Home » Modeling » UML2 » uml2.ecore mistake
Re: uml2.ecore mistake [message #477804 is a reply to message #477803] |
Fri, 10 October 2008 08:18 |
Cyril Faucher Messages: 63 Registered: July 2009 |
Member |
Ed,
I think there is a redundancy, I mean:
The context:
EClass Element
Element.owner as type Element (derived)
Element.ownedElement as type Element (derived)
Element.owner and Element.ownedElement are opposite
If I want to get the value of Element.owner then I am using the
implementation of the dedicated getter. The same thing for
Element.ownedElement.
Now, if I have a setter on Element.owner, I am using the implementation
of the dedicated setter. This setter could not impact the value of
Element.owner then Element.ownedElement (opposite) will be not updated.
Finally, in my opinion and in this specific case, the opposite is there
just there for a semantic sugar, but ignored in the rest.
Cyril.
Ed Merks a écrit :
> Cyril,
> It sounds okay to me, especially if they are derived from references
> that are similarly paired as opposites. Why do you think it doesn't
> make sense?
> Cyril Faucher wrote:
>> Hi,
>> I have a question about the metamodel of uml2: uml2.ecore.
>> The EClass "Element" has 2 EReferences "owner" and "ownedElement".
>> These 2 EReferences are derived.
>> My problem is: why they are opposite, I guess that comes from the
>> translation of an UML Association in Ecore.
>> For me, I think that does not make sense in Ecore to have 2 derived
>> EReferences and opposite.
>> Best regards,
>> Cyril.
Re: uml2.ecore mistake [message #477805 is a reply to message #477804] |
Fri, 10 October 2008 10:49 |
Ed Merks Messages: 33142 Registered: July 2009 |
Cyril,
Comments below.
> Ed,
> The context:
> EClass Element
It looks to be derived from EObject.eContainer.
> The same thing for Element.ownedElement.
This looks to be a derived union, so I imagine it's effectively like
containment reference.
> implementation of the dedicated setter.
But there doesn't appear to be one.
> This setter could not impact the value of Element.owner then
I guess it wouldn't be clear setting the owner which specific
containment reference the child should go into. However, if the child
is added to some specific containment reference and hence effectively
into the owned elements derived union, then that does impact the owner
in the usual bidirectional way. So while it doesn't seem necessary to
make these things opposites, and hence redundant, it doesn't seem wrong
or inconsistent. In fact it seems useful in a perhaps fairly useless way...
> there just there for a semantic sugar, but ignored in the rest.
I guess so. If you looked at the class diagram representation, it's
represented as an association with two ends though right?
> Cyril.
> Ed Merks a écrit :
>> Cyril,
>> make sense?
>>> Hi,
>>> Best regards,
>>> Cyril.
Ed Merks
Re: uml2.ecore mistake [message #627001 is a reply to message #477801] |
Thu, 09 October 2008 16:20 |
Cyril,
make sense?
> Best regards,
> Cyril.
Ed Merks
Re: uml2.ecore mistake [message #627002 is a reply to message #477803] |
Member |
Ed,
The context:
EClass Element
Cyril.
Ed Merks a écrit :
> Cyril,
> make sense?
>> Hi,
>> Best regards,
>> Cyril.
Re: uml2.ecore mistake [message #627003 is a reply to message #477804] |
Cyril,
Comments below.
> Ed,
> The context:
> EClass Element
> Cyril.
> Ed Merks a écrit :
>> Cyril,
>> make sense?
>>> Hi,
>>> Best regards,
>>> Cyril.
Ed Merks
Current Time: Fri Apr 26 06:48:59 GMT 2024
Powered by FUDForum. Page generated in 0.04040 seconds
