Home » Modeling » UML2 » UUID generation
Re: UUID generation [message #477762 is a reply to message #477760] |
Sat, 27 September 2008 11:53 |
Ed Merks Messages: 33142 Registered: July 2009 |
--------------060909030405090705090604
Timothy,
Generally you should use eObject.eResource().getURIFragment(eObject).
This will return whatever the resource decides is the URI fragment you
should be using to look up the object within its containing resource.
This might be a fragment path (the default), the intrinsic ID of the
eObject (the value of the eObject.eClass().getEIDAttribute() if it has
one), or the extrinsic ID (the value of XMLResource.getID(eObject) if it
has an associated extrinsic ID). So probably you already have what you
need because UML and GMF typically are making heavy use of extrinsic IDs
that are UUIDs (with your xmi:id comments being indicative of that).
Timothy Marc wrote:
> Ed,
> thanks, but where can i configure the uml tool to use this kind of
> implementation. Currently, all elements have only these xmi:id attributes,
> but these couldn't be accessed from within my jet2 transformation via
> EcoreUtil.getID().
> Thx
> Timothy
> "Ed Merks" <Ed.Merks@gmail.com> schrieb im Newsbeitrag
> news:gbl4dp$860$1@build.eclipse.org...
>> Timothy,
>> You need to use an XMIResourceImpl for which useUUIDs() is specialized to
>> return true. UML and GMF both have resource factories that return such
>> resource implementations already...
>> Timothy Marc wrote:
>>> Hi all,
>>> i've modeled a simple class diagramm with papyrus and wanted the editor
>>> to
>>> use the useUUID() method from XMIResource (i'm not sure whether this is
>>> the
>>> right class). I need those UUIDs for traceability during a JET2/MTL
>>> M2C-Transformation, ut didn't found any possibility to turn this on.
>>> Any help would be appreciated.
>>> Thx
>>> Timothy
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Timothy,<br>
<br>
it has an associated extrinsic ID). So probably you already have what
you need because UML and GMF typically are making heavy use of
extrinsic IDs that are UUIDs (with your xmi:id comments being
indicative of that).<br>
<br>
<br>
Timothy Marc wrote:
<blockquote cite="mid:gbl5u5$df3$1@build.eclipse.org" type="cite">
<pre wrap="">Ed,
EcoreUtil.getID().
Thx
Timothy
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com"><Ed.Merks@gmail.com></a> schrieb im Newsbeitrag
<a class="moz-txt-link-freetext" href="news:gbl4dp$860$1@build.eclipse.org">news:gbl4dp$860$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Timothy,
Timothy Marc wrote:
</pre>
<pre wrap="">Hi all,
to
the
Thx
Timothy
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------060909030405090705090604--
Ed Merks
Re: UUID generation [message #626958 is a reply to message #477758] |
Sat, 27 September 2008 11:11 |
Timothy,
to return true. UML and GMF both have resource factories that return
such resource implementations already...
Timothy Marc wrote:
> Hi all,
> i've modeled a simple class diagramm with papyrus and wanted the editor to
> use the useUUID() method from XMIResource (i'm not sure whether this is the
> Thx
> Timothy
Ed Merks
Re: UUID generation [message #626960 is a reply to message #477760] |
Timothy,
Timothy Marc wrote:
> Ed,
> EcoreUtil.getID().
> Thx
> Timothy
>> Timothy,
>> Timothy Marc wrote:
>>> Hi all,
>>> to
>>> the
>>> Thx
>>> Timothy
<html>
<head>
</head>
Timothy,<br>
<br>
<br>
<br>
<pre wrap="">Ed,
EcoreUtil.getID().
Thx
Timothy
</pre>
Timothy Marc wrote:
</pre>
to
the
Thx
Timothy
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
</body>
</html>
Ed Merks
Current Time: Fri Apr 26 09:23:17 GMT 2024
Powered by FUDForum. Page generated in 0.03934 seconds
