Home » Modeling » UML2 » EMF Code generation from UML2 model fails
EMF Code generation from UML2 model fails [message #477841] Fri, 17 October 2008 04:40 Go to next message
problems don't stop :) Currently, i try to convert a UML2 model (with union
and subset) into a valid Ecore file. It contains an ownership relationship,
similar to the owner/ownedElements from the UML::Class::Kernel::Element.
ModelElement (EClass)
owner (EReference): changeable, non-transient, non-volatile, non-derived
ownedElements (EReference): changeable, non-transient, non-volatile,
non-derived
These both references are opposites. The problem is, that no attribute
ownedElements is generated into the ModelElement class. All the successor
methods are defined, but they produce a Syntax error, because of that
missing attributes. I can fullfill the missing attriibute by hand, but i
think, this is not the best way to handle such a problem?
Thx
TImothy
Re: EMF Code generation from UML2 model fails [message #477843 is a reply to message #477841] Fri, 17 October 2008 10:30 Go to previous messageGo to next message
Hi Timothy,
Do you have a sample .uml model with .genmodel that I can use to reproduce
what you are seeing?
There may be some incompatible combination of properties that produce an
error.
Please raise a bugzilla if this is an issue in the UML2 project itself.
- James.
"Timothy Marc" <timothymarc@freenet.de> wrote in message
news:gd9itg$al$1@build.eclipse.org...
> union and subset) into a valid Ecore file. It contains an ownership
> relationship, similar to the owner/ownedElements from the
> non-derived
> non-derived
> Thx
> TImothy
Re: EMF Code generation from UML2 model fails [message #477848 is a reply to message #477843] Mon, 20 October 2008 09:31 Go to previous messageGo to next message
Dear James,
yes, it was a problem in the model. I've tried the same with a simple model
and it works.
But one question concerning the Union/Subset-List-Types of the UML2
codegenerator.
After creating an Ecore out of a really simple UML model, the Ecore was
annotated with some union/subsets-Annotations. So far so good. But after
code generation only the uniosn-Annotations resultng in a
DerivedUnionEObjectList-Type. All the subsets-relationships are treated as
ordinary EMF-List. I'm pretty sure, that i got him work, but currently,
either wich input i provide, it never produces these uml2 specific types.
I'm really confused...
Thx
Timothy
"James Bruck" <jbruck@ca.ibm.com> schrieb im Newsbeitrag
news:gda7g0$j2e$1@build.eclipse.org...
> Hi Timothy,
> error.
> Cheers,
> - James.
>> non-derived
>> non-derived
>> Thx
>> TImothy
Re: EMF Code generation from UML2 model fails [message #477876 is a reply to message #477848] Thu, 23 October 2008 12:45 Go to previous message
Timothy,
Depending on the multiplicities of your subset/superset properties, you may
or may not see the subset/superset lists being used by generated code. If
you attach a sample model that you think is problematic, we'll take a
look...
Kenn
news:gdi12i$8ue$1@build.eclipse.org...
> Dear James,
> model and it works.
> codegenerator.
> Thx
> Timothy
>> Hi Timothy,
>> reproduce what you are seeing?
>> error.
>> Cheers,
>> - James.
>>> Hi,
>>> non-derived
>>> non-derived
>>> successor methods are defined, but they produce a Syntax error, because
>>> of that missing attributes. I can fullfill the missing attriibute by
>>> hand, but i think, this is not the best way to handle such a problem?
>>> Thx
>>> TImothy
Re: EMF Code generation from UML2 model fails [message #627048 is a reply to message #477841] Fri, 17 October 2008 10:30 Go to previous message
Hi Timothy,
error.
- James.
> non-derived
> non-derived
> Thx
> TImothy
Re: EMF Code generation from UML2 model fails [message #627051 is a reply to message #477843] Mon, 20 October 2008 09:31 Go to previous message
Dear James,
and it works.
codegenerator.
Thx
Timothy
> Hi Timothy,
> error.
> Cheers,
> - James.
>> non-derived
>> non-derived
>> Thx
>> TImothy
Re: EMF Code generation from UML2 model fails [message #627076 is a reply to message #477848] Thu, 23 October 2008 12:45 Go to previous message
Timothy,
look...
Kenn
> Dear James,
> model and it works.
> codegenerator.
> Thx
> Timothy
>> Hi Timothy,
>> error.
>> Cheers,
>> - James.
>>> Hi,
>>> non-derived
>>> non-derived
>>> Thx
>>> TImothy
Previous Topic:Complete Project Development
Next Topic:Using UML2 mechanism
Current Time: Mon Oct 27 06:29:00 EDT 2025
Powered by FUDForum. Page generated in 0.03993 seconds
