hooking
some callbacks, such as the custom draw callbacks, on the underlying Table.
The viewer provides facilities for doing all of this at the jface level, and
I think it expects them to be used. See if the snippets below are helpful,
and if not then you may wish to re-ask this on the eclipse.platform.jface
newsgroup.
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet029VirtualTableViewer.java?view=markup
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet010OwnerDraw.java?revision=1.8&view=mar kup
HTH,
Grant
"PM " <priyanka.mitra@etrade.com> wrote in message
news:e310c097c4f4054884e409d951fee2e8$1@www.eclipse.org...
> columns).
> scrolls down.
> Regards
> Priyanka
> int i=0;
> itr.hasNext();i++)
> } //end for loop
> else
> else
> else
> else
> cases
> calls.
> count
> else
> else {
> some reason
> We dont
> event.width =
> //packColumns();
FUDForum. Page generated in 0.03719 seconds
