Home » Modeling » UML2 » Export to UML from ECORE fails
Export to UML from ECORE fails [message #478000] Sun, 23 November 2008 14:30 Go to next message
I get an InvocationTargetException caused by a DanglingHREFException,
the full stacktrace is in this message.
How can I locate the element causing the error?
Heinz
java.lang.reflect.InvocationTargetException
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:119)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:458)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:366)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 934)
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rWizard.performFinish(ModelConverterWizard.java:246)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:742)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:373)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
org.eclipse.emf.converter.ui.OpenWizardActionDelegate.run(Op enWizardActionDelegate.java:115)
org.eclipse.emf.converter.ui.OpenWizardActionDelegate.run(Op enWizardActionDelegate.java:105)
org.eclipse.ui.actions.ActionDelegate.runWithEvent(ActionDel egate.java:70)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:241)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:583)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:500)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
Caused by: org.eclipse.core.runtime.CoreException: An error occurred
while performing this operation.
org.eclipse.emf.common.util.DiagnosticException.toCoreExcept ion(DiagnosticException.java:47)
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rWizard$1.execute(ModelConverterWizard.java:235)
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:104)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1800)
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:116)
... 45 more
Caused by: org.eclipse.emf.common.util.DiagnosticException: An error
occurred while performing this operation.
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rWizard$1.execute(ModelConverterWizard.java:234)
... 48 more
Caused by: org.eclipse.emf.ecore.resource.Resource$IOWrappedException:
The object 'org.eclipse.uml2.uml.internal.impl.PrimitiveTypeImpl@1c44394
(name: Boolean, visibility: <unset>) (isLeaf: false, isAbstract: false)'
is not contained in a resource.
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.endSave(XMLSaveIm pl.java:306)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:270)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:205)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:1344)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:986)
org.eclipse.uml2.uml.ecore.exporter.UMLExporter.doExport(UML Exporter.java:151)
at org.eclipse.emf.exporter.ModelExporter.export(ModelExporter. java:634)
org.eclipse.emf.exporter.ui.contribution.base.ModelExporterW izard.doPerformFinish(ModelExporterWizard.java:113)
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rWizard$1.execute(ModelConverterWizard.java:228)
... 48 more
Caused by: org.eclipse.emf.ecore.xmi.DanglingHREFException: The object
'org.eclipse.uml2.uml.internal.impl.PrimitiveTypeImpl@1c44394 (name:
Boolean, visibility: <unset>) (isLeaf: false, isAbstract: false)' is not
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.handleDanglingH REF(XMLHelperImpl.java:760)
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.getURIFragment( XMLHelperImpl.java:731)
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.getIDREF(XMLHel perImpl.java:753)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveIDRefSingle(X MLSaveImpl.java:1954)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1300)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:2667)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:1156)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:1017)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedMany (XMLSaveImpl.java:2368)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1515)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.writeTopObject(XM LSaveImpl.java:671)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:588)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:256)
... 55 more
Re: Export to UML from ECORE fails [message #478004 is a reply to message #478000] Mon, 24 November 2008 10:44 Go to previous messageGo to next message
Hi Heinz,
It appears that you are trying to save a Boolean primitive type that is "not
contained in a resource".
Try setting breakpoints on the DanglingHREFException to get a better idea of
which item is failing.
If you are still having issues, try posting a snippet of the model and a
reproduceable scenario and I can have a look.
- James.
"Heinz Drews" <heinz.drews@gmail.com> wrote in message
news:ggcb1p$sfq$1@build.eclipse.org...
> Hello,
> I get an InvocationTargetException caused by a DanglingHREFException, the
> Heinz
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by: org.eclipse.core.runtime.CoreException: An error occurred while
> at
> at
> at
> at
> ... 45 more
> at
> ... 48 more
> Caused by: org.eclipse.emf.ecore.resource.Resource$IOWrappedException: The
> at
> at
> at
> at
> at
> at
> at
> ... 48 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 55 more
Re: Export to UML from ECORE fails [message #478015 is a reply to message #478004] Tue, 25 November 2008 02:07 Go to previous messageGo to next message
James Bruck wrote:
Hi James,
thanks for the quick response.
I'll check the model but this is relatively big.
Are there instructions somewhere what has to be setup to run in debug mode?
Heinz
> Hi Heinz,
> Cheers,
> - James.
>> Hello,
>> Regards,
>> Heinz
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> ... 45 more
>> at
>> ... 48 more
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 48 more
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 55 more
Re: Export to UML from ECORE fails [message #478032 is a reply to message #478015] Wed, 26 November 2008 16:31 Go to previous message
Hi Heinz,
No special setup is required. You would need to have access to the source
to find out where the exception is happening. Just set a breakpoint at the
occurrence of the exception.
- James.
news:ggg87v$qrn$1@build.eclipse.org...
> James Bruck wrote:
> Hi James,
> mode?
> Best regards,
> Heinz
>> Hi Heinz,
>> "not contained in a resource".
>> of which item is failing.
>> Cheers,
>> - James.
>>> Hello,
>>> Regards,
>>> Heinz
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 45 more
>>> at
>>> ... 48 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 48 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 55 more
Re: Export to UML from ECORE fails [message #627221 is a reply to message #478000] Mon, 24 November 2008 10:44 Go to previous message
Hi Heinz,
- James.
> Hello,
> Heinz
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 45 more
> at
> ... 48 more
> at
> at
> at
> at
> at
> at
> at
> ... 48 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 55 more
Re: Export to UML from ECORE fails [message #627232 is a reply to message #478004] Tue, 25 November 2008 02:07 Go to previous message
James Bruck wrote:
Hi James,
Heinz
> Hi Heinz,
> Cheers,
> - James.
>> Hello,
>> Regards,
>> Heinz
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 45 more
>> at
>> ... 48 more
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 48 more
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 55 more
Re: Export to UML from ECORE fails [message #627249 is a reply to message #478015] Wed, 26 November 2008 16:31 Go to previous message
Hi Heinz,
- James.
> James Bruck wrote:
> Hi James,
> mode?
> Best regards,
> Heinz
>> Hi Heinz,
>> Cheers,
>> - James.
>>> Hello,
>>> Regards,
>>> Heinz
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 45 more
>>> at
>>> ... 48 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 48 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 55 more
Previous Topic:Usage of DerivedUnion or simple derived?
Next Topic:Reflective feature delegation works incorrectly
Current Time: Tue Oct 28 06:45:02 EDT 2025
Powered by FUDForum. Page generated in 0.06117 seconds
