Home » Modeling » UML2 » get the value of a stereotype's attribute
get the value of a stereotype's attribute [message #478662] Tue, 04 August 2009 10:56 Go to next message
I have created a uml profile with a stereotype s which have a property p
without a specific value.
Then I have created a model with a class c with the stereotype s. I have
given the value 100 to the property p.
Then I would like to get the value 100 in a java programm.
I have load my uml model in java, I succeed in getting uml elements with
the stereotype s.
But I don't succeed in having the property's value of the stereotype. How
it is possible?
If someone can help me, Thank you
Aurelie
Re: get the value of a stereotype's attribute [message #478663 is a reply to message #478662] Tue, 04 August 2009 11:18 Go to previous messageGo to next message
Hi Aurelie,
What methods are you using to access the property?
Element.getValue(stereotype,propertyName) ???
Tas
"guenin " <au.guenin@laposte.net> wrote in message
news:d7ef2ef525f749eedd8c04d9c81c94a4$1@www.eclipse.org...
> the stereotype s.
> it is possible?
> Aurelie
Re: get the value of a stereotype's attribute [message #478667 is a reply to message #478663] Wed, 05 August 2009 02:32 Go to previous message
Hi Tas,
Thank you for your quick response. I searched a function in stereotype
interface(after using Element. getStereotype) and not in the element
interface!
The function element.getvalue(stereotype, propertyValue) is what I wanted
Aurélie
Re: get the value of a stereotype's attribute [message #627843 is a reply to message #478662] Tue, 04 August 2009 11:18 Go to previous message
Hi Aurelie,
Tas
> the stereotype s.
> it is possible?
> Aurelie
Re: get the value of a stereotype's attribute [message #627847 is a reply to message #478663] Wed, 05 August 2009 02:32 Go to previous message
Hi Tas,
interface!
Aurélie
Previous Topic:How to deal with uml model fragments?
Next Topic:EvaluationException : Couldn't resolve type for 'Persistence::Entity'. Did you f
Current Time: Wed Nov 05 14:37:39 EST 2025
Powered by FUDForum. Page generated in 0.03637 seconds
