Re: Loading Model from Enterprise architect [message #478219 is a reply to message #478218] |
Fri, 06 March 2009 13:34 |
Just my two cents on this item.
I have already done the exercice to load a UML model exported in XMI
from EA and I had to replace some keywords so that it can be accepted by
Eclipse UML2 editor.
Seems that EA is not really conformant to UML2 specification. Probably
because they have to deal with compatibility from 1.X relases for their
customers.
regards
raphaël
Kenn Hussey a écrit :
> Anand,
> There's a problem with the XMI you are trying to load - it has a number of
> 'defaultValue' elements with unspecified type. Since the type of
> Property::defaultValue, ValueSpecification, is abstract, a specific type
> must be specified; otherwise, an attempt it made to instantiate the abstract
> type, hence the exception.
> Kenn
> "Anand Soddy" <anand.soddy@in.bosch.com> wrote in message
> news:adb56c15888d466f4baf3b4ebd6e70c2$1@www.eclipse.org...
>> Hello James,
>> Thanks for your reply.
>> Here is the XMI content. I could not find the way to attach the file.
>> I am getting the following error when i load xmi in UML Model editor.
>> Please help me in this. I am struck up with this problem.
>> java.lang.IllegalArgumentException: The class 'ValueSpecification' is not
>> a valid classifier
>> at
>> org.eclipse.uml2.uml.internal.impl.UMLFactoryImpl.create(UML FactoryImpl.java:681)
>> at
>> org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.createObject(XM LHelperImpl.java:871)
>> at
>> org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.createObject(XM LHelperImpl.java:920)
>> at
>> org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFa ctory(XMLHandler.java:2171)
>> at
>> org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFe atureType(XMLHandler.java:2144)
>> at
>> org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHa ndler.java:2020)
>> at
>> org.eclipse.emf.ecore.xmi.impl.XMIHandler.createObject(XMIHa ndler.java:131)
>> at
>> org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1799)
>> at
>> org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1023)
>> at
>> org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:87)
>> at
>> org.eclipse.uml2.uml.internal.resource.XMI2UMLHandler.proces sElement(XMI2UMLHandler.java:103)
>> at
>> org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:1001)
>> at
>> org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
>> at
>> org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:167)
>> at
>> com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown
>> Source)
>> at
>> com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocume ntParser.emptyElement(Unknown
>> Source)
>> at
>> com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(Unknown
>> Source)
>> at
>> com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDispatcher.dispatch(Unknown
>> Source)
>> at
>> com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
>> Source)
>> at
>> com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
>> Source)
>> at
>> Source)
>> at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
>> Source)
>> at
>> com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
>> Source)
>> at javax.xml.parsers.SAXParser.parse(Unknown Source)
>> at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
>> at
>> org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
>> at
>> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1445)
>> at
>> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1241)
>> at
>> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
>> at
>> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
>> at
>> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
>> at
>> org.eclipse.uml2.uml.editor.presentation.UMLEditor.createMod elGen(UMLEditor.java:926)
>> at
>> org.eclipse.uml2.uml.editor.presentation.UMLEditor.createMod el(UMLEditor.java:971)
>> at
>> org.eclipse.uml2.uml.editor.presentation.UMLEditor.createPag es(UMLEditor.java:1058)
>> at
>> org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:310)
>> at
>> org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
>> at
>> org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
>> at
>> org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
>> at
>> org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:266)
>> at
>> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2820)
>> at
>> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2729)
>> at
>> org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2721)
>> at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2673)
>> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
>> at
>> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2668)
>> at
>> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2652)
>> at
>> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2643)
>> at org.eclipse.ui.ide.IDE.openEditor(IDE.java:646)
>> at org.eclipse.ui.ide.IDE.openEditor(IDE.java:605)
>> at
>> org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:318)
>> at
>> org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:160)
>> at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:22 8)
>> at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:20 7)
>> at
>> org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:274)
>> at
>> org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:250)
>> at
>> org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:363)
>> at
>> org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 5.open(PackageExplorerPart.java:603)
>> at
>> org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:820)
>> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
>> at org.eclipse.core.runtime.Platform.run(Platform.java:880)
>> at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
>> at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
>> at
>> org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:818)
>> at
>> org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1079)
>> at
>> org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1183)
>> at
>> org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
>> at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
>> at
>> org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
>> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
>> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
>> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
>> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
>> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
>> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
>> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
>> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
>> at
>> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
>> at
>> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
>> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
>> at
>> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
>> at
>> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
>> at
>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
>> at
>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
>> at
>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
>> at
>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>> at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
>> at java.lang.reflect.Method.invoke(Unknown Source)
>> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
>> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
>> at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
>> I am pasting the file contents here:
>> <?xml version="1.0" encoding="windows-1252"?>
>> <xmi:XMI xmi:version="2.1" xmlns:uml="http://schema.omg.org/spec/UML/2.1"
>> xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
>> xmlns:thecustomprofile="http://www.sparxsystems.com/profiles/thecustomprofile/1.0">
>> <xmi:Documentation exporter="Enterprise Architect" exporterVersion="6.5"/>
>> <uml:Model xmi:type="uml:Model" name="EA_Model" visibility="public">
>> <packagedElement xmi:type="uml:Package"
>> xmi:id="EAPK_CD825798_C93A_4035_82E5_AEC56D9DF236" name="Model"
>> xmi:id="EAPK_1F199D3E_F346_422d_9D3E_154CFAF09C77" name="Sample"
>> <packagedElement xmi:type="uml:Class"
>> xmi:id="EAID_1AE191F0_1502_475e_922B_0D92E48C0FBF" name="ABC.c"
>> <ownedAttribute xmi:type="uml:Property"
>> xmi:id="EAID_322327E9_C4CC_4941_AB10_AC127CA6DEC4" name="UB"
>> visibility="private" isStatic="true" isDerived="false">
>> <lowerValue xmi:type="uml:LiteralInteger"
>> xmi:id="EAID_LI000001_C4CC_4941_AB10_AC127CA6DEC4" value="1"/>
>> <upperValue xmi:type="uml:LiteralInteger"
>> xmi:id="EAID_LI000002_C4CC_4941_AB10_AC127CA6DEC4" value="1"/>
>> </ownedAttribute>
>> xmi:id="EAID_87E66664_4B01_4ecd_8EA4_A10DCB13CFCD" name="UL"
>> xmi:id="EAID_LI000003_4B01_4ecd_8EA4_A10DCB13CFCD" value="1"/>
>> xmi:id="EAID_LI000004_4B01_4ecd_8EA4_A10DCB13CFCD" value="1"/>
>> </ownedAttribute>
>> <ownedOperation xmi:id="EAID_07A8A26F_1436_4f35_8726_673CA5AAE937"
>> name="eV" visibility="public" concurrency="sequential"/>
>> <ownedOperation xmi:id="EAID_EAFA9516_8FA3_43cc_B12B_EED12E9A6442"
>> name="V" visibility="public" concurrency="sequential"/>
>> <ownedOperation xmi:id="EAID_FD8BC5FA_5BFD_48d1_8F30_EA5B172ABED4"
>> name="V2" visibility="public" concurrency="sequential"/>
>> </packagedElement>
>> <packagedElement xmi:type="uml:Dependency"
>> xmi:id="EAID_00761287_6260_4e76_8F06_E94E95866688" visibility="public"
>> supplier="EAID_B9C9BA44_30FD_4b5d_AB3F_D4AD3936F1A9"
>> client="EAID_1AE191F0_1502_475e_922B_0D92E48C0FBF"/>
>> xmi:id="EAID_828E1DD7_5321_4b7a_9EAC_09F1EA8FD65A" visibility="public"
>> supplier="EAID_0AEA91B6_60B8_4044_9552_123705B7C497"
>> xmi:id="EAID_889E9CB6_2B18_4794_BAD9_FAD0C2F9AE26" visibility="public"
>> supplier="EAID_90FD549A_5C50_4bb5_88C6_F7A80B3FDE2B"
>> xmi:id="EAID_9F76A730_FCDB_45db_A6C2_3F46CB1AB37F" visibility="public"
>> supplier="EAID_6C8CD667_59E4_42b6_98F4_85F460E6282B"
>> xmi:id="EAID_F7890F02_791A_48a3_8424_88EBE18E5AEC" visibility="public"
>> supplier="EAID_524570EC_00AA_48ce_9798_633F4D0FAF92"
>> <packagedElement xmi:type="uml:Interface"
>> xmi:id="EAID_90FD549A_5C50_4bb5_88C6_F7A80B3FDE2B" name="CFG.h"
>> visibility="public" isAbstract="true">
>> xmi:id="EAID_8E79DFF3_E860_4f4e_9E82_80D4C809FFA5" name="a"
>> visibility="public" isStatic="true" isDerived="false">
>> xmi:id="EAID_LI000005_E860_4f4e_9E82_80D4C809FFA5" value="1"/>
>> xmi:id="EAID_LI000006_E860_4f4e_9E82_80D4C809FFA5" value="1"/>
>> </ownedAttribute>
>> xmi:id="EAID_2BD709F5_46CC_4ba7_BA2A_A390B4F2290E" name="b"
>> xmi:id="EAID_LI000007_46CC_4ba7_BA2A_A390B4F2290E" value="1"/>
>> xmi:id="EAID_LI000008_46CC_4ba7_BA2A_A390B4F2290E" value="1"/>
>> </ownedAttribute>
>> xmi:id="EAID_BBCF6B47_C248_49a1_9D2D_54A397102AE7" name="c"
>> xmi:id="EAID_LI000009_C248_49a1_9D2D_54A397102AE7" value="1"/>
>> xmi:id="EAID_LI000010_C248_49a1_9D2D_54A397102AE7" value="1"/>
>> </ownedAttribute>
>> xmi:id="EAID_6A209E19_BD07_4cc8_8EF1_ED22ED79CAE5" name="e"
>> xmi:id="EAID_LI000011_BD07_4cc8_8EF1_ED22ED79CAE5" value="1"/>
>> xmi:id="EAID_LI000012_BD07_4cc8_8EF1_ED22ED79CAE5" value="1"/>
>> </ownedAttribute>
>> xmi:id="EAID_8DD41F45_04A0_47e2_B70F_1393CC8D2CAF" name="f"
>> xmi:id="EAID_LI000013_04A0_47e2_B70F_1393CC8D2CAF" value="1"/>
>> xmi:id="EAID_LI000014_04A0_47e2_B70F_1393CC8D2CAF" value="1"/>
>> </ownedAttribute>
>> xmi:id="EAID_B843386C_4FBB_445b_A019_CE229198B1C4" name="g"
>> xmi:id="EAID_LI000015_4FBB_445b_A019_CE229198B1C4" value="1"/>
>> xmi:id="EAID_LI000016_4FBB_445b_A019_CE229198B1C4" value="1"/>
>> </ownedAttribute>
>> xmi:id="EAID_64D3FB86_C07A_411d_A177_5DA0C97B5A44" name="h"
>> xmi:id="EAID_LI000017_C07A_411d_A177_5DA0C97B5A44" value="1"/>
>> xmi:id="EAID_LI000018_C07A_411d_A177_5DA0C97B5A44" value="1"/>
>> </ownedAttribute>
>> xmi:id="EAID_0D9C4ABF_572C_47ce_BF3B_750590F4EFC2" name="i"
>> xmi:id="EAID_LI000019_572C_47ce_BF3B_750590F4EFC2" value="1"/>
>> xmi:id="EAID_LI000020_572C_47ce_BF3B_750590F4EFC2" value="1"/>
>> </ownedAttribute>
>> xmi:id="EAID_B5B0700B_E483_4f0a_AA77_3AFF7E9C10F9" name="j"
>> xmi:id="EAID_LI000021_E483_4f0a_AA77_3AFF7E9C10F9" value="1"/>
>> xmi:id="EAID_LI000022_E483_4f0a_AA77_3AFF7E9C10F9" value="1"/>
>> </ownedAttribute>
>> </packagedElement>
>> xmi:id="EAID_FE29440B_60A9_4b9e_921D_5859BC0DBF3F" visibility="public"
>> client="EAID_90FD549A_5C50_4bb5_88C6_F7A80B3FDE2B"/>
>> xmi:id="EAID_B9C9BA44_30FD_4b5d_AB3F_D4AD3936F1A9" name="Gs.H"
>> xmi:id="EAID_CF61D5D9_0DC8_422e_B169_DD92BA2F731F" name="PST"
>> xmi:id="EAID_LI000023_0DC8_422e_B169_DD92BA2F731F" value="1"/>
>> xmi:id="EAID_LI000024_0DC8_422e_B169_DD92BA2F731F" value="1"/>
>> </ownedAttribute>
>> xmi:id="EAID_C4373B66_03F4_46e2_94EA_9DE519CC3AF4" name="ST"
>> xmi:id="EAID_LI000025_03F4_46e2_94EA_9DE519CC3AF4" value="1"/>
>> xmi:id="EAID_LI000026_03F4_46e2_94EA_9DE519CC3AF4" value="1"/>
>> </ownedAttribute>
>> </packagedElement>
>> xmi:id="EAID_524570EC_00AA_48ce_9798_633F4D0FAF92" name="Ph.h"
>> xmi:id="EAID_D264A9F6_95E4_42ef_820D_68B9A65D82EE" name="C"
>> xmi:id="EAID_LI000027_95E4_42ef_820D_68B9A65D82EE" value="1"/>
>> xmi:id="EAID_LI000028_95E4_42ef_820D_68B9A65D82EE" value="1"/>
>> <defaultValue xmi:id="EAID_LI000029_95E4_42ef_820D_68B9A65D82EE"
>> value="0x04"/>
>> </ownedAttribute>
>> xmi:id="EAID_0D162A65_3032_40e9_A9BF_9D0CCF0E39D3" name="C_F"
>> xmi:id="EAID_LI000029_3032_40e9_A9BF_9D0CCF0E39D3" value="1"/>
>> xmi:id="EAID_LI000030_3032_40e9_A9BF_9D0CCF0E39D3" value="1"/>
>> <defaultValue xmi:id="EAID_LI000031_3032_40e9_A9BF_9D0CCF0E39D3"
>> value="0x4000"/>
>> </ownedAttribute>
>> xmi:id="EAID_450489B9_CC5D_4c1b_A14A_FE50FB0C3926" name="C_Fl"
>> xmi:id="EAID_LI000031_CC5D_4c1b_A14A_FE50FB0C3926" value="1"/>
>> xmi:id="EAID_LI000032_CC5D_4c1b_A14A_FE50FB0C3926" value="1"/>
>> <defaultValue xmi:id="EAID_LI000033_CC5D_4c1b_A14A_FE50FB0C3926"
>> value="0x2000"/>
>> </ownedAttribute>
>> xmi:id="EAID_8BD9C4EF_CBD0_44d6_AC38_2683599C8BA6" name="C_Fla"
>> xmi:id="EAID_LI000033_CBD0_44d6_AC38_2683599C8BA6" value="1"/>
>> xmi:id="EAID_LI000034_CBD0_44d6_AC38_2683599C8BA6" value="1"/>
>> <defaultValue xmi:id="EAID_LI000035_CBD0_44d6_AC38_2683599C8BA6"
>> value="0x02"/>
>> </ownedAttribute>
>> xmi:id="EAID_EE17AB8E_79F8_47d0_BCA4_D0622F1F62C3" name="C_Flas"
>> xmi:id="EAID_LI000035_79F8_47d0_BCA4_D0622F1F62C3" value="1"/>
>> xmi:id="EAID_LI000036_79F8_47d0_BCA4_D0622F1F62C3" value="1"/>
>> <defaultValue xmi:id="EAID_LI000037_79F8_47d0_BCA4_D0622F1F62C3"
>> value="0x1000"/>
>> </ownedAttribute>
>> xmi:id="EAID_3FA96802_48F5_4aca_BA74_6BD4A9DFE5F3" name="C_H"
>> xmi:id="EAID_LI000037_48F5_4aca_BA74_6BD4A9DFE5F3" value="1"/>
>> xmi:id="EAID_LI000038_48F5_4aca_BA74_6BD4A9DFE5F3" value="1"/>
>> <defaultValue xmi:id="EAID_LI000039_48F5_4aca_BA74_6BD4A9DFE5F3"
>> value="0x08"/>
>> </ownedAttribute>
>> xmi:id="EAID_40E00161_763B_420d_8C36_5B996C59CAC4" name="C_He"
>> xmi:id="EAID_LI000039_763B_420d_8C36_5B996C59CAC4" value="1"/>
>> xmi:id="EAID_LI000040_763B_420d_8C36_5B996C59CAC4" value="1"/>
>> <defaultValue xmi:id="EAID_LI000041_763B_420d_8C36_5B996C59CAC4"
>> value="0x20"/>
>> </ownedAttribute>
>> xmi:id="EAID_DC309A9C_1D4C_4505_9CCE_98658A9E7320" name="C_Het"
>> xmi:id="EAID_LI000041_1D4C_4505_9CCE_98658A9E7320" value="1"/>
>> xmi:id="EAID_LI000042_1D4C_4505_9CCE_98658A9E7320" value="1"/>
>> <defaultValue xmi:id="EAID_LI000043_1D4C_4505_9CCE_98658A9E7320"
>> value="0x10"/>
>> </ownedAttribute>
>> xmi:id="EAID_39A7934A_74CC_472b_A4D2_55DC246DB690" name="ID_UL"
>> xmi:id="EAID_LI000043_74CC_472b_A4D2_55DC246DB690" value="1"/>
>> xmi:id="EAID_LI000044_74CC_472b_A4D2_55DC246DB690" value="1"/>
>> <defaultValue xmi:id="EAID_LI000045_74CC_472b_A4D2_55DC246DB690"
>> value="0x40"/>
>> </ownedAttribute>
>> xmi:id="EAID_BED3FAE5_F0B1_4fb2_8D38_39EFE17E9C3B" name="ID_UL1"
>> xmi:id="EAID_LI000045_F0B1_4fb2_8D38_39EFE17E9C3B" value="1"/>
>> xmi:id="EAID_LI000046_F0B1_4fb2_8D38_39EFE17E9C3B" value="1"/>
>> <defaultValue xmi:id="EAID_LI000047_F0B1_4fb2_8D38_39EFE17E9C3B"
>> value="0x80"/>
>> </ownedAttribute>
>> xmi:id="EAID_03FEB6F4_23D0_4472_9B27_4088F062B269" name="UB"
>> xmi:id="EAID_LI000047_23D0_4472_9B27_4088F062B269" value="1"/>
>> xmi:id="EAID_LI000048_23D0_4472_9B27_4088F062B269" value="1"/>
>> </ownedAttribute>
>> xmi:id="EAID_F017B5A3_3859_4b4e_B53C_318B503B0D20" name="UL"
>> xmi:id="EAID_LI000049_3859_4b4e_B53C_318B503B0D20" value="1"/>
>> xmi:id="EAID_LI000050_3859_4b4e_B53C_318B503B0D20" value="1"/>
>> </ownedAttribute>
>> xmi:id="EAID_04622168_3E1C_4458_9D9F_CED672472244" name="UL1"
>> xmi:id="EAID_LI000051_3E1C_4458_9D9F_CED672472244" value="1"/>
>> xmi:id="EAID_LI000052_3E1C_4458_9D9F_CED672472244" value="1"/>
>> <defaultValue xmi:id="EAID_LI000053_3E1C_4458_9D9F_CED672472244"
>> value="0x400"/>
>> </ownedAttribute>
>> xmi:id="EAID_5591BAA7_58CA_4574_921C_47439E3932F4" name="UL2"
>> xmi:id="EAID_LI000053_58CA_4574_921C_47439E3932F4" value="1"/>
>> xmi:id="EAID_LI000054_58CA_4574_921C_47439E3932F4" value="1"/>
>> <defaultValue xmi:id="EAID_LI000055_58CA_4574_921C_47439E3932F4"
>> value="0x800"/>
>> </ownedAttribute>
>> xmi:id="EAID_AB9C4001_57AC_4a04_86CC_23798A18A2DF" name="UL3"
>> xmi:id="EAID_LI000055_57AC_4a04_86CC_23798A18A2DF" value="1"/>
>> xmi:id="EAID_LI000056_57AC_4a04_86CC_23798A18A2DF" value="1"/>
>> <defaultValue xmi:id="EAID_LI000057_57AC_4a04_86CC_23798A18A2DF"
>> value="0x100"/>
>> </ownedAttribute>
>> xmi:id="EAID_0D819D4A_601F_4fd5_9F7C_029C060462DA" name="UL4"
>> xmi:id="EAID_LI000057_601F_4fd5_9F7C_029C060462DA" value="1"/>
>> xmi:id="EAID_LI000058_601F_4fd5_9F7C_029C060462DA" value="1"/>
>> <defaultValue xmi:id="EAID_LI000059_601F_4fd5_9F7C_029C060462DA"
>> value="0x200"/>
>> </ownedAttribute>
>> xmi:id="EAID_4BD757E9_F734_4267_B948_9F665BB6DF4B" name="UL5"
>> xmi:id="EAID_LI000059_F734_4267_B948_9F665BB6DF4B" value="1"/>
>> xmi:id="EAID_LI000060_F734_4267_B948_9F665BB6DF4B" value="1"/>
>> <defaultValue xmi:id="EAID_LI000061_F734_4267_B948_9F665BB6DF4B"
>> value="0x100"/>
>> </ownedAttribute>
>> <ownedOperation xmi:id="EAID_1FB5BA0A_817F_48d7_985C_8F4FD94706E4"
>> name="V" visibility="public" concurrency="sequential">
>> <ownedParameter xmi:id="EAID_7579BF43_7CBF_4e91_998F_6556D8EBB9B2"
>> name="l_ErrorId_UL" direction="pk_in"/>
>> </ownedOperation>
>> </packagedElement>
>> xmi:id="EAID_0AEA91B6_60B8_4044_9552_123705B7C497" name="XYZ.h"
>> xmi:id="EAID_54F9D7EC_4249_4242_AAC7_BB13190BD787" name="1_UL"
>> xmi:id="EAID_LI000061_4249_4242_AAC7_BB13190BD787" value="1"/>
>> xmi:id="EAID_LI000062_4249_4242_AAC7_BB13190BD787" value="1"/>
>> </ownedAttribute>
>> xmi:id="EAID_B1BCC9BF_09FA_439a_87F3_248201574F23" name="L"
>> xmi:id="EAID_LI000063_09FA_439a_87F3_248201574F23" value="1"/>
>> xmi:id="EAID_LI000064_09FA_439a_87F3_248201574F23" value="1"/>
>> </ownedAttribute>
>> xmi:id="EAID_DFC27553_2A02_442c_823C_43CD1D034A24" name="OFF"
>> xmi:id="EAID_LI000065_2A02_442c_823C_43CD1D034A24" value="1"/>
>> xmi:id="EAID_LI000066_2A02_442c_823C_43CD1D034A24" value="1"/>
>> </ownedAttribute>
>> xmi:id="EAID_EF03C6CD_51FA_46d2_8D0B_127BF90352A3" name="ON"
>> xmi:id="EAID_LI000067_51FA_46d2_8D0B_127BF90352A3" value="1"/>
>> xmi:id="EAID_LI000068_51FA_46d2_8D0B_127BF90352A3" value="1"/>
>> </ownedAttribute>
>> xmi:id="EAID_DF833404_8A71_4462_B1B3_9E529343A0C4" name="U"
>> xmi:id="EAID_LI000069_8A71_4462_B1B3_9E529343A0C4" value="1"/>
>> xmi:id="EAID_LI000070_8A71_4462_B1B3_9E529343A0C4" value="1"/>
>> </ownedAttribute>
>> xmi:id="EAID_3E289690_D9C4_4cb9_889F_53CA4DA9F62E" name="UL"
>> xmi:id="EAID_LI000071_D9C4_4cb9_889F_53CA4DA9F62E" value="1"/>
>> xmi:id="EAID_LI000072_D9C4_4cb9_889F_53CA4DA9F62E" value="1"/>
>> </ownedAttribute>
>> <ownedOperation xmi:id="EAID_C92674C6_05B9_445f_8037_20808961C579"
>> </packagedElement>
>> xmi:id="EAID_6C8CD667_59E4_42b6_98F4_85F460E6282B" name="in.h"
>> xmi:id="EAID_C0244F60_C580_48ad_98D5_0D2F6FF9F9CD" name="ED"
>> xmi:id="EAID_LI000073_C580_48ad_98D5_0D2F6FF9F9CD" value="1"/>
>> xmi:id="EAID_LI000074_C580_48ad_98D5_0D2F6FF9F9CD" value="1"/>
>> </ownedAttribute>
>> xmi:id="EAID_15E4E617_6E29_49e9_95E1_720EE56AEEA5" name="UL"
>> xmi:id="EAID_LI000075_6E29_49e9_95E1_720EE56AEEA5" value="1"/>
>> xmi:id="EAID_LI000076_6E29_49e9_95E1_720EE56AEEA5" value="1"/>
>> </ownedAttribute>
>> xmi:id="EAID_2539AD27_B179_4c7d_B307_DB9AC76856F6" name="UL1"
>> xmi:id="EAID_LI000077_B179_4c7d_B307_DB9AC76856F6" value="1"/>
>> xmi:id="EAID_LI000078_B179_4c7d_B307_DB9AC76856F6" value="1"/>
>> </ownedAttribute>
>> xmi:id="EAID_3C123386_221E_4b95_86DC_2FE29FED4C6C" name="UL2"
>> xmi:id="EAID_LI000079_221E_4b95_86DC_2FE29FED4C6C" value="1"/>
>> xmi:id="EAID_LI000080_221E_4b95_86DC_2FE29FED4C6C" value="1"/>
>> </ownedAttribute>
>> xmi:id="EAID_C6DABED3_63D4_4352_9A37_E73681B1FCF6" name="UL3"
>> xmi:id="EAID_LI000081_63D4_4352_9A37_E73681B1FCF6" value="1"/>
>> xmi:id="EAID_LI000082_63D4_4352_9A37_E73681B1FCF6" value="1"/>
>> </ownedAttribute>
>> xmi:id="EAID_659CB829_BB94_45ed_B622_A9A98C22691F" name="UW"
>> xmi:id="EAID_LI000083_BB94_45ed_B622_A9A98C22691F" value="1"/>
>> xmi:id="EAID_LI000084_BB94_45ed_B622_A9A98C22691F" value="1"/>
>> </ownedAttribute>
>> <ownedOperation xmi:id="EAID_5948638B_00F1_486d_97EF_45D37AFB8103"
>> <ownedOperation xmi:id="EAID_D54988F3_C4DA_491a_B737_CDC8178A5E27"
>> name="V1" visibility="public" concurrency="sequential"/>
>> <ownedOperation xmi:id="EAID_7769A273_CD9C_4771_8C62_A0A9C4AE43E4"
>> <ownedOperation xmi:id="EAID_DA91EA8E_64A5_4ec7_95EB_EC87D9B76A1A"
>> name="V3" visibility="public" concurrency="sequential"/>
>> <ownedOperation xmi:id="EAID_C6A2A643_8219_48dc_A243_C3BF8CD3708F"
>> name="V4" visibility="public" concurrency="sequential"/>
>> </packagedElement>
>> xmi:id="EAID_8B33B2D3_7EBA_48c0_A0F5_80F745A825E0" visibility="public"
>> client="EAID_6C8CD667_59E4_42b6_98F4_85F460E6282B"/>
>> <packagedElement xmi:type="uml:Component"
>> xmi:id="EAID_6BCFB871_6F81_4128_BF92_E0D5F12859B9" name="Sampl"
>> visibility="public"/>
>> <packagedElement xmi:type="uml:Realization"
>> xmi:id="EAID_AA01A369_87A1_4e30_BC64_1CD6D60ECDD5" visibility="public"
>> realizingClassifier="EAID_6C8CD667_59E4_42b6_98F4_85F460E6282B "
>> client="EAID_6BCFB871_6F81_4128_BF92_E0D5F12859B9"/>
>> xmi:id="EAID_48CFBEB8_378D_489b_AE67_B6FF4C9E776C" name="ESM09_COMMON :
>> ESM09_InterruptHandling" visibility="public"/>
>> xmi:id="EAID_52CE987F_1DF6_43db_9C3E_9E3F9818B125" name="ESM09_COMMON :
>> ESM09_Init" visibility="public"/>
>> xmi:id="EAID_687E4E47_19EC_4add_9178_7C827FAB68AA" name="internal ESM09
>> diagrams" visibility="public"/>
>> xmi:id="EAID_6C42D355_5696_472d_8E8C_8656CD760EC6" name="ESM09_COMMON"
>> xmi:id="EAID_7B83CA0A_706D_43d5_8ECB_A2ADA65C498C" name="Sample"
>> xmi:id="EAID_7F4D9478_93E7_4d17_9F30_D32664B86511" name="ESM09_COMMON"
>> xmi:id="EAID_8987A2AF_9FF0_4545_ACEA_8850C89D57EA" visibility="public"
>> client="EAID_7F4D9478_93E7_4d17_9F30_D32664B86511"/>
>> xmi:id="EAID_8F455C4F_A5FC_4ec4_8B3B_61B33A9155C0" name="ESM09_COMMON"
>> xmi:id="EAID_ACD3CC84_2F18_405d_B20D_C2C27640B6B7" name="ESM09_COMMON"
>> xmi:id="EAID_CBE4B06D_EC40_4acf_AA7A_276EC990DAF1" name="ESM09_COMMON :
>> ESM09_StartupTests" visibility="public"/>
>> </packagedElement>
>> </packagedElement>
>> <thecustomprofile:interface
>> base_Interface="EAID_90FD549A_5C50_4bb5_88C6_F7A80B3FDE2B"/ >
>> <thecustomprofile:Visibility
>> Visibility="ESM09_COMMON"/>
>> base_Interface="EAID_B9C9BA44_30FD_4b5d_AB3F_D4AD3936F1A9"/ >
>> <thecustomprofile:typedef_volatile_struct
>> base_Attribute="EAID_C4373B66_03F4_46e2_94EA_9DE519CC3AF4"
>> __EAStereoName="typedef volatile struct"/>
>> base_Interface="EAID_524570EC_00AA_48ce_9798_633F4D0FAF92"/ >
>> <thecustomprofile:extern
>> base_Attribute="EAID_03FEB6F4_23D0_4472_9B27_4088F062B269"/ >
>> base_Attribute="EAID_F017B5A3_3859_4b4e_B53C_318B503B0D20"/ >
>> base_Interface="EAID_0AEA91B6_60B8_4044_9552_123705B7C497"/ >
>> base_Attribute="EAID_54F9D7EC_4249_4242_AAC7_BB13190BD787"/ >
>> base_Attribute="EAID_B1BCC9BF_09FA_439a_87F3_248201574F23"/ >
>> base_Attribute="EAID_DF833404_8A71_4462_B1B3_9E529343A0C4"/ >
>> <thecustomprofile:extern_volatile
>> base_Attribute="EAID_3E289690_D9C4_4cb9_889F_53CA4DA9F62E"
>> __EAStereoName="extern volatile"/>
>> base_Interface="EAID_6C8CD667_59E4_42b6_98F4_85F460E6282B"/ >
>> Visibility="HSW"/>
>> base_Attribute="EAID_2539AD27_B179_4c7d_B307_DB9AC76856F6"
>> <thecustomprofile:inline
>> base_Operation="EAID_5948638B_00F1_486d_97EF_45D37AFB8103"/ >
>> base_Operation="EAID_D54988F3_C4DA_491a_B737_CDC8178A5E27"/ >
>> base_Operation="EAID_7769A273_CD9C_4771_8C62_A0A9C4AE43E4"/ >
>> base_Operation="EAID_DA91EA8E_64A5_4ec7_95EB_EC87D9B76A1A"/ >
>> base_Operation="EAID_C6A2A643_8219_48dc_A243_C3BF8CD3708F"/ >
>> <thecustomprofile:realize
>> base_Realisation="EAID_AA01A369_87A1_4e30_BC64_1CD6D60ECDD5 "/>
>> <uml:Profile xmi:version="2.1"
>> xmlns:uml="http://schema.omg.org/spec/UML/2.1/uml.xml"
>> xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmi:id="thecustomprofile"
>> nsPrefix="thecustomprofile" name="thecustomprofile"
>> metamodelReference="mmref01">
>> <ownedComment xmi:type="uml:Comment" xmi:id="comment01"
>> annotatedElement="thecustomprofile">
>> <body> Version:1.0</body>
>> </ownedComment>
>> <packageImport xmi:id="mmref01">
>> <importedPackage href="http://schema.omg.org/spec/UML/2.1/uml.xml"/>
>> </packageImport>
>> <packagedElement xmi:type="uml:Stereotype" xmi:id="realize"
>> name="realize">
>> <ownedAttribute xmi:type="uml:Property" xmi:id="realize-base_Realisation"
>> name="base_Realisation" association="Realisation_realize">
>> <type href="http://schema.omg.org/spec/UML/2.1/uml.xml#Realisation"/>
>> </ownedAttribute>
>> </packagedElement>
>> <packagedElement xmi:type="uml:Extension" xmi:id="Realisation_realize"
>> name="A_Realisation_realize" memberEnd="extension_realize
>> realize-base_Realisation">
>> <ownedEnd xmi:id="extension_realize" name="extension_realize"
>> type="realize" isComposite="true" lower="0" upper="1"
>> memberEnd="extension_realize realize-base_Realisation"/>
>> </packagedElement>
>> <packagedElement xmi:type="uml:Stereotype" xmi:id="extern" name="extern">
>> <ownedAttribute xmi:type="uml:Property" xmi:id="extern-base_Attribute"
>> name="base_Attribute" association="Attribute_extern">
>> <type href="http://schema.omg.org/spec/UML/2.1/uml.xml#Attribute"/>
>> </ownedAttribute>
>> </packagedElement>
>> <packagedElement xmi:type="uml:Extension" xmi:id="Attribute_extern"
>> name="A_Attribute_extern" memberEnd="extension_extern
>> extern-base_Attribute">
>> <ownedEnd xmi:id="extension_extern" name="extension_extern" type="extern"
>> isComposite="true" lower="0" upper="1" memberEnd="extension_extern
>> extern-base_Attribute"/>
>> </packagedElement>
>> <packagedElement xmi:type="uml:Stereotype" xmi:id="extern volatile"
>> name="extern volatile">
>> volatile-base_Attribute" name="base_Attribute"
>> association="Attribute_extern volatile">
>> </ownedAttribute>
>> </packagedElement>
>> volatile" name="A_Attribute_extern volatile" memberEnd="extension_extern
>> volatile extern volatile-base_Attribute">
>> <ownedEnd xmi:id="extension_extern volatile" name="extension_extern
>> volatile" type="extern volatile" isComposite="true" lower="0" upper="1"
>> memberEnd="extension_extern volatile extern volatile-base_Attribute"/>
>> </packagedElement>
>> <packagedElement xmi:type="uml:Stereotype" xmi:id="interface"
>> name="interface">
>> <ownedAttribute xmi:type="uml:Property" xmi:id="interface-base_Interface"
>> name="base_Interface" association="Interface_interface">
>> <type href="http://schema.omg.org/spec/UML/2.1/uml.xml#Interface"/>
>> </ownedAttribute>
>> </packagedElement>
>> <packagedElement xmi:type="uml:Extension" xmi:id="Interface_interface"
>> name="A_Interface_interface" memberEnd="extension_interface
>> interface-base_Interface">
>> <ownedEnd xmi:id="extension_interface" name="extension_interface"
>> type="interface" isComposite="true" lower="0" upper="1"
>> memberEnd="extension_interface interface-base_Interface"/>
>> </packagedElement>
>> <packagedElement xmi:type="uml:Stereotype" xmi:id="inline" name="inline">
>> <ownedAttribute xmi:type="uml:Property" xmi:id="inline-base_Operation"
>> name="base_Operation" association="Operation_inline">
>> <type href="http://schema.omg.org/spec/UML/2.1/uml.xml#Operation"/>
>> </ownedAttribute>
>> </packagedElement>
>> <packagedElement xmi:type="uml:Extension" xmi:id="Operation_inline"
>> name="A_Operation_inline" memberEnd="extension_inline
>> inline-base_Operation">
>> <ownedEnd xmi:id="extension_inline" name="extension_inline" type="inline"
>> isComposite="true" lower="0" upper="1" memberEnd="extension_inline
>> inline-base_Operation"/>
>> </packagedElement>
>> <packagedElement xmi:type="uml:Stereotype" xmi:id="Visibility"
>> name="Visibility">
>> <ownedAttribute xmi:type="uml:Property" xmi:id="Visibility-base_Interface"
>> name="base_Interface" association="Interface_Visibility">
>> </ownedAttribute>
>> <ownedAttribute xmi:type="uml:Property" xmi:id="Visibility-Visibility"
>> name="Visibility">
>> <type href="http://schema.omg.org/spec/UML/2.1/uml.xml#String"/>
>> </ownedAttribute>
>> </packagedElement>
>> <packagedElement xmi:type="uml:Extension" xmi:id="Interface_Visibility"
>> name="A_Interface_Visibility" memberEnd="extension_Visibility
>> Visibility-base_Interface">
>> <ownedEnd xmi:id="extension_Visibility" name="extension_Visibility"
>> type="Visibility" isComposite="true" lower="0" upper="1"
>> memberEnd="extension_Visibility Visibility-base_Interface"/>
>> </packagedE
Re: Loading Model from Enterprise architect [message #627414 is a reply to message #478218] |
customers.
regards
raphaël
> Anand,
> Kenn
>> Hello James,
>> a valid classifier
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> value="0x04"/>
>> </ownedAttribute>
>> value="0x4000"/>
>> </ownedAttribute>
>> value="0x2000"/>
>> </ownedAttribute>
>> value="0x02"/>
>> </ownedAttribute>
>> value="0x1000"/>
>> </ownedAttribute>
>> value="0x08"/>
>> </ownedAttribute>
>> value="0x20"/>
>> </ownedAttribute>
>> value="0x10"/>
>> </ownedAttribute>
>> value="0x40"/>
>> </ownedAttribute>
>> value="0x80"/>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> value="0x400"/>
>> </ownedAttribute>
>> value="0x800"/>
>> </ownedAttribute>
>> value="0x100"/>
>> </ownedAttribute>
>> value="0x200"/>
>> </ownedAttribute>
>> value="0x100"/>
>> </ownedAttribute>
>> </ownedOperation>
>> </packagedElement>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> </packagedElement>
>> </packagedElement>
>> Visibility="HSW"/>
>> </ownedComment>
>> </packageImport>
>> name="realize">
>> </ownedAttribute>
>> </packagedElement>
>> </packagedElement>
>> </ownedAttribute>
>> </packagedElement>
>> </packagedElement>
>> </ownedAttribute>
>> </packagedElement>
>> </packagedElement>
>> name="interface">
>> </ownedAttribute>
>> </packagedElement>
>> </packagedElement>
>> </ownedAttribute>
>> </packagedElement>
>> </packagedElement>
>> name="Visibility">
>> </ownedAttribute>
>> name="Visibility">
>> </ownedAttribute>
>> </packagedElement>
>> </packagedE
FUDForum. Page generated in 0.05007 seconds
