Home » Modeling » M2T (model-to-text transformation) » [MTL] the emtl-file([MTL] the emtl-file)
[MTL] the emtl-file [message #479575] |
Tue, 11 August 2009 11:40  |
Can anybody tell me anything about the generate.emtl-file within MTL projects? It is missing now and then. Where does it come from and where is it used for?
Siegfried
Re: [MTL] the emtl-file [message #480772 is a reply to message #480065] |
Tue, 18 August 2009 08:48   |
--------------090902050707000403090608
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi Siegfried,
As Guillaume found out, the emtl file is a compiled version of the .mtl
template. This is the file that's used by the engine for the generation,
the .mtl being no more than the source.
It sometime happens for this file to be missing when the java builder
decided to delete everything contained within the "bin" folder; it does
it on a regular basis. You will then need to either force a save of your
mtl file or use Project => clean... => <your mtl project(s)> for the
emtl files to be compiled anew. This has been fixed in the 0.8 version,
which you should obviously use to avoid a fair number of issues.
The absence of the builder most probably comes from your using version
0.7 as well.
Laurent Goubet
Obeo
Siegfried a écrit :
> As far as I found out, I don't need this buildCommand. Sorry Guillaume.
> My case is a bit tricky, I've got a workaround now, yet no solution:
> First of all let's change to the MTL-perspective (I'm not sure, whether
> I've worked with it all the time, and I'm not sure whether I need to.)
> So editing and saving syntactivally correct mtl-files will deliver a
> emtl-file somehow. Somehow I happend to get no emtl-file. I don't know
> why. Maybe the MTL-perspective. Though this leads to a modification of
> the tasks/generate.xml (ant-file) as well - a reset to the former
> values. My editing this file (ECCLIPSE_HOME and ECLIPSE_WORKSPACE) has
> been gone. That leads to a ant-build error:
> generate:
> [java] java.lang.NoClassDefFoundError:
> org/eclipse/emf/ecore/resource/ResourceSet
> Maybe it's a bit more elegant to start this transformation as Java
> application. Anyway thanks for help,
> Siegfried
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
YmVnaW46dmNhcmQNCmZuOkxhdXJlbnQgR291YmV0DQpuOkdvdWJldDtMYXVy ZW50DQpvcmc6
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyLyI+T2JlbzwvYT4NCmVtYWls O2ludGVybmV0
OmxhdXJlbnQuZ291YmV0QG9iZW8uZnINCnVybDpodHRwOi8vd3d3Lm9iZW8u ZnINCnZlcnNp
b246Mi4xDQplbmQ6dmNhcmQNCg0K
--------------090902050707000403090608--
Re: [MTL] the emtl-file [message #501005 is a reply to message #500969] |
Mon, 30 November 2009 11:24   |
--------------060101040009070205080304
Andre,
Please don't dig up old threads without leaving at least the last reply
in your answer, reading this through a newsreader, I had no idea what
you were talking about and had to go on the forum to find out :p.
As for your issue, there can be a number of reasons :
a) you told eclipse to clean your workspace at launch, didn't call
"build all" and are not in automatic build
b) you haven't got the Acceleo builder mentionned in your project's
..project file
c) you still have Acceleo 0.7 installed and Eclipse messes up, loading
this instead of the newer 0.8 builds
d) your mtl files are not contained in a source folder
e) you simply are not in automatic build mode
If none of the above is true, we'll need an example on which we can
reproduce this behavior to have a chance at fixing the issue; as we
haven't observed this bug in either one of our projects since the
release of 0.8.
Laurent Goubet
Obeo
Andre wrote:
> Hi Laurent
> I think this problem persists on 0.8 version. Everytime i reopen
> Eclipse, the .mtl files doesn't compile, accusing error on .emtl file.
> To solve this, i need to clean the project.
> cheers,
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyIj5PYmVvPC9hPg0KZW1haWw7 aW50ZXJuZXQ6
bGF1cmVudC5nb3ViZXRAb2Jlby5mcg0KdXJsOmh0dHA6Ly93d3cub2Jlby5m cg0KdmVyc2lv
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------060101040009070205080304--
Re: [MTL] the emtl-file [message #501299 is a reply to message #501005] |
Tue, 01 December 2009 14:14   |
Hi Laurent
Sorry for not leaving the last reply...
Lets go:
- The 'build automatically' option is checked on my workspace
- The acceleo version installed on my PC is: Acceleo (Incubation) 0.8.0.v200906161003 org.eclipse.acceleo.feature.group
- I think the Acceleo Builder is installed, because it is listed on Properties->Buildes and it builds the files after the clean operation. How can i know this for sure?
- My .mtl file is on source folder. When i've created the Acceleo Module Project, the .mtl file was automatically saved on src file, and in fact it is there.
- The Eclipse version installed is:
Domain-Specific Language (DSL) Toolkit
Modeling Amalgamation Project
Version: 1.0.0
Build id: 20090703-0844
The problem is: when i open the workspace, there is no error on .mtl files. When i update and save any mtl, this error appears in all files: 'Metamodel couldnt be resolved'. To solve this, i need to just open a model of the metamodel used on mtl, and then clean the project. All the erros dissapear.
The model i need to open is located on other project, but on the same workspace as the .mtl files. The metamodel is customized, and defined by myself.
thanks,
Andre
Your last reply:
Andre,
you were talking about and had to go on the forum to find out .
..project file
release of 0.8.
Laurent Goubet
Obeo
Re: [MTL] the emtl-file [message #501412 is a reply to message #501299] |
Wed, 02 December 2009 04:00   |
--------------010109050206040909010607
Hi Andre,
Acceleo does not handle (yet) usage of workspace-defined metamodels.
This functionality will only see its way in the code for the M5 or M6
release.
It will work after you load a model defined with this metamodel as
loading it will register the needed packages in the package registry.
Laurent Goubet
Obeo
Andre wrote:
> Hi Laurent
> Lets go:
> it is there.
> - The Eclipse version installed is: Domain-Specific Language (DSL) Toolkit
> Version: 1.0.0
> erros dissapear.
> myself.
> thanks,
> Andre
> Your last reply:
> Andre,
> .project file
> release of 0.8.
> Laurent Goubet
> Obeo
--------------010109050206040909010607--
Re: [MTL] the emtl-file [message #501555 is a reply to message #501412] |
Wed, 02 December 2009 13:58  |
Laurent
thanks for answering one more time..
another problem i've found is: i use a common.mtl file to save my common templates, and some of these templates are not accessable on other .mtl file, even importing the common.mtl. When i paste these templates that are not accessable on the second mtl, everything works fine.
Is there any limitation about saving templates on an .mtl used as import on other files?
These templates manipulate EClasses from my custom metamodel.
thanks
Current Time: Thu Sep 25 09:00:43 EDT 2025
Powered by FUDForum. Page generated in 0.05843 seconds
