| Problems applying a particular stereotype:java.lang.NullPointerException at EStructuralFeatureImpl. [message #478256] |
Thu, 26 March 2009 08:23  |
<html>
<head>
</head>
Hello everybody.<br>
I'm having problems trying to apply a particular stereotype (the
"Overrides" stereotype from the Theme/UML profile:
<a class="moz-txt-link-freetext" href=" https://www.cs.tcd.ie/Eamonn.Linehan/lero/ThemeUML.profile.u ml"> https://www.cs.tcd.ie/Eamonn.Linehan/lero/ThemeUML.profile.u ml</a>).<br>
The rest of the stereotypes I used applied correctly with no problems,
but each time I try to use "Overrides" I get the following error
(independently of the type of element I'm applying it to):<br>
<font color="#ffff00"><br>
<font color="#3333ff">java.lang.NullPointerException<br>
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSetting Delegate(EStructuralFeatureImpl.java:814) <br>
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate (BasicEObjectImpl.java:1532) <br>
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicIsSet(Ba sicEObjectImpl.java:1268) <br>
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:1250) <br>
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:1235) <br>
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.shouldSaveFeature (XMLSaveImpl.java:1194) <br>
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1232) <br>
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:2667) <br>
org.eclipse.emf.ecore.xmi.impl.XMISaveImpl.writeTopObjects(X MISaveImpl.java:90) <br>
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:592) <br>
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:256) <br>
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:205) <br>
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:1344) <br>
org.eclipse.emf.ecore.resource.impl.ResourceImpl.saveOnlyIfC hangedWithMemoryBuffer(ResourceImpl.java:1120) <br>
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:973) <br>
org.eclipse.uml2.uml.editor.presentation.UMLEditor$14.execut e(UMLEditor.java:1400) <br>
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:104) <br>
org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1800) <br>
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:116) <br>
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121) </font></font><br>
<br>
Which could be the reason?, perhaps the profile was made with a
different version of UML2/EMF/Eclipse?.<br>
Any suggestions would be greatly appreciated.<br>
Regards,<br>
Juan Pedro<br>
<br>
</body>
</html>
| Re: Problems applying a particular stereotype:java.lang.NullPointerException at EStructuralFeatureI [message #478260 is a reply to message #478256] |
Thu, 26 March 2009 09:00   |
--------------060009000704040606030202
Juan,
My guess would be an ill formed profile where there is a feature without
a type. The validator ought to catch that, so be sure to validate the
profile. If you set a breakpoint for this exception, you'll know which
feature is causing the problem.
Juan Pedro Silva wrote:
> Hello everybody.
> https://www.cs.tcd.ie/Eamonn.Linehan/lero/ThemeUML.profile.u ml).
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Juan Pedro
<html>
<head>
</head>
Juan,<br>
<br>
without a type. The validator ought to catch that, so be sure to
validate the profile. If you set a breakpoint for this exception,
you'll know which feature is causing the problem.<br>
<br>
<br>
<blockquote cite="mid:gqfs3c$auc$1@build.eclipse.org" type="cite">Hello
everybody.<br>
<a moz-do-not-send="true" class="moz-txt-link-freetext"
<br>
Regards,<br>
Juan Pedro<br>
<br>
</blockquote>
</body>
</html>
--------------060009000704040606030202--
| Re: Problems applying a particular stereotype:java.lang.NullPointerException at EStructuralFeatureI [message #478262 is a reply to message #478260] |
Thu, 26 March 2009 10:01  |
<html>
<head>
</head>
Thanks Ed, you were right, as usual.<br>
There are two feature with no types in the profile.<br>
Regards,<br>
Juan Pedro<br>
<br>
Ed Merks escribió:
<blockquote cite="mid:gqfu8t$kk5$1@build.eclipse.org" type="cite">
Juan,<br>
<br>
<br>
<br>
everybody.<br>
"Overrides" stereotype from the Theme/UML profile: <a
<br>
Regards,<br>
Juan Pedro<br>
<br>
</blockquote>
</blockquote>
</body>
</html>
| Re: Problems applying a particular stereotype:java.lang.NullPointerException at EStructuralFeatureI [message #627451 is a reply to message #478256] |
Juan,
> Hello everybody.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Juan Pedro
<html>
<head>
</head>
Juan,<br>
<br>
<br>
<br>
everybody.<br>
<br>
Regards,<br>
Juan Pedro<br>
<br>
</blockquote>
</body>
</html>
| Re: Problems applying a particular stereotype:java.lang.NullPointerException at EStructuralFeatureI [message #627453 is a reply to message #478260] |
<html>
<head>
</head>
Regards,<br>
Juan Pedro<br>
<br>
Juan,<br>
<br>
<br>
<br>
everybody.<br>
<br>
Regards,<br>
Juan Pedro<br>
<br>
</blockquote>
</blockquote>
</body>
</html>
FUDForum. Page generated in 0.03829 seconds
