| Multiple Inheritance: select which Impl java class will be used as superclass [message #478300] |
Mon, 13 April 2009 10:30  |
Hello all,
I have a class (CustomElement) that inherits from PackageElement and from
one of my classes (BaseCustomElement). When CustomElementImpl is
generated, it has PackageableElement as superclass. Is there a way to
instruct the generator to use BaseCustomElementImplo as superclass?
Thanks in advance.
Cristi.
| Re: Multiple Inheritance: select which Impl java class will be used as superclass [message #478323 is a reply to message #478300] |
Thu, 23 April 2009 15:15  |
Cristian,
If to set a keyword of "extend" on a generalization using
Element#addKeyword(String), the general class will become the base
superclass when the UML model is converted to Ecore.
Kenn
"Cristian " <cristian607@yahoo.com> wrote in message
news:c97ef971080974a5deacb5743bc80dbe$1@www.eclipse.org...
> Hello all,
> Thanks in advance.
> Best regards,
> Cristi.
| Re: Multiple Inheritance: select which Impl java class will be used as superclass [message #627495 is a reply to message #478300] |
Wed, 15 April 2009 11:27  |
Hi Cristian,
If you change the order of the ESuper Types in the ecore representation of
CustomElement such that BaseCustomElement appears first then it should work.
Select the 'CustomElement' in the tree view, then from the properties view
select 'ESuper Types' field. Use the 'Up' & 'Down' keys from the property
dialog to change the order.
- James.
> Hello all,
> Thanks in advance.
> Best regards,
> Cristi.
| Re: Multiple Inheritance: select which Impl java class will be used as superclass [message #627496 is a reply to message #478305] |
Wed, 15 April 2009 11:34  |
.... from the .uml model, you can reorder your generalizations such that the
one for BaseCustomElement appears first using drag/drop in the tree editor.
When it comes time to convert the .uml model to .ecore, you will see an
option labeled 'Super Class Order'. Simply choose either 'ignore' or
'report' but *not* 'process'. If you choose 'process' it may reorder the
superclass order to optimize for code generation.
- James.
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:gs4u7f$959$1@build.eclipse.org...
> Hi Cristian,
> work.
> property dialog to change the order.
> Cheers,
> - James.
>> Hello all,
>> Thanks in advance.
>> Best regards,
>> Cristi.
| Re: Multiple Inheritance: select which Impl java class will be used as superclass [message #627512 is a reply to message #478300] |
Cristian,
Kenn
> Hello all,
> Thanks in advance.
> Best regards,
> Cristi.
FUDForum. Page generated in 0.04771 seconds
