Home » Modeling » UML2 » Code generator problem with redefinitions
Re: Code generator problem with redefinitions [message #477609 is a reply to message #477608] |
Wed, 16 July 2008 14:15 |
Lutz Wrage Messages: 181 Registered: July 2009 |
That was so misleading... Here the clarification:
The stack overflow occurs if the feature is accessed using eGet and
eIsSet, which are used in the generated editor, for example. That's
where I ran into the problem.
The generated isSet and getB methods are obviously fine, and there
certainly is code to handle multiple inheritance. It seems that it's not
enough, though.
- Lutz
Lutz Wrage wrote, on 7/16/2008 9:41 AM:
> I ran into the following problem when generating code from my metamodel.
> It's when I use a combination of multiple inheritance an redefinition.
> See the attached file for a minimal example.
> I have a class C that specializes two classes A and B. A and B have
> properties a and b, respectively. In C I redefine both properties. I
> generate code for this model (with processing duplicate features). The
> generated Java implementation class CImpl extends AImpl.
> However, the generated code has the problem that it is impossible to get
> the value of feature b in C, because eGet, etc., only go up the Java
> inheritance hierarchy. Accessing C.b in any way leads to a stack
> overflow. To me this looks like an oversight in the UML code generator
> because it creates no code that takes UML multiple inheritance into
> account for this scenario.
> I changed my metamodel to use subsetting instead, but that's not quite
> the correct semantics in my situation.
> - Lutz
Re: Code generator problem with redefinitions [message #477619 is a reply to message #477609] |
Fri, 18 July 2008 16:03 |
No need to reply to this. I've reported a bug (patch attached):
https://bugs.eclipse.org/bugs/show_bug.cgi?id=241411
- Lutz
Lutz Wrage wrote, on 7/16/2008 10:15 AM:
> enough, though.
> - Lutz
>> Hi,
>> metamodel. It's when I use a combination of multiple inheritance an
>> redefinition. See the attached file for a minimal example.
>> get the value of feature b in C, because eGet, etc., only go up the
>> Java inheritance hierarchy. Accessing C.b in any way leads to a stack
>> - Lutz
Re: Code generator problem with redefinitions [message #477620 is a reply to message #477619] |
Fri, 18 July 2008 18:06 |
james bruck Messages: 1724 Registered: July 2009 |
Thanks Lutz,
I'll have a look at the defect in detail for the next iteration of UML2.
- James.
"Lutz Wrage" <lwrage@sei.cmu.edu> wrote in message
news:g5qet7$uh7$1@build.eclipse.org...
> - Lutz
>> eIsSet, which are used in the generated editor, for example. That's where
>> enough, though.
>> - Lutz
>>> Hi,
>>> - Lutz
Re: Code generator problem with redefinitions [message #626799 is a reply to message #477608] |
enough, though.
- Lutz
> - Lutz
Re: Code generator problem with redefinitions [message #626810 is a reply to message #477609] |
- Lutz
> enough, though.
> - Lutz
>> Hi,
>> - Lutz
Re: Code generator problem with redefinitions [message #626811 is a reply to message #477619] |
Thanks Lutz,
- James.
> - Lutz
>> enough, though.
>> - Lutz
>>> Hi,
>>> - Lutz
Current Time: Sun May 12 18:54:04 GMT 2024
Powered by FUDForum. Page generated in 0.04228 seconds
