Home » Modeling » UML2 » Re: Amalgamate Models
Re: Amalgamate Models [message #477431] Sat, 24 May 2008 09:33 Go to next message
Zheng,
Please use the UML newsgroup, which I've added to the "to" list of the
reply, for questions about UML.
Zheng Xie wrote:
> Zheng Xie wrote:
>> I have two uml models, model1 and model2. I need to add all the
>> elements in model2 into model1, so that the new model1 has all the
>> elements of model1 and model2. How can I do it?
>> Thanks.
> Basicly, what I did is:
> find all the Packages in model2 and add them to model1's
> packagedElements.
> The problem is:
> The applied stereotypes are lost.
Re: Amalgamate Models [message #477456 is a reply to message #477431] Wed, 28 May 2008 09:47 Go to previous message
Hi Zheng,
For a general "copy" method you can have a look at EcoreUtil.copy(EObject
eObject).
The UMLUtil PackageMerger uses this to copy elements.
Alternatively have a look UML2Util.getAllContents() to get the contents of
one object. A defensive copy of the contents can be made.
- James.
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:g195bt$ct7$1@build.eclipse.org...
> Zheng,
> Zheng Xie wrote:
>> Zheng Xie wrote:
>>> I have two uml models, model1 and model2. I need to add all the elements
>>> in model2 into model1, so that the new model1 has all the elements of
>>> Thanks.
>> packagedElements.
>> The problem is:
Re: Amalgamate Models [message #626638 is a reply to message #477431] Wed, 28 May 2008 09:47 Go to previous message
Hi Zheng,
eObject).
- James.
> Zheng,
>>> Thanks.
>> packagedElements.
>> The problem is:
Previous Topic:[Announce] MDT UML2 2.2.0RC2 is available
Next Topic:static profiles with model libraries
Current Time: Thu Sep 25 11:26:22 EDT 2025
Powered by FUDForum. Page generated in 0.04223 seconds
